(#476)
Furylibre Furylibre is offline
Car: 335XI
Default 08-08-2019, 01:45 PM
Hello all,
My turn now.
I just blew my motor out last month, probaly a week part or bad injector connection, it's not clear yet. I had overboosted @24psi, i don't think tune was an issue. But, anyway, i replaced motor with an 80K miles "brand new" N54.
I would need a conservative tune to make sure i would not blew motor again. I am a bi afraid. Motor has been installed 2 weeks ago, i will change my oil next week, and after, i'll be ready to do some pulls.
I would like Trebila have a look on it, if it's possible.
My car and my mods are:
335XI 2008 N54
Pure Stage 2 DD turbos,
2" inlets,
CTS Intercooler, DCI,
CTS ChargeP with Forge Diverter Valves with yellow spring,
Magnaflow exausts and you know what,
RB PCV Valve, 3.5Bar T-Map sensor,
Recent JB4 + MHD backed-end flash Pump.
I'am running on 91 octane
My goal is just a save tune, not too agressive that will not be hard on the life of the motor while beeing a cool daily drive.
Thank you.
jacobniell jacobniell is offline
Default 08-12-2019, 10:17 PM
Trebila, have you ever done any tune for the helix overdrive HPFP that are slowly comming on the market?
ym12ad ym12ad is offline
Default 08-14-2019, 02:08 AM
I have bought an '07 335i with BEF from Trebila 100% meth flow with 99 octane on map 3.From few days now at WOP the car automatically switch to map4 and I get 4 hazard lights flash,any idea what can be wrong.I will make some logs and post them.
Thank you
Default 08-14-2019, 04:02 AM
Thank you
It is most likely your JB4 that is protecting your engine and tricking the map4 mode.
If you look on the JB¤ interface, you will be able to see what tricked the fault. Do you have the JB4 app?
Default 08-14-2019, 10:23 AM
thank you,also makes a very strange noise now,anybody any idea what can it be?
joeinsd joeinsd is offline
Car: 2010 e92 335i msport
Default 08-20-2019, 04:42 PM
What does the last safety show? That'll tell you why it got pushed to map 4..
trebila's Avatar
trebila trebila is offline
Default 09-04-2019, 04:59 AM
Hi
Helix sent me directly the definitions for VCV, and how to adjust them, yes.
Cal1415 Cal1415 is offline
Car: 2006 335i
Default 11.61@127.1mph stock turbos Trebila E50 BEF - 09-04-2019, 08:49 AM
I managed to consistently trap 127-128mph in the 1/4 mile last Sunday. The first 3 runs were on Map 3 (23.5psi) but found the engine did't feel as smooth and the IAT across the finish line were 160 degrees. Causing a cylinder 6 misfire.
Thereafter I used Map 7 (19.5psi) and found the engine to run much smoother and the IAT was only 130 degrees at the finish line. The 1/4 mile trap speed was slightly higher too and much more consistent.
I'm going to visit a different track in a couple of weeks which will be fully prepped and should knock my 60ft time down quite considerably. Overall I'm loving the car and the Trebila E50 flash is excellent
E92 335i Stock turbos on 97,000 miles.
JB4 + Trebila E50 BEF on Map 7, XHP stage 2 trans flash, Fuel-It Stage 1 LPFP, VRSF 7" intercooler, VRSF doonpipes, BMS DCI, ML 1.75" inlets, RB outlets, CPE charge pipe. Hoosier drag radials 275/40r17 with Apex Arc 8 wheels, Mickey Thompson ET Front skinnes
Weight: 1480kg (3260lbs)
Best quarter mile trap: 11.84@128.2mph (stock turbos) 19.5psi boost, E50 fuel only
Best quarter mile time: 11.45@125.6mph (stock turbos) 19.5psi boost, E50 fuel only
JMVela's Avatar
JMVela JMVela is offline
Car: 335is
Default 09-04-2019, 08:54 AM
Congrats. Trebila is a great tuner!!
2012 335is DCT 719.9 WHP MMPs BB turbos 93 oct pump gas + Meth. Trebila tuned.
codesx codesx is offline
Default 09-04-2019, 10:14 AM
I'm stoked.
I'll be doing a Trebila tune in the next few weeks/months.
THE BEAST got me hooked after showing me some logs and videos. Stunning results. (thanks!)
I'm just tuning up the car pre Trebila. (Index 12 Injectors (after much debate) plugs, boost leak testing, etc)
I'm guessing it'll be 33% of my auto happiness. (cost to happiness... no idea why every JB4 user doesn't do it, just based on other's results)
First 33 goes to JB4, second 33 goes to BMS WMI.
All the other mods will have to share the remaining 1%. Just give me boost and timing and I'm happy!
2008 335i Convertible, E93, N54, A/T (190,000+ km)
TMAP: 3.5 barr
xHP Stage 3 (v2.0)
VRSF CP | HKS BOV
RB PCV Valve
NGK 5992 Plugs @ .020
Maintenance:
Car: 2008 E93
Default 09-04-2019, 12:42 PM
Originally Posted by codesx
I'm stoked.
Im sure you will be happy.
Car: 2008 E93
Default 09-04-2019, 12:44 PM
I didnt think it was possible to trap that high on stock turbos ! Congrats !
Any weight reduction ?
Says 335i, but what model ?
Car: 2006 335i
Default 09-04-2019, 03:30 PM
Thanks! Neither did I think it was possible until I fitted some some front skinnies and gained 3-4mph.
The weight reduction totals at 267lbs so the car now weighs 3260lbs. I weigh 176lbs so 3436lbs in race weight. It's an E92 335i
Car: 2008 E93
Default 09-04-2019, 04:22 PM
Time to update your signature now !
