(#226)
Fmonteiro444's Avatar
Car: 09 E92 SG
Default 08-06-2019, 02:13 PM
Back on the streets!! Time to really turn it up and make some big power with that turbo
How far have you turned it up so far?
Currently only on a pump gas tune, 19psi ish.
Car: 09 E92 SG
Default 08-14-2019, 12:07 PM
Still dialing in boost, but here is a quick pull on E85.
zole2112 zole2112 is offline
Car: 2013 BMW 335xi F30 N55
Default 08-14-2019, 12:29 PM
Awesome!!!
2013 BMW 335xi F30 N55 PWG
Injen CAI/ER CP/VRSF C-less DPipe/Active A FMIC/JB4 v3 - Map 7/e50/Custom tuned exhaust/stock turbo/Resonator Delete/MHD & JB4 e85 BEF/Stage 2 LPFP Walbro 450
Summer '19 install: Speedtech BW 8374/PI & Tune by Trebila
Phataxe's Avatar
Phataxe Phataxe is offline
Car: 2014 435I
Default 08-19-2019, 10:10 PM
Sounds and looks pretty good. Im running mine at 24 psi right now. Hard to keep the rear end hooked up anywhere below 4th gear..lol
'14 435I RWD MHD "Twisted Custom Tune" BigBoost Stage 3 Turbo PR Coils XHP Trans Tune GFB DV+ VRSF Race Cooler VRSF CP BMS Intake Borla ATAK Exhaust Custom Down-pipe stage 3 LPFP BMP4 EKP M Performance LSD Phoenix Racing PI Intake Manifold AIC2-P controller e85 3.5 TMAP NGK 5992 Plugs "0.020"
luchocamp's Avatar
Default 08-22-2019, 03:44 AM
need to be fast at 20psi before increase boost to 22, 24, 26 or more...
keep it up
10.64 @129mph, MHD Custom + #LUCHOJB4, E40 + meth ~ Drag Track online set up on instagram @luchocampusano ➡
Hamad335 Hamad335 is offline
Car: F30 335 2015
Default 10-07-2019, 01:35 PM
Originally Posted by Fmonteiro444
So I finally fixed it. I didn't end up needing a longer rod. Turns out, key-off the wastegate flapper is only like 3-4mm open. I started with key-on voltage around 3.9v. At one point I got it down to 1.4v. So I shortened it some more and it jumped back to 3v key-on and the wastegate never even opened. It's amazing how sensitive this thing it.
So I've been running map 7 on E50 for now and all I can say is this thing RIPS! Once I get my new Rev3 installed I'll start doing some real tuning at higher boost.
What did you actually change volt of what and how did you change it i have been trying to fix this problem for ages can you please give me the steps to fix this
Email me h335xx@gmail.com
