Williamsoc21 Williamsoc21 is offline
Car: 2008 335i
Default After firmware update getting code 30FE - 09-09-2019, 04:27 PM
As the title says. I up dated my jb4 for the first ever. I followed the Instructions or so I thought. Made sure menu 4 was set to 2 (got backend tune) all the duty bias was set to zero and boost In third gear set to zero. Updated without any errors or issues. Did a test drive and the first time I got on it, it started to build boost then it just fall flat. No codes popped. Did it a few more times and same results. I was in map 6. I changed it to map 2 and went full throttle. Same issues. But this time codes popped up 30fe and 3100 and car we into limp mode. Kept it in map 2 but I changed the base duty cycle from 2800 to 2400 hoping that would fix but I got the same results. I reset everything and this time I turned off the jb4. Went full throttle. No issues. What am I missing here? Do i have change any settings in my tune.
Here's my log. I got off it once when the boost fall off
Default 09-09-2019, 09:06 PM
Don’t see any wot in this log?
One thing to note set your fuel bias all to 0
Duty bias you can adjust to 50 across the board
Turn off traction control & lets log map 1, 3rd gear 2k to redline
http://www.fuel-it.biz/
e92 AT 335xi 2.0
Doc Race Kit 6062
Car: 2008 335i
Default 09-09-2019, 09:30 PM
Donít see any wot in this log?
Thank you so much for responding. Iíll adjust those setting tomorrow. So I did another log tonight in map 2 this time I held it in gear till I got close to redline. If you could take a look and let me know what you think.
Car: 2008 335i
Default 09-15-2019, 10:51 AM
Hereís two logs in map 1
Default 09-15-2019, 09:49 PM
You don’t go WOT in any of these logs
e92 AT 335xi 2.0
Doc Race Kit 6062
Car: 2008 335i
Default 09-16-2019, 05:08 AM
You donít go WOT in any of these logs
Thatís crazy lol because I was going WOT or so I thought. My pedal position is at 94 (I got a little stopper on the gas pedal to stop the kick down from happening). I would think the throttle would be matching that. And if you look at my previous logs itís the same thing. Could that be my issue?
Default 09-16-2019, 01:05 PM
Is the stopper homemade? If yes, remove- and reflash your BEF via MHD and check disable kickdown in the options menu b4 flashing.
e92 AT 335xi 2.0
Doc Race Kit 6062
Car: 2008 335i
Default 09-16-2019, 02:01 PM
No I bought the stopper at Walmart. Itís just little pad you put under future. Iíve had it forever. Never ran into any issues with it before. I got my BEF from bimmerboost.
Default 09-16-2019, 09:58 PM
So yes, homemade, lol- not specíd specifically to stop kickdown / 100% pedal.
Did you flash the bef via mhd?
e92 AT 335xi 2.0
Doc Race Kit 6062
