MFactory MFactory is offline
Car: BMW E92 M3
Exclamation MFactory LSD's, Clutches, Flywheels and Misc SPECIAL OFFERS - 05-18-2016, 01:20 AM
Mods/Admin - As there is now a 1-thread limit in place for vendors, please keep this thread open and lock all other threads. Thanks!
MFactory Limited Slip Differentials - Lifetime Warranty, 30-Day Money Back Guarantee!
Helical LSD E9X 335i 05-07 (Bolted MT/AT) - $999.95
Helical LSD E9X 335i Sep 07+ (Bolted AT) - $999.95
Helical LSD E9X 335i (Welded MT/DCT/335d) - $999.95 + $799.95 for Rebuild Kit (Includes BRAND NEW 2.56/2.81/3.08 MFactory Bolted Ring & Pinion, Ring Gear Bolts, Shim Kit & Solid Pinion Sleeve. No Machining Required!)
Fully Rebuilt Pumpkin with Helical LSD (Bolted Fitments) - $1499.95 + $500 core exchange fee
Fully Rebuilt Pumpkin with Helical LSD (Welded Fitments) - $2199.95 + $500 core exchange fee
Metal Plate LSD E9X 335i 05-07 (Bolted MT/AT) - $1499.95
Metal Plate LSD E9X 335i Sep 07+ (Bolted AT) - $999.95
Metal Plate LSD E9X 335i (Welded MT/DCT/335d) - $1499.95 + $799.95 for Rebuild Kit (Includes BRAND NEW 2.56/2.81/3.08 MFactory Bolted Ring & Pinion, Ring Gear Bolts, Shim Kit & Solid Pinion Sleeve. No Machining Required!)
Fully Rebuilt Pumpkin with Metal Plate LSD (Sep 07+ Bolted AT Fitments) - $1499.95 + $500 core exchange fee
Fully Rebuilt Pumpkin with Metal Plate LSD (05-07 Bolted AT/MT & Welded Fitments) - $2699.95 + $500 core exchange fee
- Optional Extras -
Diff Bearings (05-07 Bolted MT/AT & Welded Fitments) - $299.95/pair
Diff Bearings (Sep 07+ Bolted AT Fitments) - $199.95/pair
Shim Kit (05-07 Bolted MT/AT & Welded Fitments) - $199.95
Shim Kit (Sep 07+ Bolted AT Fitments) - $199.95
Axle Seals & Ring Gear Bolts (05-07 Bolted MT/AT & Welded Fitments) - $99.95
Axle Seals & Ring Gear Bolts (Sep 07+ Bolted AT Fitments) - $99.95
Solid Pinion Sleeve (05-07 Bolted MT/AT & Welded Fitments) - $99.95
Solid Pinion Sleeve (Sep 07+ Bolted AT Fitments) - $99.95
Solid Diff Bushings (All Fitments) - $149.95
MFactory Racing Clutches & Flywheels
335i 06-08 8-Bolt SMFW - $499.95
335i 09+ 6-Bolt SMFW - $499.95
335i 06-08 OEM 550i Clutch & 8-Bolt SMFW - $899.95
335i 09+ OEM 550i Clutch & 6-Bolt SMFW - $899.95
335i 06-08 SPEC 2+ Clutch & 8-Bolt SMFW - $1200
335i 09+ SPEC 2+ Clutch & 6-Bolt SMFW - $1200
335i 06-08 SPEC 3+ Clutch & 8-Bolt SMFW - $1250
335i 09+ SPEC 3+ Clutch & 6-Bolt SMFW - $1250
335i 06-08 MFactory Twin-Disc Clutch & 8-Bolt SMFW - $1599.95
335i 09+ MFactory Twin-Disc Clutch & 6-Bolt SMFW - $1599.95
If you have any questions, please don't hesitate to ask!
For daily specials, please PM me for pricing
Car: BMW E92 M3
Default 05-18-2016, 01:32 AM
For those waiting for our 8-Bolt SMFW's to come back in stock, we are happy to announce that our container just arrived at port this week. It will take a few days to clear customs and then be delivered to us, so all back-orders will be fulfilled by late next week!
