trb1 trb1 is offline
Car: 2009 e90 335i
Default Lean AFR both banks even on safety map - 09-12-2019, 06:21 PM
Hi guys, new to forum.
Picked up a FBO 93 + meth 09 335i running an MHD backend flash with JB4. Car ran great for a week and now it has increasingly become more lean in boost (both banks). It now will not even stay on map 3 for a full pull. It just kicks right to the safety map.
not an issue with the meth system as it's still running lean at 8 psi on the safety map.
No knock or lean codes, runs and feels great, no misfires or anything.
I have occasionally gotten these two codes. sometimes they'll pop up, other times they won't.
2C32 Lambda probe in front of catalytic converter 2, trimming control and a 2C7B lambda probe behind catalytic converter 2, signal
I'm assuming that it's probably just o2 sensors on their way out and the JB4 kicks it into low boost because AFR looks lean, but I am new to a DI car and wanted to make sure my lpfp (walbro 450) and hpfp numbers were okay as well.
Attached is a log of WOT on map 4. Don't dare go back into map 3 with weird AFR issues. Thanks for any input.
Tom
Car: 2009 e90 335i
Default 09-12-2019, 06:24 PM
Forgot to attach file.. here it is.
Car: 2009 e90 335i
Default 09-13-2019, 06:28 PM
Bump. Any ideas? Increased FOL by 10 and afr is mid 12s now on map 3. Cruising AFR is still pretty all over the place.
Car: 2009 e90 335i
Default 09-15-2019, 02:36 PM
Anyone?
Default 09-15-2019, 09:48 PM
Your throwing safety 4 = meth flow low
http://www.fuel-it.biz/
e92 AT 335xi 2.0
Doc Race Kit 6062
Car: 2009 e90 335i
Default 09-16-2019, 03:49 AM
Even with AFR all over the place while cruising, and a lean afr on the safety map?.... flow gauge looks good. I’m spraying meth.
Default 09-16-2019, 01:10 PM
Try an 02 reset first monitor the AFR on both banks after for next day or so.
e92 AT 335xi 2.0
Doc Race Kit 6062
Car: 2009 e90 335i
Default 09-22-2019, 09:25 AM
It was definitely an issue with the rear o2s. Any idea why the jb4 app shows the code 2c7b as bank 2 when it’s actually the bank 1 rear sensor?
Default 09-23-2019, 07:34 AM
It shouldn’t be doing that- did you fix the sensor, all good now?
e92 AT 335xi 2.0
Doc Race Kit 6062
Car: 2009 e90 335i
Default 09-23-2019, 08:08 AM
Looks to be that way. Ended up replacing both. Just have ******* ** codes now. Weird that I had a bank 2 trimming hex code but a bank 1 signal code that said it was bank 2...
Default 09-23-2019, 02:00 PM
Very odd
Please keep me posted on that as you drive more.
e92 AT 335xi 2.0
Doc Race Kit 6062
Car: 2009 e90 335i
Default 09-23-2019, 05:00 PM
[U][U]Here’s an updated log and a screenshot of stored codes I was dealing with. No more o2 codes for the last 2 days besides 29F4/29F5.
No more variation in AFR between banks. How does this one look? Map 3 2k-7k wot in 3rd gear.
Default 09-23-2019, 10:50 PM
From what I can see this looks clean
You’ll want to enable 6 cyl timing for future logs
e92 AT 335xi 2.0
Doc Race Kit 6062
