DamnDatsun's Avatar
DamnDatsun DamnDatsun is offline
Car: 2010 135i msport
Default 01-03-2019, 02:27 PM
Eagerly awaiting this
dtran09 dtran09 is offline
Car: '08 335xi E92
Default 02-10-2019, 09:25 AM
Any updates? Thanks
Default 02-10-2019, 06:12 PM
Yes have the basics all worked out, got sidetracked with the N54 automatic launch mode.
Default 02-11-2019, 09:49 AM
It's been raining like crazy here so hopefully this week I'll be able to bring it by since I think it stopped for a few days?
Prototype007 Prototype007 is offline
Car: 2009 335i
Default 02-18-2019, 09:17 AM
Does the current Fuel-It analyzer that wires into the JB4 not play a role in modifying fueling when also running port injection?
I have the kit on my N54 along with the JB4, PI, and PI Controller, but do not have the system activated or the BEF for it since I'm busy chasing ghost with air temp issues.
2009 335i Automatic Coupe.
Default 02-18-2019, 09:33 AM
Yes it can, the JB4 can be set to scale port injection on E85 mixture. Technically speaking the way the MHD flex fuel works you can use their kit or the Fuel-IT kit. The fee is on the MHD side when you load the E85 integrated compatible flash. Still sorting out the details, weather around here is not cooperating!
Default 02-22-2019, 07:50 PM
Making some progress here, could use a few testers. If you have a flex fuel kit installed and want better integration via the MHD back end flash drop me an email.
Milan's Avatar
Milan Milan is offline
Car: 08 335xi
Default 02-24-2019, 08:00 PM
Which kit do we need? I've been waiting on you tell me what to buy. I can get the Fuel it kit or the Motiv one
09 335 - 6266
07 335i - 6870, E85 - SOLD
Default 02-24-2019, 08:27 PM
We're partial to the Fuel-IT kit. But either one works.
Technically speaking the analyzer sends in a 0-5v signal to the ECU relating to actual E85 mixture. And then the the JB4 reads this signal from the ECU and uses that to direct the tuning. MHD has ~$99 fee to unlock the new table blending which is automatically detected when you go to load the FLEX BEF and prompts you to buy a license for it.
Milan's Avatar
Car: 08 335xi
Default 02-25-2019, 01:10 PM
Thatís what I thought. So do we need motivís flex fuel box thing or does the JB4 replace that?
09 335 - 6266
Slewis336 Slewis336 is offline
Car: 08 335xi
Default 02-28-2019, 09:57 PM
Curious of this also. Iíd be willing to help test it out.
Stephtech's Avatar
Stephtech Stephtech is offline
Car: 335xi 2010 E90
Default 03-03-2019, 08:08 PM
@Terry did you found a way to enable the launch on N54? I could not find any message mentioning it yet
2010 E90 335XI 6AT with XPH stage 3 | JB4 G5 W/Trebila Tune | RB Next Gen+ | RB hot side INLETs | VRSF high flow OUTLETS | custom Stage 3 LPFP | ETS FMIC | MODDED VRSF CP | TIAL Q | BMS METH KIT CM10+CM5 | MMP Port Injection Gen2 | AR DESIGN cer. downP | BMS/MITSH OCC's | RB external PCV w/plugged HEAD | Best 1/4: 11.47@123mph
Milan's Avatar
Car: 08 335xi
Default 03-07-2019, 09:36 AM
I talked to Terry via email and learned that we can use Fuel-It's or Motiv's flex fuel unit. The JB4 will read E content from the DME.
I don't have either yet, but I am down to order one, kinda hoping someone else can confirm it works first.
09 335 - 6266
07murderedcoupe 07murderedcoupe is offline
Car: 07 345i
Default 03-24-2019, 12:44 AM
Any updates? Do I just do regular install of everything and which bef do we want to use with it? Plan is e50
Milan's Avatar
Car: 08 335xi
Default 03-28-2019, 08:55 AM
Is anyone testing this? I have the line and the sensor but not an analyzer yet. I think a lot of people would make use of this if there was just a little bit of documentation out there.