Car: BMW E92 M3
Default 05-23-2016, 10:23 AM
Pre-Order Special - This Week Only!
With our container arriving this week, we'll have enough stock to last us quite a while, so thought we would give everyone an opportunity to get a 10% Discount Off their order - For This Week Only!
Discount applies to Helical LSD's, Plate LSDs and Rebuilt Pumpkins. Please PM me to order!
Rushan's Avatar
Rushan Rushan is offline
Car: 335i E92 2009
Default 05-26-2016, 11:18 AM
So which option of those as full pumpkin that fits the 05/2008 E92 335i with 6AT?
Car: BMW E92 M3
Default 05-26-2016, 11:31 AM
If purchased this week, including discount, will be $1349.96 + $500 core exchange fee
Rushan's Avatar
Car: 335i E92 2009
Default 05-26-2016, 11:40 AM
Core exchange will be difficult considering I'm in dubai and shipping will be way too high... What's the total weight of the shipment also what's the estimated shipping in case you ship internationally to dubai
Car: BMW E92 M3
Default 05-26-2016, 09:44 PM
As you have a bolted diff, you can purchase just the LSD unit only, and have this installed locally.
Car: BMW E92 M3
Default 06-01-2016, 07:24 AM
MFactory Sports Axles
(sorry for the low quality image)
Put more power to the ground with the MFactory Sports Axles, designed specifically for the high performance street car.
Diamond Cut to exacting tolerances from Forged High-Nickel-Chromium-Molybdenum Steel
- Perfect fitment & finish ensures hassle-free installation & maintenance, each and every time
Designed using leading-edge Solidworks 3D CAD & Cosmos FEA software
- Advanced Geometry minimizes parasitic drivetrain losses. Race cars utilizing MFactory components transfer, on average, 1-2% more power to the ground over our competitors!
2nd Generation Design
- With our Rifle-Bored Center Shaft, the MFactory v2 Racing Axles are lighter, stronger and more efficient than any other Sports Axle on the market today!
Covered by the MFactory Lifetime, Globally Transferable Warranty
- Whether used on the Street, Strip or Track, all MFactory Sports Axles come with a Lifetime, No-Hassle, Globally Transferable Warranty
We have so far tested these up to around 550lbs with no issues (we don't have an upper limit on these yet). From our initial sample batch, we still have a few sets left, so are offering these at a discount price to those interested
Unlike other axles on the market, ours are a Complete Set, including new 6-ball CV joints i.e You do NOT have to send in your existing axles for a shaft upgrade! Our axles are a direct plug-n-play swap
MSRP: $999.95 + shipping
Test Price: $799.95 inc FREE Shipping
Review thread here: http://www.n54tech.com/forums/showthread.php?t=39989
Please PM me if interested
E90gone E90gone is offline
Default 06-02-2016, 06:18 PM
I need a set of axels for an 08 e90 335i. Shoot me a PM with the price shipped to 33778.
Default 06-04-2016, 12:57 PM
MFactory, whats the weight of the new axles compared to OE BMW units?
N54 | Build Thread
Car: BMW E92 M3
Default 06-05-2016, 09:50 PM
For those asking for the weight, our axles actually weigh exactly the same as the oem (12kg). The reason for this is because our centre shaft ends are a lot thicker, as well have having larger cv cages/balls.
VegasJD's Avatar
VegasJD VegasJD is offline
Car: 2012 bmw 135i
Default 06-05-2016, 11:15 PM
Are these in stock? or how long is the wait time to get a set of them?
2018 Individual Tanzanite Blue Competition M4
Car: BMW E92 M3
Default 06-05-2016, 11:24 PM
Yes, we still have few sets in stock
Xshadows Xshadows is offline
Car: 2008 135i
Default 06-07-2016, 05:08 AM
I currently have your SMFW. Is it the same one that you ship with your Twin Disk? If so.. what's the price on just the clutch? Also - Is this a race clutch? And will there be a street version made if so?
