CristianL1 CristianL1 is offline
Car: 2011 335is
Default JB4 app giving me wrong lpfp reading. - 09-14-2019, 08:39 PM
So after installing new fuel pump & new fuel pressure sensor. JB4 app is still giving me a fuel pressure of 65 at idle. So I decided to use pro tool from bimmergeeks to read my lpfp pressure & at idle with jb4 on map 0 itís a steady 72psi. What could cause my JB4 app to not read my fuel pressure correctly? Logs all look good now with the new pump & sensor but confused why the reading is different compared to other app.
Thank you!
Default 09-15-2019, 09:57 AM
Log?
Usually it’s pretty accurate, could be a tired EKP
http://www.fuel-it.biz/
e92 AT 335xi 2.0
Doc Race Kit 6062
Stephtech's Avatar
Stephtech Stephtech is offline
Car: 335xi 2010 E90
Default 09-15-2019, 06:58 PM
Originally Posted by CristianL1
So after installing new fuel pump & new fuel pressure sensor. JB4 app is still giving me a fuel pressure of 65 at idle. So I decided to use pro tool from bimmergeeks to read my lpfp pressure & at idle with jb4 on map 0 it’s a steady 72psi. What could cause my JB4 app to not read my fuel pressure correctly? Logs all look good now with the new pump & sensor but confused why the reading is different compared to other app.
Thank you!
I am just trying to troubleshoot the EXACT same issue...
I have a spare EKPM3 module running the exact same ZB number 7276383) and tried replacing it with the exact same results.
I am running a trebila custom bef with firmware 32.14.
INPA show a steady 5000hpa (which is 72.5psi), see attached image, JB4 logging at idle shows 65. If I manually kick in my second pump, I see the JB4 log going straight to a stable 77psi (5900hpa=86psi) which is the maximum the lpfp sensor is reading. The fact that the pressure is getting maxed out point out a fuel pressure regulator that I will take care but the fact is that the value of 65 in the jb4 is a live value, just wrong. The HPFP value is right on though.
anybody else noticed the same behavior?
2010 E90 335XI 6AT with XPH stage 3 | JB4 G5 W/Trebila Tune | RB Next Gen+ | RB hot side INLETs | VRSF high flow OUTLETS | custom Stage 3 LPFP | ETS FMIC | MODDED VRSF CP | TIAL Q | BMS METH KIT CM10+CM5 | MMP Port Injection Gen2 | AR DESIGN cer. downP | BMS/MITSH OCC's | RB external PCV w/plugged HEAD | Best 1/4: 11.47@123mph
Car: 2011 335is
Default 09-15-2019, 07:52 PM
I also switched ekpm3 already and with the exact zb number that came with my car. Here is my log everything looks good from what I can tell. My only concern is that the pressure on the app is false compared to what I get from the other app.
Stephtech's Avatar
Car: 335xi 2010 E90
Default 09-17-2019, 07:40 PM
Even with Bavarian Technic the lpfp value is right on.
I suspect that when some condition are not met, the jb4 does not display the correct value, like when in park, or below certain rpm...because I have seen values in the 72's in my logs.
Stephtech's Avatar
Car: 335xi 2010 E90
Default 09-20-2019, 08:06 PM
bump for an update
have an inconsistent issue with lpfp pressure and need to know why I got an offset on the JB4 versus actual pressure to figure out the real pressure I have
Default 09-23-2019, 06:08 AM
That’s odd- haven’t heard of this issue often with the app.
Let me get with terry / mobile
e92 AT 335xi 2.0
Doc Race Kit 6062
Stephtech's Avatar
Car: 335xi 2010 E90
Default 09-24-2019, 07:35 PM
Thatís odd- havenít heard of this issue often with the app.
Any news on this?
Could it be related to a custom BEF (Trebila) reporting LPFP differently? I could try with the standard BMS BEF if it is worthed
In my case, I am using the JB4 interface with a windows laptop, not a phone with a JB4 app.
Default 09-25-2019, 11:25 AM
Originally Posted by Stephtech
Any news on this?
Might be worth a switch to rule that out- didn't realize you weren't running one of our OTS maps
e92 AT 335xi 2.0
Doc Race Kit 6062
Stephtech's Avatar
Car: 335xi 2010 E90
Default 09-25-2019, 02:50 PM
ok will try with BMS bef
Car: 2011 335is
Default 09-26-2019, 03:23 PM
Iím running a BMS BEF with jb4 app & itís giving me those false readings.
Default 09-26-2019, 06:05 PM
Have you verified?
What are you getting @ WOT?
e92 AT 335xi 2.0
Doc Race Kit 6062
Car: 2011 335is
Default 09-26-2019, 08:18 PM
Have you verified?
65 at idle and up to 74 at WOT according to jb4 log. You can see log on my earlier post. With pro tool & jb4 at map 0 I get 72 at idle & i seen around 76 accelerating. But I have not logged a WOT since i would need to buy the mhd log license.
Stephtech's Avatar
Car: 335xi 2010 E90
Default 09-26-2019, 09:20 PM
Well, just the fact that at idle the pressure reported does not match what other software reports seems kinda strange.
I have noticed the following: I have the car already idling, I then start the jb4 interface software and connect to car. If watching closely at the lpfp value (in the bottom box), the value is displayed within maybe a second but it is enough time to see the value climbing. ex: 0, 16, 43, 65.
This behavior is strange as this value should be displayed unmanipulated from the DME, so that should be straight to 72 (65 in this case)
Car: 2011 335is
Default 09-27-2019, 12:16 PM
I do too stephtech when i start it up after having the car idle. I find it even more strange that we both get 65 psi.
