Levan-i's Avatar
Levan-i Levan-i is offline
Car: 2007 BMW 335i E92
Default How to disable rear O2 sensors? - 07-28-2015, 07:27 AM
So,
I've not plugged in rear O2 Sensors,
I've disabled :
2C77
2C78
2C7B
2C7C
values to 00 in tunerpro and flashed but now i get
2C7F (AfterCat O2 sensor trim control, bank 2) and 2C6A (AfterCat O2 Sensor switched) errors
what else should i do in bin?
2007 E92 335
ST - GTW3684
MT (after swap),
MFactory LSD
Car: 2007 BMW E90 335i
Default 07-28-2015, 10:12 AM
I've been told by a few reputable people that you must leave the rear O2 sensors installed and plugged in or else it will lead to incorrect fuel trims. Personally I find this hard to believe since they are narrowband sensors and should only care about c@t performance and not affect fueling. But I'm not an expert.
kenjermen's Avatar
kenjermen kenjermen is offline
Car: 2009 BMW 335i
Default 07-28-2015, 05:20 PM
One way to leave the o2 sensor in and not worry about faults is to get the o2 bung spacers. They lift the sensors out of direct air flow simulating that you have cats. Plus these spacers are cheap you can get them off of eBay for $12
2009 BMW 335I with: MHD/Haltech,
precision 6870 turbo, jp Workz header,
Wagner EVO II intercooler,HKS exhaust with cutouts, stage 3 lpfp, wavtech lsd, eospeed intake manifold with fuel return and 60lb injectors
Dmac @ BMS/DMD's Avatar
Car: 2008 135i
Default 07-28-2015, 08:43 PM
Been running with my rear O2s unplugged from the DME for awhile now on 32psi.
What I did:
Remove pins 19 and 20 on the small black subconnector
Code out 2C9E and 2C9F in the flash
These codes weren't available in the public XDFs so I had to add their definitions in myself. Let me know if you have any questions.
Levan-i's Avatar
Default 07-29-2015, 12:06 AM
Dmac
sounds as solution
how you you did that?
2007 E92 335
ST - GTW3684
MT (after swap),
MFactory LSD
3000GT MR's Avatar
3000GT MR 3000GT MR is offline
Car: 09' 335i
Default 07-29-2015, 04:10 AM
Originally Posted by Levan-i
Dmac
sounds as solution
Take your a code that you have. We'll use 2C9F as the example. Swap the first and second 2-bit so it will be 9F2C (dont ask) find it in your .bin hex. All the engine codes are in a general area. Once you find it count up 15 2-bit hex spaces. There will be a number surrounded by zeros. It will be either 56,22,11,00. Take that hex address and plug it into the XDF in TP as a toggle. Then you can shut it off by changing the number to a 00 or 11 depending on what it is. Typically the "on" toggle for O2's is 56 so you would change that to a 00 to turn that particular toggle off.
Have a single turbo and/or tired of burning up O2 sensors? Ask me about the new ADV O2 sensor retro kits!
335i 2010 e92 M-sport Mods: VM Top mount 6466, Aquamist HSF4 w/custom direct port. VRSF IC + Exhaust
335i 2009 e90 665RWHP VFF900 ST RIP .
Levan-i's Avatar
Default 07-29-2015, 04:46 AM
thank you very much!
as i see, in my case the numbers are at 5th hex couple bits not 15th somewhy,
now trying to figure out how to add it to definitions, where do i get unique id from
I've got
2C7E at 5A184
2C7F at 5A198
2C6A at 58604
2C9E at 59158
2C9F at 5916C
2007 E92 335
ST - GTW3684
MT (after swap),
MFactory LSD
jyamona jyamona is offline
Car: 2010 135i 6MT
Default 07-29-2015, 06:17 AM
The reason you need to swap the bytes is because everything in the DME uses LSB (least significant byte first), where as reading the code normally is MSB (most significant byte first) aka. it's even more of a pain in the ass to think this way.
