Immoralus's Avatar
Immoralus Immoralus is offline
Car: 2008 335xi
Default 2ABC and 3100- Car Shutting off while driving. - 10-19-2016, 03:43 AM
So yesterday I go to leave work and get a half engine, I check it and thought it said 2abd (a common tmap code I get) and a 3100 code. So no biggie I go to 1-2 in jb4 to clear it and my car shuts off. Oddly enough the car is reading me the codes still, even though I used the jb4 command to delete them.
So I manage to clear them, I jump on the highway boom cel for the same issue now my car sputters and then goes limp causing me to have to hit the shoulder. I try to delete it again and the car turns off again. I manage to limp her home with the check engine light in map 0.
So I thought, let me get my laptop and clear them only to realize that the same thing would happen. I'm at wits end here... I checked my 4bar tmap and that looked fine... any ideas?
08 335xi- JB4/Trebila,RB Inlets, VRSF CP ,FMIC, ** ,BMS DCI,e50 and Fuel-it Stage 2. 11.8 @ 118
Default 10-19-2016, 06:18 PM
Verify N20 TMAP is set to 4 and that the connection is good at the sensor. If you're still getting them, go back to the stock sensor to verify it's not something else.
Immoralus's Avatar
Car: 2008 335xi
Default 10-19-2016, 07:43 PM
Thanks Steve , I'll give it a try. After researching this is a seemingly common issue with no definitive answer. Makes me worry...
Default 10-19-2016, 10:02 PM
Whoops...I said to set the TMAP to "4", meant to say set your 4.0 TMAP to 2.
Rob.K Rob.K is offline
Car: 08 135i 6MT
Default 10-20-2016, 01:36 PM
I've had the same issue, was a loose wire going into the TMAP from taking out and installing several times.
Current - 2008 135i 6MT | XR9567
Sold - 2007 335xi AT | 12.1@117
Immoralus's Avatar
Car: 2008 335xi
Default 10-21-2016, 09:39 AM
Cool so I've inspected all the wires.. still the same issue. Took off jb4 again same issue. Should I contact Terry to see if should purchase another tmap? I'm about to part this baby out lol. Jk jk
Default 10-21-2016, 08:03 PM
Try swapping your stock TMAP back in and see if that resolves the issue.
Default 10-21-2016, 08:37 PM
Could be a faulty TMAP but more likely a BEF setting that needs to be changed for the 2ABD.
Immoralus's Avatar
Car: 2008 335xi
Default 10-23-2016, 05:37 AM
So yesterday I flashed the car back to stock, took off the jb4 and flashed the MHD e40 ots map and the car ran like new. This morning I go to start the car and the same code was apparent (2abc/3100) and car was revving high and carrying on. It's weird how it would work fine and then take a dump.
I seem to have misplaced my stock tmap in my move so I guess I'll have to get a new 4 bar.
Immoralus's Avatar
Car: 2008 335xi
Default 11-10-2016, 05:10 AM
Just to give an update, Terry sent me a new 4bar Tmap with harness and the code hasn't been back.
BostonBeemah's Avatar
Car: AW 135i
Default 11-10-2016, 09:45 AM
I also got a new 4bar from Terry but not a harness. Code has come back twice in a 2 week period just at initial startup but I cleared and restarted the car without it coming back. Not sure if its the cold or whats going on here but I am just glad I can drive the car now..
RIP 2008 AW/BL 135i
Immoralus's Avatar
Car: 2008 335xi
Default 11-10-2016, 11:17 PM
I Bekieve it is the harness then.
