SEAN_13@MSN.COM SEAN_13@MSN.COM is offline
Car: 08 E92
Default marc's logs - 09-14-2019, 02:45 PM
over boost logs
Default 09-16-2019, 11:42 AM
Mods and fuel used?
Car: 08 E92
Default 09-16-2019, 01:29 PM
Tuner catted down ***** mmp 1K turbos stage2 lpfp afe I take vrsf 5 inch hd intercooler charge pipe with hks blow off valve muffler delete on my factory exhaust running e50 nvm it ne stage colder plugs
Car: 08 E92
Default 09-16-2019, 02:11 PM
And a custom back end flash
Default 09-16-2019, 10:01 PM
Few things before we get going:
Enable 6cyl timing under user adjustments tab
Map 4 = stock that won’t tell us much.
Lets see 1-2 map1 logs- 2k to redline, WOT, traction off
http://www.fuel-it.biz/
e92 AT 335xi 2.0
Doc Race Kit 6062
Car: 08 E92
Default 09-17-2019, 06:39 AM
It kicked into map 4 on that morning I’m running map 6 terry from BMS Told me to change fud bit 6 to disable I’ll add some more logs tonight I’m running map 6 haven’t did any logs after changing bit6
Default 09-18-2019, 06:45 AM
Originally Posted by SEAN_13@MSN.COM
It kicked into map 4 on that morning Iím running map 6 terry from BMS Told me to change fud bit 6 to disable Iíll add some more logs tonight Iím running map 6 havenít did any logs after changing bit6
e92 AT 335xi 2.0
Doc Race Kit 6062
