HKD126 HKD126 is offline
Car: 2014 335i
Default 29F3 code after removing ** fix - 09-10-2019, 09:43 AM
I just purchased a 2009 335xi that was nicely modded. After the first day of ownership I started getting 02 codes and discovered that the JB4 had a ** fix installed on it. After removing the D P fix and installing the new harness wires today, I started to get a 29F3 code - Faulty Low Fuel Pressure Sensor.
Is the car fine to drive with this code and in this state?
My current fuel pump is also a bit weak and will be replacing with a new Fuel It Stage 2 bucketless pump. Could the D P fix have been masking this new code? Do I just need a new LPFP or both a sensor and a pump? If I get a new sensor is there any reason to get the new sensor with the updated fuel line or will just a replacement old style sensor be fine? Either one I get will be replaced with genuine BMW parts.
Thanks.
Default 09-11-2019, 10:30 AM
We'd need to see logs.
But the fix has 0 correlation w. the lpfp sensor
http://www.fuel-it.biz/
e92 AT 335xi 2.0
Doc Race Kit 6062
Car: 2014 335i
Default 09-11-2019, 11:07 AM
Here are some map 2 logs. Codes are all gone now... Not sure what that was all about.
Default 09-12-2019, 01:04 PM
n54 life haha.
FF looks to be maxed out and boost looks to be very laggy- You might have a leak somewhere in the system
e92 AT 335xi 2.0
Doc Race Kit 6062
Car: 2014 335i
Default 09-12-2019, 01:42 PM
n54 life haha.
Could it be old vanos solenoids as well? I cannot find a leak.
Default 09-15-2019, 10:16 PM
Ehhh, maybe? Boost solenoids seem a little more likely.
Did you pressure test the system or just eye ball it?
e92 AT 335xi 2.0
Doc Race Kit 6062
