Boss86 Boss86 is offline
Car: 2007 Bmw 335i
Default New pure 600ís - 08-04-2019, 10:01 PM
So whoís running the new pure 600ís? How do you like them? How do they stack up against the pure stage 2ís? How much power are you making, and how much boost? Iím very interested in these and canít find much about them. Iím sure someone here has them.
fazman fazman is offline
Car: e90 FBO
Default 08-11-2019, 12:41 PM
I am interested as well, unless Pure would like me to be the first to give a review?
lucas lucas is offline
Car: 135I
Default 08-15-2019, 02:36 PM
Hello, sorry but I use a translator, I am from Argentina, recently on my E90 fbo 95 octanes + meth install my ps2Hf and it really is another very strong and powerful car, currently 24 psi, I still did not go to the test bench but do not hesitate to buy them. The attention of the people of Pure is excellent!
Car: 2007 Bmw 335i
Default 08-15-2019, 03:40 PM
So the new 600ís are basically like the ps2ís right? But probably the DD? Iíve also seen theyíre rated 600-700 hp. 🤔 thatís actually pretty good considering the price.
Car: 135I
Default 08-15-2019, 03:53 PM
The ps2 is 450 to 600 and the ps2HF 600 to 700, for the little price difference would go for the HF, the total power in hp will also depend on the fuel you use, I do not have E85 at my reach and I do not think reach much more than 600 hp.
Car: 2007 Bmw 335i
Default 08-15-2019, 04:05 PM
I have e85 where I am. Iíd like to hit the 600hp mark. Iím already running the stage 2 lpfp(bucket version) 1 step colder ngk plugs, vrsf 7Ē hd fmic, dciís, **, cp w/bov. Iím also mhd/jb4 custom e60 tune. Stage 3 xhp trans tune with custom settings I also have inlets too.
Car: 135I
Default 08-15-2019, 05:30 PM
Yes, we have both similar hardware and preparation, you with E85 and ps2HF will surely exceed 600 whp.
Car: 2007 Bmw 335i
Default 08-15-2019, 06:53 PM
I donít have the ps2 high flows, Iím gonna get the new pure 600ís with the 2Ē inlets. N54 tuning is saying the turbos are rated at 600-700hp not sure how true that is but I figure 550whp is good for a dd
DBShiznit DBShiznit is offline
Car: 2008 BMW 135i
Default 08-28-2019, 04:22 AM
No one has any new info on these? Pretty close to pulling the trigger on a set.. I might just have to do a review myself at this point once they are installed.
Car: 135I
Default 08-28-2019, 04:42 AM
that log is with ps2 hf with the configuration and hardware similar to your car, as in the other messages I told you
Car: 2008 BMW 135i
Default 08-28-2019, 04:50 AM
You were running at ~24 lbs boost. I think the cast pure 600s could run at the same boost. I heard online not to run it more than 26 lbs. When I spoke with a rep at Pure Turbos he told the cast are like the DD ones but literally just cast. Can the HF turbos go up any higher on boost? Seems like you're running on a conservative boost level? Trying to learn from you guys on this lol
Also when you installed these was it on a 135i? I know for the e82 series I have to use two hoses from the 335i lhd but am not sure which one so if you have any info on those hoses it'd be awesome!
Car: 135I
Default 08-28-2019, 05:07 AM
I do not have that information but people of pure will know how to tell you, my car is a 335i e90, it can be up to 32 psi but I can not more than 26/27 by the octane
THE BEAST's Avatar
Car: 2008 E93
Default 08-28-2019, 10:02 AM
I hear this from quite a few people. Choice of turbos should be based on actual goals, fuel available to accomplish those goals, hardware, upgrades, axles, trans, etc. Bigger isnt always better. If someone has a goal of 550, the extra headroom of purchasing 700whp capable turbos is over kill and the headroom left on 600s is plenty. What if you are auto trans ? 700 whp and destroy the trans before you even get to enjoy the full power is POINTLESS. Generally speaking, the more power a turbo can make, the more lag that is also introduced. Look around and check 1/4 mile times from stock to 700whp hybrids. Trap definitely increases, but E.T. in many cases (not all), barely changes. So once again, depends on goals. 1/4mile ? Driveability ? Trap speed ? Roll race ? 1/2 mile runs ? Dig runs ? Go buy 700whp twins and run a car with RBs at 525whp from ligh to light on the street and see what happens. By the time the 700s kick in, the race is already over. Longer freeway run and the opposite will happen. Goals......not bigger is better IMO.
