(#51)
Default 12-24-2018, 10:41 AM
Yes good gains even on 91. We'll post some 91 and 93 octane numbers when time permits.
boosteddub69 boosteddub69 is offline
Car: AMG C63
Default 12-24-2018, 11:10 AM
Many thanks sir, looking forward to seeing the numbers on pump gas. I'm still waiting for my car to come in but this is high on my list of things to waste money on when I get it.
shidayuan shidayuan is offline
Car: 435i
Default 12-24-2018, 01:58 PM
Hi Terry, My car already had the BEF. Could the jb4 work with the tune?I don't the see the custom map for this jb4.
2014 435I xdrive EWG , JB4, Meth kit(cm10), ER CP, ER ca tl ess **, Stock tubo
Default 12-24-2018, 03:00 PM
Yes, log map0 to start, email it in, and I can help you with the details.
notabenex notabenex is offline
Car: MB W205 C250
Default 12-24-2018, 09:32 PM
Terry I am using only 98+ octane pump gas here in EU, usually 99.5octane when they do the testing. Can I expect results like you posted in first picture? How about ethanol mixture?
Mr.Pink Mr.Pink is offline
Default 12-25-2018, 12:03 AM
Since it's already flashed for starters just send us a JB4 log on map0 so we can see how the flash it setup, determine if there is more power to be had there for you, adjust the boost by gear, etc.
There should be a good bit of power to be had on these pure turbos �� I'll get it in as soon as I get it and shoot you over a log on map 0
Have an awesome holiday!
spikiii's Avatar
spikiii spikiii is offline
JB4 addict
Car: powered by JB4
Default 12-26-2018, 09:34 PM
@Terry @Payam @Jon @Christine - OMG OMG they arrived!!!!
going to have fun this weekend installing it hopefully.
Default 12-27-2018, 04:14 PM
First verified install here! :
Will have some logs here shortly! Thank you guys especially Jon for all the support he gave me during install
Car: MB W205 C250
Default 12-27-2018, 08:29 PM
Wow thats great. Keep us updated.
Gbango Gbango is offline
Car: 16' C63s
Default 12-31-2018, 01:05 PM
Have the JB4 installed, but having some issues. Car will drive relatively fine, but will shut start running rough, cuts power and will turn off at a stop. It's not really drive able at this point.. **note- this happens on the only maps I've tried (map 0, map 1, map 2 and map 3).
Default 12-31-2018, 08:59 PM
Sounds like a possible OBDII cable issue. As a first step try unplugging OBDII all together to see what effect it has. Also, emailing in for tech support will be much faster than posting here and waiting for one of us to see the thread.
As a reminder you should only be using map1 for now. And you can read codes via the JB4 app as well as record a log, to post to this thread, or email in.
Default 01-02-2019, 09:15 PM
Keep the map1 JB4 logs rolling in!
Default 01-03-2019, 03:32 PM
Found an issue with some of the C63 BETA systems shipped. There is a resistor on the JB4 control board that needs to be soldered over. If it's not, you may get a check engine light, mismatched bank to bank fuel trims when looking at JB4 logs, etc.
Photo attached to identify the issue. There should be a wire soldered across the resistor as shown.
If you're missing the wire then we've got the following options for you:
1) Leave the fuel pressure connections stock for now, leaving the rest of the JB4 plugs attached. Fortunately they are relatively easy to reach connections.
2) Email me @ terry@burgertuning.com and I can send you a replacement JB4 control board which attaches to the JB4 harness.
3) If you're handy with a soldering iron you can add the missing wire yourself.
Car: MB W205 C250
Default 01-04-2019, 11:39 PM
Any results, feelings, logs from actual users? I will be doing my install next weekend so any tips appreciated
zipzap zipzap is offline
Car: C63s
Default MAP 0 log - 01-07-2019, 01:57 AM
Here is a quick run I made on my C63s , im running a flash tune so the boost and timing you see are not for a stock car.
Nasir.alshehhi Nasir.alshehhi is offline
Car: BMW
Default 01-07-2019, 04:43 AM
If you can provide us with a longer log WOT in 2,3,4th gear that would be much appreciated , the log you provided is too short.
Default 01-07-2019, 09:35 AM
Need to read 2 posts above yours and follow that.
N54Tech.com - International Turbo Racing Discussion - View Single Post - Mercedes AMG C63 C63S JB4
Car: C63s
Default 01-09-2019, 03:55 AM
Hi Payam
The unit has been uninstalled for some time as Iím waiting for my warranty replacement. Terry was great and he noticed the trim imbalance straight away and got me a replacement unit fedexed within a day , still waiting for it to clear customs unfortunately as nothing happens quickly in Africa !
Fame Douglas Fame Douglas is offline
Car: 2018 C63
Default 01-10-2019, 04:37 AM
My JB4 is up and running with the updated board.
I only tested it a little bit with map 1. It feels fine, it’s hard to tell a difference since there’s no traction.
Is it OK to test maps 2, 3 and 5 if I throw in a tank of 100 octane gas?
Car: 16' C63s
Default 01-11-2019, 07:19 AM
I only tested it a little bit with map 1. It feels fine, itís hard to tell a difference since thereís no traction.
Same here. All running fine for me now with the replacement board as of right now. Will start doing some logs. How long before we can start trying out the other maps? Have some Torco and race gas in the garage waiting to be used. Also, any ETA on the intake release?
As a side note, Terry has provided excellent support so far and quickly sent out a replacement board.
Car: 2018 C63
Default 01-11-2019, 07:40 AM
I noticed that my JB4 doesn’t detect what gear I’m in. Shouldn’t that be working for boost by gear?
Default 01-11-2019, 09:23 AM
Send us a log to evaluate first in a lower map before going higher.
Try to get a log at higher speed so you won't have traction issues
Dat1racingchannel's Avatar
Dat1racingchannel Dat1racingchannel is offline
Car: AMG GTS
Default 01-12-2019, 10:00 PM
Hello Terry I just received my JB4 today, I drive a Pure stage 1 AMG GTS with eurocharged tune and ********* with custom intakes and methanol kit and wisetec blow off valves. The car dynoed at 650 whp and 700 tq on Pump gas 93. Hopefully with the JB4 I can gain another 50+ whp. Any updates on BCM on when it will be available?
Default 01-13-2019, 06:02 PM
Sounds good, let's get working on it. Email in a log on map0 to start!
spikiii's Avatar
JB4 addict
Car: powered by JB4
Default 01-19-2019, 12:34 PM
Finally got the JB4 installed!! gotta shoutout to Jon@BMS for the help and guidance in getting to MAP #1 & 3
just wanted to confirm this bit:
Enter the amount of boost to reduce per gear. For example, entering 3psi in 1st will reduce 1st gear by 3psi regardless of the performance map selected. We suggest values of 4psi in 1st gear, and 2psi in 2nd gear, to start.
- reducing boost per gear, is entered in the app like this. (even though description says "max boost" rather than "reduce boost?")
**all other values have not been changed - will try get logs soonish
