(#601)
emiliof emiliof is offline
Car: Mini F56 Cooper S
Default 07-18-2019, 03:47 PM
Sure thing:
MAP 2
psi_curve[0] = 30 '1500
psi_curve[1] = 35 '2000
psi_curve[2] = 40 '2500
psi_curve[3] = 45 '3000
psi_curve[4] = 50 '3500
psi_curve[5] = 60 '4000
psi_curve[6] = 60 '4500
psi_curve[7] = 60 '5000
psi_curve[8] = 55 '5500
psi_curve[9] = 50 '6000
psi_curve[10] = 40 '6500
psi_curve[11] = 35 '7000
MAP 1
psi_curve[0] = 20 '1500
psi_curve[1] = 20 '2000
psi_curve[2] = 25 '2500
psi_curve[3] = 35 '3000
psi_curve[4] = 40 '3500
psi_curve[5] = 40 '4000
psi_curve[6] = 40 '4500
psi_curve[7] = 40 '5000
psi_curve[8] = 40 '5500
psi_curve[9] = 40 '6000
So Terry if I want to create a gentle map at low rpm and then adding more boost at the top end, like an hybrid version between map 1 and 2, I could make something like this, right? Of course the values are just an idea to show the concept.
psi_curve[0] = 15 '1500
psi_curve[1] = 15 '2000
psi_curve[2] = 15 '2500
psi_curve[3] = 20 '3000
psi_curve[4] = 25 '3500
psi_curve[5] = 30 '4000
psi_curve[7] = 50 '5000
psi_curve[8] = 50 '5500
psi_curve[10] = 45 '6500
Assuming that:
1. these values represent additive values for boost based on a decimal psi scale
2. If 1500 is below 10, then they will be additive values, and if 1500 is over 10 they will be absolute values
So in order to achieve an additive +5psi map with low torque, I do need to write these values under 'Map 6 Boost' like
1500= 1.5
2000= 1.5
2500 = 1.5
3000 = 2.0
3500 = 2.5
4000 = 3.0
4500 = 4.0
5000 = 5.0
5500 = 5.0
6000 = 5.0
6500 = 4.5
7000 = 3.5
Is is correct?
Default 07-24-2019, 10:24 AM
You could try that but the key is always to log and evaluate to ensure it's doing what you expect.
Those values represent additive values.
echacon echacon is offline
Car: Cooper S F56
Default 07-25-2019, 12:05 PM
JB4 is compatible with 7-speed DCT mini's?
johntotah94 johntotah94 is offline
Car: B46 F56S
Default 07-25-2019, 11:22 PM
BootMod3 released support for B48. Will we be seeing a BEF one day?
Default 07-28-2019, 09:40 AM
Waiting for MHD to release it but I'm sure it won't be too long now!
Car: Cooper S F56
Default 07-29-2019, 04:45 AM
JB4 is compatible with 7-speed DCT mini's 2018/2019?
Car: B46 F56S
Default 07-29-2019, 04:56 AM
Awesome. I quite like the way you programmed this file to switch to Map 8 and switch back automatically. You don’t need to make any adjustments to that.
Is it possible, when you get some time, to help out with the code read?
Code read not working is super annoying. Having to switch dongles, open Carly, and that is very time consuming compared to JB4 app.
Jay1312 Jay1312 is offline
Jay1312
Car: BMW 320i and M5
Default 08-02-2019, 12:28 PM
Originally Posted by johntotah94
Awesome. I quite like the way you programmed this file to switch to Map 8 and switch back automatically. You donít need to make any adjustments to that.
Seems I canít determine if meth is flowing or not; John does that work for you and btw code read does work when you have an error and deletes. When you check next time it gives you an invalid read as message on hex6.
Augustor Augustor is offline
Car: Mini Cooper S F56
Default Firmware Version - 08-10-2019, 01:05 PM
please help, I did the firmware update but before I had version 48/5 // 5 and now I have version 48/4 // 5, could you tell me which one is the last one and how to get it?
Car: B46 F56S
Default 08-10-2019, 04:28 PM
Yes. My meth works properly and displays properly.