This is also sometimes referred to as LoHi vs. HiLo
Levan-i's Avatar
Default 07-29-2015, 07:35 AM
Thanks Jake,
also take a look at you thread also pls
2007 E92 335
ST - GTW3684
MT (after swap),
MFactory LSD
enrita's Avatar
enrita enrita is offline
Default 07-29-2015, 08:24 AM
What I did:
This and no issues
07 335i AT - MOTIV 750 - MHD BMS E85 Flash - BMS PI - JB4G5 - Okada Coils - NGK 5992 Plugs - Helix IC - Snow Stg. 3 - Stett CP - Custom midpipes with 100 HJS Cats - Bastuck Quad - PSS10 - QUAIFE LSD - BMS OCC - Forge DVs - AR OC - ALCON BBK - M3 Chassi - Dinan CP - Velocity M rear Toe arms - Advan RZ-DF - LUX H8 - Level 10 AT upgrade
marconi118 marconi118 is offline
Default 07-29-2015, 08:58 AM
how to add this to the xdf?
3000GT MR's Avatar
Car: 09' 335i
Default 07-29-2015, 09:17 AM
Thanks now you F'ed me all up. Why couldn't you just leave my simple thought process alone.
Levan-i's Avatar
Default 07-29-2015, 10:37 AM
:D
2007 E92 335
ST - GTW3684
MT (after swap),
MFactory LSD
Car: 2008 135i
Default 07-29-2015, 01:30 PM
Shiv made a video showing how this works. Here's the video link.
http://youtu.be/mA87hWbGaVU
Disclaimer: DO NOT ATTEMPT THIS UNLESS YOU KNOW EXACTLY WHAT YOU ARE DOING
Levan-i's Avatar
Default 07-30-2015, 01:27 AM
thanks to Shiv for the video!
but strange thing is that, values in my bin are not 15th byte but 5th,
maybe it is the difference in IJE0S and I8AOS?
2007 E92 335
ST - GTW3684
MT (after swap),
MFactory LSD
DV135i's Avatar
DV135i DV135i is offline
Default 07-30-2015, 12:29 PM
If you were to do this, would you be able to achieve o2 readiness?
~MHD Stage 2+~3.5 Bar Tmap~PR Ignition Kit~VTT Inlets~VTT Cast Valve Cover~VTT Dual CC~XClutch Twin Disk~BMS Short Shifter~ER Competition FMIC Kit w/ HKS SSQV~3"AR DP's~3" Custom exhaust~Fuel-It Stage 2 Bucket~
Levan-i's Avatar
Default 07-30-2015, 12:38 PM
"o2 readiness"?
whats that?
2007 E92 335
ST - GTW3684
MT (after swap),
MFactory LSD
DV135i's Avatar
Default 07-30-2015, 12:43 PM
"o2 readiness"?
whats that?
Something they check for when you get your car smogged.
quing quing is offline
Car: bmw 335i
Default 02-09-2016, 04:28 PM
Can this be added to the XDF??
Car: 2010 135i 6MT
Default 02-10-2016, 06:51 AM
It is in the XDF. There is now a DTC Master table where you can toggle ANY code.
Car: bmw 335i
Default 02-10-2016, 12:40 PM
Thank you!!
omarmarji's Avatar
Car: n54 335
Default 02-10-2016, 12:59 PM
giving this a try, thx! but snipping the wires from the pins going to the DME, is the necessary ?
751WHP 688WTQ
JP Works Kit Record
SOLD: E90 335i 751whp 688WTQ
prelude2perfect's Avatar
Car: '07 335i
Default 03-23-2016, 07:53 PM
Bump for an answer ^
Keep getting code 2c9f and would like to disable instead of buying a new one
Best 1/4 ET: 11.4
Best 1.4 Trap: 127.7
Torsion Torsion is offline
Car: 335
Default 03-23-2016, 08:03 PM
DO NOT SNIP, The pins can be removed easily with a small screwdriver push in on the side and pull the pin out
omarmarji's Avatar
Car: n54 335
Default 03-23-2016, 09:25 PM
has anyone had problems with this yet? any fuel trim defects?
751WHP 688WTQ
JP Works Kit Record
