skrillah416 skrillah416 is offline
FBO Minus FMIC
Car: E60 535xi
Default Please help n54 stage 3 MMP turbos - 09-09-2019, 06:48 AM
Hey new to the forum and the JB4 community. I have few issues Iím running into and could use the help. Iíve recently done a engine rebuild, ported and lapped valves. Stage 3 MMP Turbos, VRSF FBO just missing a FMIC, Precision race works stage 2 fuel pump. After the fuel pump install Iím not getting a message on the idrive saying service fuel pump continued driving is possible or somthing like that but I donít feel a loss is power or anything. Anyone know what it could be ? Also now I successfully installed the jb4 the other night and now when running on map 2. Not full WOT but getting there (because the engine rebuild is only 1400km in) it throws the four ways twice and switches me to map 4. Not sure if thats the loggs needed but thats what ive got so far lol.
2010 E60 535xi
FBO Minus FMIC
PRW Stage 2 Fuel pump
VRSF High Flow Cats
MMP Stage 3 Turbos
Fresh Engine Rebuild as well as All new Parts Listed above.
Default 09-09-2019, 03:15 PM
Going into map 4 due to bank 1 being extremely lean.
You need to load the hybrid BEF & follow our default settings. Link : N54 BimmerBoost MHD Back End Flash Maps - N54Tech.com - International Turbo Racing Discussion
Relog Map 1 after
http://www.fuel-it.biz/
e92 AT 335xi 2.0
Doc Race Kit 6062
FBO Minus FMIC
Car: E60 535xi
Default 09-12-2019, 01:07 PM
Relog Map 1 after
Hey sorry im still learning my way around the forum and JB4 its self.
which of the map Releases do i download and then which one is the file i need ? that has the upgraded hybird turbos. Thanks!
2010 E60 535xi
FBO Minus FMIC
VRSF High Flow Cats
MMP Stage 3 Turbos
Default 09-12-2019, 01:17 PM
Just click our most recent map releases then select the appropriate hybird map
Remember to update your firmware too.
e92 AT 335xi 2.0
Doc Race Kit 6062
FBO Minus FMIC
Car: E60 535xi
Default 09-12-2019, 05:50 PM
Hey they all have e85 as fuel options when I look at them all but I put 91? Lol and Iím from Canada what should I do ?
2010 E60 535xi
FBO Minus FMIC
VRSF High Flow Cats
MMP Stage 3 Turbos
FBO Minus FMIC
Car: E60 535xi
Default 09-12-2019, 08:56 PM
Hey so i flashed the JB4_IJE0S_PUMP.bin and did the whole 4/2, 0/1 and was trying to log 3ed wot but on the jb4 program on my laptop it looked like it wouldnt start logging untill it went into the safe mode (map 4) ive got a few logs here if you can take a look and maybe it did log it. i then have one from a launch point where i think it logged it but not sure if it went into safe mode.
Thanks for the time and help put in!!
2010 E60 535xi
FBO Minus FMIC
VRSF High Flow Cats
MMP Stage 3 Turbos
FBO Minus FMIC
Car: E60 535xi
Default 09-12-2019, 09:21 PM
should i try another pump flash or maybe race flash ?
2010 E60 535xi
FBO Minus FMIC
VRSF High Flow Cats
MMP Stage 3 Turbos
Default 09-15-2019, 11:07 AM
Your trims are staying pegged @ 25- open loop.
Throwing safety 2 - AFR LEAN.
your running the right flash- based on your bank 1 AFR, you may have an o2 sensor issue- you throwing any codes?
e92 AT 335xi 2.0
Doc Race Kit 6062
FBO Minus FMIC
Car: E60 535xi
Default 09-15-2019, 02:57 PM
Hey. I believe I need an o2. I will be scanning it once I get home to give an update on codes. I have high flow kittieless kitties if that makes a difference but one of them we had to crush and bend to make fitment possible so the air flow is different from the other one.
2010 E60 535xi
FBO Minus FMIC
VRSF High Flow Cats
MMP Stage 3 Turbos
FBO Minus FMIC
Car: E60 535xi
Default 09-16-2019, 05:16 AM
Iíve got 2 codes showing up 2c9c and 2c32
2010 E60 535xi
FBO Minus FMIC
VRSF High Flow Cats
MMP Stage 3 Turbos
Default 09-16-2019, 12:42 PM
I'd replace the sensor & report back.
e92 AT 335xi 2.0
Doc Race Kit 6062
