battlehawk battlehawk is offline
Car: 2017 M2 and 2007 335xi e90 6mt
Smile Suggestions for fueling set up? - 05-03-2017, 01:08 PM
Hey Folks,
Recently purchased n54 pure stage 2 turbo Hi- flow set up. I am at the point where I need to figure out the fueling upgrades and requirements . My build goal is 600HP ish on 93 pump gas or some e85 blend. Maybe 650hp on e85.
I already have EOS port injection/intake manifold with the JB4 controller.
I don't have a problem to run full E85 to reach my power goals. My main goal is to reach this power level safely.
My question is do I need a stage 3 or 4 lpfp? Also is upgrading the fuel lines required ? Thanks for your help
If I missed anything please let me know.
BevsM3's Avatar
BevsM3 BevsM3 is offline
Car: 2010 535i m sport wagon
Default 05-03-2017, 01:44 PM
Do you have the stage 2 LPFP now?
Default 05-03-2017, 01:49 PM
I have no upgraded pump now. Fuel is system is completely stock. I just have the EOS mainifold ready to be installed. I inherited the car from my brother when he passed away.
BevsM3's Avatar
Default 05-03-2017, 01:51 PM
I'm sorry to hear that!!
I think with the manifold and stage 2 LPFP you will not have a problem reaching those power levels, but maybe someone from fuel-it can chime in.
Default 05-03-2017, 01:57 PM
Thanks. I am finishing what he started
That was my original conclusion. But from my research I see people with stage 3 pumps who have similar set ups . Also Pure claims theses turbos can support 700 hp (with supporting mods of course) But I took that with a grain of salt (AKA 650hp number) and if I decided to go for a glory run all I have to do is have the correct back end flash and change a few settings and bam
N54QC N54QC is offline
Car: 07 BMW 335i
Default 05-03-2017, 02:18 PM
I would say you would need a stage 3 at a minimal for your power goals. Steve will have to chime in on the specifics, as you are potentially looking to go into the upper 600's might require a stage 4.
Car: 2013 Genesis Coupe
Default 05-03-2017, 02:54 PM
I don't think your ever going to make 600whp on 93 pump without meth. Stage 2 might be able to hold that power level, but you might as well get a stage 3 with dual pumps with a hobbs switch or whatever you want to use to trigger the secondary pump when needed.
HanSolo71 HanSolo71 is offline
Car: 2008 135i 'Vert M-Sport
Default 05-03-2017, 03:06 PM
Why? I only ask because I kind of assumed we were limited by how much boost we were willing to throw at the motor as long as we had the fuel to do it.
Default 05-03-2017, 03:12 PM
Well you see, more boost and timing requires higher octane since it produces more heat. E85 is around 105 octane so the reason people do a mix is to raise their octane levels and make sure there is no knock at higher boost levels
Default 05-03-2017, 04:24 PM
For those kinds of numbers on straight E85, we would recommend our Stage 4 kit. It will get you all the upgraded fuel lines and have no problem supporting 700whp on straight E85. Otherwise you're looking at a Stage 3 kit plus fuel lines and return kit anyways...so it'd be better and support more power to go with our Stage 4 kit. You can email us at info@fuel-it.com with any additional questions or post them here.
http://www.fuel-it.biz/e-series-135i...-line-upgrade/
For reference, here is a log of our 135i running Pure Stage 2 high flows on E85 with a full stage 4 kit and and our port injection kit.
BevsM3's Avatar
Default 05-03-2017, 04:39 PM
So should he dump the PI manifold and just use the stage 4?
Correction I see your running one as well as the stage 4
BevsM3's Avatar
Default 05-03-2017, 04:46 PM
I have some questions about fueling the 535, email coming.
sshec152's Avatar
sshec152 sshec152 is offline
Car: 07 335i mt
Default 05-03-2017, 07:22 PM
Check out precisionraceworks.com stange 3 lpfp. You'll easily be able to reach your goal, and at a great price
