E30 Racer E30 Racer is offline
Car: 1M
Default 03-22-2019, 05:44 PM
In my case (1M), the wires leading to the evap valve became a bit stressed due to the BOV adapter shifting everything a few inches towards the firewall. Payam was really helpful in resolving this...ultimately I ended up making an extension using some *short* Bosch EV1 connectors.
Comparison of a few EV1 style connectors. Use of the short ones is important, the extra 1/8” keeps the evap connector wires from rubbing against the firewall.
Default 03-22-2019, 05:49 PM
As there was some confusion on the line size put together a quick video here to clarify it:
lightning lightning is offline
Car: BMW 1M Coupe
Default 08-31-2019, 12:18 PM
Hi Terry would you mind doing up installation instructions for this?
Default 09-04-2019, 11:15 AM
Really straight forward.
Remove the brake booster line that goes onto the throttle body.
Lube Orings in the BOV adapter, install onto throttle body and insert E clip to lock into place. Re attache brake booster line to the BOV adapter and you're done.
Car: BMW 1M Coupe
Default 09-11-2019, 08:37 AM
Thank you so much Payam! will get to work immediately over the weekend. btw, how does this boost reference for BOV improve performance? I would like to understand more
Default 09-11-2019, 01:41 PM
It improves the vacuum and boost going to the BOV with the larger diameter barb. You will have less flutter with this in place. It also has a second port for boost gauge, hobb switch, or OCC kit, etc...
Car: BMW 1M Coupe
Default 09-13-2019, 12:18 AM
Thanks Payam! hmm.. does flutter take hp away?
Default 09-13-2019, 09:05 AM
No but makes compressor surge more likely. Overall, a better vacuum adapter for the BOV is optional but worth the minor cost IMHO.
Rule77's Avatar
Rule77 Rule77 is offline
Car: 08 E90 335i
Default 09-13-2019, 09:13 AM
Is flutter at lower rpms normal?
08 E90 335i
Montego Blue
JB4/MHD E85 BEF
BMS DCI
BMS OCC
BMS Cowl Filters
VRSF ⬇️ Pís
MMP Chargepipe
TIAL BOV
BMS Pedal Tuner
BMS PCV VALVE
NGK 97506 @ .022
STAGE 2 LPFP
H&R Springs
19' 666m Wheels
Pinscher Pinscher is offline
Car: 08' 335i
Default 09-24-2019, 04:09 PM
Is it still possible to get this for 59.99?
Website shows 70
Default 09-25-2019, 10:22 AM
Website shows 70
You can go for the basic kit:
$50 for the basic kit
$70 is for the full kit with the push lock fittings.
https://www.burgertuning.com/product...18162484543603