5nowh1te's Avatar
5nowh1te 5nowh1te is offline
Car: 2008 535i
Default 09-04-2019, 07:38 PM
Originally Posted by trebila
Hi
I might have to look into it
2008 535i SAT W/paddle shifters
Pure Stage 2 DD on the way!
VTT Inlets and Outlets
Spool Performance stage 3 LPFP
Fuel-It Ethanol Sensor + Lines
Motiv Flex Fuel Box
AD-Engineering 650 HP Intercooler
JB4 G5 ISO W/MHD BEF
XHP Flash Stage 3
Synapse CP with BOV
BMS OCC & PCV
Accuair Elevel
Hpdrivetech air bags
AG Wheels
lightning lightning is offline
Car: BMW 1M Coupe
Default 09-07-2019, 02:24 AM
Did my Trebilla tune in 2016 for my 1M Coupe.
haha and car is still running strong and smooth. I do not really like the idea of going on the dyno, but here’s a 100-200 run on pump gas and 100% meth.
Great job done by David
DamnDatsun's Avatar
DamnDatsun DamnDatsun is offline
Car: 2010 135i msport
Default 09-07-2019, 04:54 PM
I had David do an e50 tune when I had stock twins and it was the best thing I did to my car.
Now I'm having him tune my 6466 single turbo conversion. I was slightly worried I went too large in my turbo choice, and the "lag" would take the fun out of putting around town. Boy, was I wrong. David's tune makes it barely noticeable i don't have stock twins anymore. And his response emails have always been next day.
I couldn't be more happy, or impressed.
Azamat Azamat is offline
Car: Bmw 335 n54 e90 2008 4wd
Default 09-11-2019, 06:11 AM
help please
Default 09-11-2019, 09:22 AM
Originally Posted by Azamat
help please
Bless you.
TMAP: 3.5 barr
xHP Stage 3 (v2.0)
VRSF CP | HKS BOV
RB PCV Valve
Maintenance:
kiwi norm kiwi norm is offline
Default 09-19-2019, 04:10 AM
Trebilla,
i need some help from you to tune my newly updated n54 335i. I am not really that tech smart. Whats the best way to contact you and what do i need to do to get this underway?
cheers
Norm
cebrailbakan's Avatar
Car: BMW E90 335XI
Default 09-19-2019, 04:44 AM
Originally Posted by kiwi norm
Trebilla,
cheers
Norm
Hi , congratulations on your new car. You can easily find the contact information in the previous posts. Have a good luck with great tuner David
Do more with less !
trebila's Avatar
Default 09-19-2019, 05:11 AM
Trebilla,
cheers
Norm
just send me a PM
pdcnc's Avatar
pdcnc pdcnc is offline
Car: BMW 335I
Default 335i N54 Mhd-Jb4 Trebila Dyno 643 WHP 702 Lb/ft - 10-21-2019, 03:36 PM
Very happy with the work David did with my car. I recommend it 100%
File Type: csv 2019-10-11 09_34_28 (MHD _TREB_V7_60_50_Meth_10_Eth)_Gear-4_Map-6.csv (8.0 KB, 3 views)
335i N54 E92 MT Version Europe. Costa Rica. 2008.
MHD_JB4_TREBILLA-FLASH. RB Next Gen turbos RB. 645 WHP 702 lb/ft Inlets RB. Pcv valve RB. Jb4 ww methanol injection 60/40. 10% Ethanol. Map 6. Two Cm 7. Fuel 93 oct. Intercooler AMS. ** AR 3". Ultimate Racing Cold Air Intake. Remus exhaust Forge diverter valves spring yellow. BMS OCC.
BMS short throw. Clutch Spec2+. BMS modified clutch valve
M4 F83 2016 DTC MHD JB4 map5 ** CNT Fuel 93 oct.
In process.
Talking Very Pleased - Today, 10:14 AM
** E93, 4090 lbs (plus fuel and me), no weight reduction **
THE BEAST put me in touch with David.
Bang for buck, this was the best expense.
I've been rockin' the Trebila tune for approx 1 month now.
The power comes in so intensely now at such a low RPM, targeting 24 PSI by 3000 RPM.
The Turbos are stock, and inlets, as is my exhaust, so there are barriers on my side to spooling and breathing.
That said, it feels like a monster.
Between my traction (getting cold here) and no ideal test zone, my ability to log has been restrictive to obtaining the best log data.
A standard 3rd gear pull is attached. I couldn't go to 7k in this one.
My best official launch so far is 4.50 seconds.
This stretch of asphalt often registers as -0.4~*, however here is -0.93%.
Same spot I pulled a 4.01 (0-60(1ft)), but it registered as invalid as it breached the -1%.
I'm convinced with warm tires and a smooth surface, I can get sub 4 sec as is.
If I switch at 5000 or 5500 RPM, followed by not accidentally letting off the gas at the end (like in the attached), it should make a difference.
(I have to hold my first gear boost at 10 PSI now, just to hold the road with 275r, while I used to leave it open)
THE BEAST is THE BENCHMARK for the E93.
One day boss... one day! It'll be Ethanol vs. Methanol!
TMAP: 3.5 barr
xHP Stage 3 (v2.0)
VRSF CP | HKS BOV
RB PCV Valve
Maintenance:
Car: 2008 E93
Default Today, 10:57 AM
Thanks for the kind words.
BENCHMARK, .....hardly
Ethanol vs methanol....hmmmmm.....dare you to cross the border, lol
Jealous of your IATs though 👀
Log looks good 👍🏽👍🏽👍🏽👍🏽👍🏽