Car: 2008 BMW 135i
Default 08-30-2019, 05:13 AM
I thought about this too. Everyone is telling me to go single turbo but I want a well rounded car and went with bigger twin turbos(Pure600) for the least amount of lag and good power. Should be a fun easy to drive car. The thing I liked most about stock turbos was when I hit the gas boost was instant. To me nothing beats that.
THE BEAST's Avatar
Car: 2008 E93
Default 08-30-2019, 08:06 AM
Exactly right......Not everyone wants or needs 750whp plus. A LOT of guys who run time attack are actually around 500whp or so (335i) Take streets of willow track for example. A single turbo 750whp car will fall WAY behind a track tuned 500whp car. These things have to be taken into consideration. The goals and intentions that people have for their cars, not just bigger is better !
AJoosten AJoosten is offline
Default 08-31-2019, 10:05 AM
I recently installed pure stg 2 high flows on my 135i. When dialing in the tuning they were over shooting to 30psi so you will not have an issue building boost with these. Have only done about 4 hours of track time but they seem to be going strong so far. I am having issues keeping my charge pipe on at 25 psi when stuff starts to get hot. Trying to come up with a better than one connections right now. Anything me have any thoughts?
09 135i N54|JB4 G5|BMS PI Cont|BEF Hybrid PI E85|Pure Stage 2 Hi-Flow Turbos|NGK 97506|Fuel 85% Ethanol|BM-Parts PI 750cc|Dual Walbro 450LPFP Bucket|Ethanol Sensor|3/8" Fuel Line|Stett Dual Oil Cooler|VRSF Relo Inlets|Active Autoworks7" FMIC|VRSF CP|HKS SSQ BOV|Agency Down & Mids|BMS Cowl Filter|MFactory LSD|JE Piston Heads|SPEC STG 3 Spr 6|ACT Pressure Plate|SPEC Single Mass Alum Flywheel|COBB Sway Bars|Ohlins Coilover 400/600|CAR BLOG
Default 08-31-2019, 10:08 AM
Zip ties don’t work. They made it about 25min at track temps :p
THE BEAST's Avatar
Car: 2008 E93
Default 09-01-2019, 03:09 PM
Originally Posted by AJoosten
Zip ties donít work. They made it about 25min at track temps :p
Have you tried a new clip ? Or maybe just a charge pipe issue ?
Default 09-01-2019, 10:32 PM
I fixed it with some metal plates, m6x120mm all thread, and some lock nuts.
THE BEAST's Avatar
Car: 2008 E93
Default 09-01-2019, 11:13 PM
Car: 2008 BMW 135i
Default 09-12-2019, 11:45 AM
So no one has any new info on the Pure600s? They just arrived at home so when I get off work I'll be unboxing them.
Stall Master Stall Master is offline
Car: BMW 135i
Default 09-12-2019, 03:56 PM
Ok 😂
codesx's Avatar
codesx codesx is offline
Default 09-13-2019, 10:20 AM
Intense.
I suspect the TB groves have rounded a bit, and thus are susceptible allowing the 'c-clip' to expand when pulled (pushed by boost) on. If the edges the of the TB aren't square, sslliipp. If they are, almost any boost shouldn't matter.
That said, very ingenious!
RB: Inlets | PCV Valve
VRSF: DiPis | CP
HKS BOV
xHP Stage 3
NGK-97506 @ .020
Maintenance:
Car: 2008 BMW 135i
Default 09-24-2019, 05:02 AM
What website do you guys use for photo sharing? Last time I frequently used the forums Photobucket was still a thing
nyt nyt is offline
Car: 335ix
Default 09-24-2019, 10:12 AM
imgur
2010 335ix - speedtech 6466g2, cams, ported head, built bottom end, 7.5in hd ic, jb4, pi, fuel-it stg3, upgraded 6hp21+cooler, pr coils
