crash1622 crash1622 is offline
Car: mini cooper s f56
Default Black flex fuel wires on JB4 mini F56 B48 - 10-25-2018, 07:22 AM
Hello Guys,
I bought the flex fuel wires like a year ago and now Im trying to install them on my JB4. I read the B48 FF connector must be 2 wires - green and black (green wire goes in #21, black wire goes in #4 into DB25) but the one I have has 2 black wires - one stripped and the other with a gold pin.
Do you know if I can use this FF connector on my JB4 maybe welding a gold pin in the stripped wire?
Attached some pictures of my setup.
Default 10-25-2018, 06:06 PM
You'll need a DSUB pin for the unstripped wire. The male connector goes to #21, sensor side female contact attaches to #4.
Default 10-26-2018, 10:43 AM
Terry, thanks for your response.
Do I need to update some setting on the JB4 from the desktop app after installing the FF wires?
With the FF wires and ethanol (15% ethanol / 85% 93 oct gas) I can run map 2 safely, right?
Default 10-27-2018, 09:46 PM
Open loop = 50, should be OK on map2 but log it. Worst case, may need more E85.