Car: BMW E92 M3
Default 06-07-2016, 08:46 AM
It's not, no. The Twin-Disc uses a custom flywheel
Car: 2008 135i
Default 06-07-2016, 12:59 PM
Ok, what about the clutch itself? Is this a race version? I saw something about you guys also making a street version?
Car: BMW E92 M3
Default 06-07-2016, 01:32 PM
It is race spec, yes. We are working on a street spec, but this won't be available for a while yet
iambinko iambinko is offline
Car: 1995 325is
Default 06-12-2016, 05:07 AM
Hello I'm looking for pilot bearing carrier snout that would press into an 8 bolt flywheel
keyap keyap is offline
Car: N55 135i
Default 06-12-2016, 05:16 AM
Hey guys, any recommendations on a supplier and fitter in the UK for the LSD? I can find a few suppliers but am really struggling to find one who'll also fit and has previous E82 experience.
JB4 | BMS OCC | N20 TMap | Fuel-It! PI | AIC6 PI Controller | Fuel-It! Fuel Lines | Fuel-It! Stage 2 LPFP | Continental In-line E Sensor | ER Charge Pipe | Pure Stage 2 Turbo | Pure High Flow Inlet | GFB DV+ | Richter C'less D/Pipe | Berk Race Full Exhaust | MFactory Pro Helical LSD (75% Bias Ratio) | eDiff Disabled Via Coding | MFactory Solid Diff Bushes | Diff Lockdown Bracket | Custom 98G0B BEF | NGK 5992s (0.020")
Car: BMW E92 M3
Default 06-12-2016, 08:45 AM
PM me
Give our UK facility a call: MFactory R&D - 01772 435 943
Default 06-12-2016, 12:44 PM
Do you have an ETA for us auto guys on the axles?
Car: BMW E92 M3
Default 06-12-2016, 03:15 PM
No ETA, but we are looking into it
Car: BMW E92 M3
Default 07-14-2016, 07:41 PM
Hey Guys,
we are looking for a tester to help us test out our new Metal Plate LSD for the 135i/335i 09/2007+ AT fitment (188 Diff):
- Coil Spring preload system ensures minimal powerloss and maximum response, allowing fully adjustable preload settings from 0-85lbs
- Fully adjustable cam angles (provided) allowing you to set the required aggressiveness and activation type
- Utilises our 2nd Generation Active Friction™ Plates, reducing NVH by as much as 50%
- Fully adjustable lock capacity with a 20-Disc Setup: 20/40/60/80/100%
- MSRP: $1499.95 + shipping
- Tester Price: $750 (50% Discount) + shipping
- Rebuild parts (bearings, seals etc) can be supplied upon request at discounted cost
- We can also rebuild your pumpkin for you if required at discounted cost
Tester requirements:
- Must have active track use (Circuit and/or Auto-X)
If anyone is interested, or know anyone who would be interested, please PM for more info
bleedsblue0023's Avatar
bleedsblue0023 bleedsblue0023 is offline
Default 07-16-2016, 09:19 AM
Whats happening with the recall if my diff is affected?
Houston, TX
Jet Black 2011 335i Sport 6MT:
Mods:
BMS Intake, JB4 Iso, BMS E85 BEF, CPe Chargepipe, ETS 5", Megan Racing turbo outlet, BMS OCC, SS Brake Lines, BMS CDV, MFactory LSD + mounts, 335is clutch, MFactory SMFW, 650i finned diff cover, Pure Inlet, Fuel-it Stg2 LPFP + Plat TBI, E46 Trans mounts, Turner Pedals, Mishimoto wheel lugs, Turner 10mm spacers, Msport Interior, M3 armrest, M3 Control arms, EvoRaceWerks F30 TIC pipe
CS@MFactory CS@MFactory is offline
Car: E92
Default 07-17-2016, 06:26 PM
Bump TTT
Got Questions? Read our Limited-Slip Differential FAQ: http://www.n54tech.com/forums/showthread.php?t=29755