Do you have a BMS Meth Kit? FSB Wired to correct pins?
Jay1312
Default 08-12-2019, 09:28 AM
Yes bms kit and connected. meth works for me when meth trigger set to 1. What maps are you running John? Have you tried the meth map3 with additive or you using map 6custom tuning on top of flash?
Car: B46 F56S
Default 08-12-2019, 01:10 PM
I was using Map 1, 2, 3 before the flash switching around. Now I use Map 6 at 0psi to control meth and trigger safeties on top of my flash.
Default 08-22-2019, 07:46 PM
Any news about new firmware?
joemysterio joemysterio is offline
Car: 2016 Mini Cooper S
Default 09-27-2019, 10:06 PM
A few questions for you all... what's the latest stable firmware? The 1st post is years old and doesn't seem like it's been edited. I'm currently on 48/4//5... I see there are two hex files, so far I've only used the first one ending in OBDII_4.
Are the maps that are usable the only ones that are in the 1st post? So anything above map 4 is useless?!
Also, my biggest question, is there a guide on how to tune the settings? I'd like to do more than just use the maps, I'd like to fine tune some more, but so far I'm not finding much info on how to do so. It's becoming extremely frustrating not finding info on how to properly use this thing.... I'm using the JB4 via BT/the app.
Thanks in advance...
-edit-
Attaching a quick pull I did yesterday, which netted me a code 12BE08: lean to rich, slow reaction.
JCW tune + JB4
******* down pipe
Car: B46 F56S
Default 09-29-2019, 01:51 PM
-edit-
JCW tune + JB4
******* down pipe
There was a few updates a few pages back but that was only to solve some stuff related to meth.
Default 09-29-2019, 06:16 PM
v6 in the first post is the latest firmware.
Default 09-29-2019, 06:18 PM
JCW tune + JB4
******* down pipe
Not a fault code I've seen before. Any intake? What fuel?
Timing looks to be dropping here a bit on just map1 so seems like a lower grade fuel. Mix in some E85 to get octane up perhaps?
rice_rocket88 rice_rocket88 is offline
Car: 08 535xi
Default 10-01-2019, 11:48 AM
Terry, do you have any separate contact? I was going to PM you but didn't see an option to. I have a 2019 X2 M35i and have a question.
toterra toterra is offline
Car: Mini Countryman S (F60)
Default 10-01-2019, 02:31 PM
I have a 2019 Mini Countryman with a manual transmission. I am trying to figure out how to get the OBDII cable through. I appears like there is a cable (for the transmission) that goes through the hole my friend's mini uses. How do I get the cable through, is there a way to force it or do I have to drill a hole or something.
Image located Imgur: The magic of the Internet
Another image Problem JB4 - Album on Imgur
Default 10-01-2019, 10:25 PM
Thanks for the response. Stock intake, 91 california octane. Can try a different station next time. I also moved back temporarily to stock down pipe, as I'm swapping the ***** less pipe to a ceramic coated one so we'll see what happens.
May you please confirm for me my question about the maps? Also may you or anyone else able to provide a guide for tuning, even if a general one that might be recommended? I'd like to learn more, if possible... thanks.
Marcelo.Felicio's Avatar
Marcelo.Felicio Marcelo.Felicio is offline
Car: Mini Cooper S F56 2.0 Year 2017
Default 10-03-2019, 03:46 PM
Hello
I have a mini cooper where I installed a JB4 and an intake billet filter (BMS) I would like to know where I find the best firmware to configure Jb4, and get the best power of my vehicle.
Marcelo Felicio
S„o Paulo - Brazil
Default 10-04-2019, 04:08 AM
Hello
Marcelo Felicio
S„o Paulo - Brazil
Marcelo Felicio
S„o Paulo - Brazil
Car: B46 F56S
Default 10-06-2019, 10:13 AM
Does this include the Map 8 safety and meth reading fix you implemented on the test firmwares on page 23?
Default 10-07-2019, 04:09 PM
Should have all the latest.
Car: B46 F56S
Default 11-17-2019, 10:40 AM
@terry
Can you add meth safeties to the next firmware?
Switch to Map 8 when meth flow is low or non existent?
