(#201)
Car: 08 535i
Default 11-23-2018, 02:21 PM
Well I am back at it, trying to get some things finished before the end of the year.
N55 PR coil kit...
I made sure all the pins were seated properly, then installed the water seal. Some pins were pushed out when installin the clips.
I also started the dynamic drive and active steering removal!!!
Lines to the rear draining...
All the dynamic drive lines removed
All that nonsense is being replaced with just this. lol
Active steering rack is next....
Should have it wrapped up before the weekend is over...
Car: 08 535i
Default 11-23-2018, 02:32 PM
I found some leaks while getting into this project.
front cover...
My rear turbo drain line had oil pooling on the anodized fitting, still unsure of where it is coming from.
My oil pan gasket is not leaking but I am going to replace that while the subframe is off. and I also have index 12s to finally install, bank 1 has a leaky injector...
Car: 08 535i
Default 12-07-2018, 05:27 PM
So now that I have the dynamic drive removed from the car I am looking into m5 rear swaybar and m5 pullrods.
Pull rods are ordered. and about to pull the trigger on an m5 rear sway.
I also developed a cylinder 6 misfire while trying to log. Seems to only happen with mhd stage 2+ installed. flashed dme back to stock and no more misfire. hmmm
Wish it wasn't so cold out, hopefully it will not be a long winter.
Car: 335i, 2009
Default 12-07-2018, 05:47 PM
Nice build! Looking forward to seeing more.
JB4 ||| H&R Sport Springs
X5 50i 2013 ///M Sport
BMS Stage 1
Car: 2003 Forester
Default 12-10-2018, 05:24 AM
Not sure if I mentioned this but I run a M5 rear bar ($100) and H&R's on my X-drive and think it's a great setup for daily use. One thing to look at though is the Dinan M5 rear bar. It's only $190
https://www.ecstuning.com/b-dinan-pa...d120-0491~din/
Car: 08 535i
Default 12-14-2018, 04:28 PM
Back at it today. I installed my m5 pullrods and cut my engine cover to fit.
Here are the list of parts needed.
You will need (4) of #16 ; (2) of #15 ; (2) of #17
Engine cover pics.....
The car is running very well, minus the fact that it never seems to want to warm up. I am about to make a post about it. But otherwise all is good in the hood!!!!
Car: 08 535i
Default 12-15-2018, 03:37 PM
I have deemed the reason the car does not want to warm up is the coolant t-stat is bad. you can read all about it here.....
https://www.n54tech.com/forums/showthread.php?t=56185
I also have had a louder than normal tick that is harmonious to the injectors, but definitely not the injectors. I found that the issue was due to my lifters not getting sufficient oil pressure. You can read about how to bleed the hydraulic lifters here...
https://www.quirkyuncle.com/2013/04/...yVktJNi65ORsAk
I also decided to do a compression test to see how things are holding up. here are the results...
Car: 08 535i
Default 09-11-2019, 01:47 PM
Anyone have a wiring diagram? lol
If you ever have to do a heater core......burn the car. lol
y0itzflip y0itzflip is offline
Car: e60 535i
Default 09-11-2019, 05:44 PM
oh no. what led to this?
Car: 08 535i
Default 09-27-2019, 08:29 AM
Parting out a few e60s and needed to pull the heater core to get the front carpet out. Never want to do that again. Lol