Edit: Ordered the analyzer from Motiv
09 335 - 6266
Car: 08 335xi
Default 04-10-2019, 05:53 AM
I have the fuel-it flex fuel kit and it’s hard wired into my JB4. Reads perfectly on my JB4 gauge. Where do I download the Flex Fuel BEF that allows interpolation?
Car: 08 335xi
Default 04-10-2019, 09:31 AM
I have the fuel-it flex fuel kit and itís hard wired into my JB4. Reads perfectly on my JB4 gauge. Where do I download the Flex Fuel BEF that allows interpolation?
I downloaded the latest BEF maps and it looks like the flex fuel is in all of the of the folders except the I8A0S?
Car: 2009 335i
Default 05-03-2019, 09:19 PM
Bumping this for updates
trebila's Avatar
trebila trebila is offline
Default 05-04-2019, 02:28 AM
Hi Terry
I have a JB4 customer with the Motiv Flex Fuel kit installed.
I've built a Flex fuel tune already, seems to work well, but he still have to adjust manually the fuel bias on the JB4, depending from the E content.
He's using the Motiv Ethanol Analyser, but the PI kit is still controlled by the BMS PI controller, not the SS one.
How can he wire the JB4 to the DME to read the E content from the Motiv analyser, so he won't have to adjust the fuel bias anymore, whatever the fuel he use ??
chronicvex chronicvex is offline
Car: 2008 335i
Default 05-05-2019, 05:37 PM
Hello Terry,
I didn't see where I could email you, but I have the Motiv Flex Fuel setup installed and would be happy to to some testing for you on my 08 335i. It has been installed using their instructions. Right now I'm using full MHD OTS Flex Fuel, but I would much prefer to go back to my JB4 with MHD BEF. PS. My car is I8A0S.
ryanamini@gmail.com
FBO
RB One Turbos
Walbro 525 LPFP
Tank to HPFP /w Ethanol Sensor and Motiv FF Box
fn42 fn42 is offline
Car: 2008 335xi
Default 05-06-2019, 07:54 AM
just adding a comment to express my interest in this and support for the FF PIDs in the jb4 logs.
I am attaching my (ije0s, jb4 compatible, FOR YOUR ENLIGHTENMENT ONLY) tune in case anyone wants to modify it for their own purposes. It's the BMS pump gas tune with my own custom fuel maps for FF and a pretty conservative FF timing map: JB4_IJE0S_PUMP_3_FF_JAKE23.bin - Google Drive
Default 05-09-2019, 03:21 PM
Sorry sort of dropped the ball on this with other development going on around here. If anyone has the flex fuel kit installed and feeding in to the ECU let's confirm the JB4 is reading the signal properly and get to work on the mapping!
buster84 buster84 is offline
Default 05-11-2019, 09:29 AM
Originally Posted by trebila
Hi Terry
Hey trebila, last we talked you were still waiting on Terry for the e85 maps (last year), is the new flex maps available now? If so I'll be happy to pay you again to update my backend flash again. I'm so ready for the day I can stop changing my flash at gas stations just for e85.
2009 335i X-Drive | GC 2.0 Turbos | VTT silicone Inlets | VTT Aluminum Outlets | Fuel It PI with FPR,return line, BMS controller, and flex fuel sensor | Fuel It Stage 3 fuel pump | BMS dual cone instakes | BMS Catch Can | VRSF 7.5" Race Intercooler | Forge Diverter Valves | JB4 G5 ISO with Blutooth/JB4 Mobile App | n20 tmap sensor 3.5 bar | AR After turbo Exhaust
alvinhobh alvinhobh is offline
Car: 07 BMW 335i Coupe
Default 05-12-2019, 07:44 PM
Terry,
I have a flex fuel kit up and running. If I turn on the Ethanol Setup "DTML Flex Fuel", it does read the same % ethanol as the MHD, I haven't tried multiple % to see if it follows well or not.
Now to Trebila’s point, is there any wiring changes to the JB4 so I don’t have to adjust fuel bias? What should I set all the fuel bias to once the DME is reading from the FF kit?
07 335i e92 - money pit
trebila's Avatar
Default 05-13-2019, 07:44 AM
just drop me an e-mail
