JTe60 JTe60 is offline
Car: 2010 535i 6spd m-pkg
Default Newbie needs help - 09-12-2019, 05:12 PM
2010 535i. Stock stock 6spd 121k 70k ish new turbos. 102knew injectors 106knee hpfp,LPFP,filter and ekpm. only issue was *** efficiency code but pulled strong
Just picked up this JB4(used w/2step). Install went straight forward and tried to set everything I could through steering wheel controls back to default but couldnít get app to work. That has been fixed so can now log and get to the rest of the settings. I feel only setting I needed to change and couldnít was for an N20 sensor that I have now reset back to 0. Have only ran map 0 and 4. Now Iím hitting 9 psi or so around 3k then loosing all boost and throwing codes from boost leak to ******* D.P.s detected.... wouldnít be surprised if it is one and I will start hunting but being new to JB4 figured I would see if Iím missing a stupid setting and other info needed will be glad to provide
Thanks to any and all in advance
Default 09-13-2019, 11:42 AM
doesnt look like you are running the correct firmware...
See post 1
E Series N54 JB4 - N54Tech.com - International Turbo Racing Discussion
http://www.fuel-it.biz/
e92 AT 335xi 2.0
Doc Race Kit 6062
Default 09-13-2019, 06:48 PM
Just want to say thanks... 100% my issue. Had that in the plans but was struggling with time and how to accomplish through app, got it figured out and completely seems good to go.
Default 09-15-2019, 09:49 PM
e92 AT 335xi 2.0
Doc Race Kit 6062
