Default 05-17-2020, 07:31 PM
Overall looks healthy.
Jesus on that plug -__-
Jaymepri13's Avatar
Jaymepri13 Jaymepri13 is offline
E92 335i 6mt
Car: 2007 E92 335i
Default 05-26-2020, 07:32 AM
Not sure if I should start a new thread or not .... everything is going well still running pump bef flash , running approx e30 mostly map 5 targets 15-16 psi boost , map 2 targets 17psi. . Looking to flash the hybrid e85 bef , run e50 .. not sure which maps to test out first ... map 2, Log ....: map 5 log .. and then ? If all is well w/e50 then what map 7?
2007 335i E92 N54 6mt jb4 Bluetooth connect, pure 600s ,Vrsf dpís , vrsf outlets & inlets, occ, dci, vrsf 7.5 step Intercooler , ER cp , synapse bov, Fuel-it stage 2 bucketless lpfp , Mhd pump bef , 3.5 tmap, ngk 2step colder plugs, Dinan axleback, H&R coilovers
Jaymepri13's Avatar
E92 335i 6mt
Car: 2007 E92 335i
Default 05-26-2020, 07:38 AM
My goal is to be 500hp+ daily driven .. have the option to switch between something like map 5 and 7 .. 5 being aggressive daily and switch to map 7 for some fun ��.
Default 05-26-2020, 08:46 AM
Bump your octane up, flash & run map 1 first- logging protocols stay same
Jaymepri13's Avatar
E92 335i 6mt
Car: 2007 E92 335i
Default E85 hybrid bef - 06-22-2020, 05:03 PM
Finally got around to do some logging after replacing the Vanos solenoid today . What a difference with the E85 hybrid flash and running about E55 . the gauge through the mobile app for E85 reads 0 now is that normal
Default 06-23-2020, 06:13 AM
Log looks really clean.
Keep an eye on the lpfp, touching 60-61
Rule77's Avatar
Rule77 Rule77 is offline
Car: 08 E90 335i
Default 06-30-2020, 04:49 AM
Iím pretty sure the gauge for E85 on your Jb4 doesnít mean anything unless you have an ethanol sensor.
BMS DCI - BMS OCC - BMS COWL FILTERS
MMP CHARGEPIPE - TIAL BOV - VRSF 7.5Ē RACE FMIC
VRSF DPís - VRSF INLETS - VRSF OUTLETS
NGK 97506 @.022 - STAGE 2 LPFP - H&R SPRINGS
19Ē 666m WHEELS - HANKOOK VENTUS V12 EVO 2ís
