gtrsam gtrsam is offline
Car: f80
Default Decrease 1st/2nd gear boost - 04-02-2015, 01:20 PM
How do you decrease boost in 1st and second gear? I recently got the jb4 map2 installed and have no traction all through 2nd. I thought the new firmware decreased it already but still no traction. I logged it in 2nd gear and was recording around 19.3psi. Is this decreased already? Values were at 0
I've tried changing the user adjustment to have max boost 2nd gear to 10psi but it didn't work, which I'm assuming is a decrease of 10psi at 50mph?
HouseN54's Avatar
HouseN54 HouseN54 is offline
Default 04-02-2015, 01:41 PM
http://www.n54tech.com/forums/showthread.php?t=10605
| ProCharged C6 Z06 | Civic-X Si | F30 330i |
Car: f80
Default 04-02-2015, 03:26 PM
Originally Posted by HouseN54
That says that it will limit boost to whatever you set it at. The n55 jb4 says it will decrease the value imputed there. ie, 10 psi should decrease 10 psi vs that link says an input of 10 will hold it at no higher than 10psi. Which is correct??
Reid Reid is offline
Car: BMW
Default 04-02-2015, 03:40 PM
The link provided was relevant to E9x chassis cars.
For the F8x, the input in the field will reduce boost by the value entered.
Default 04-02-2015, 04:13 PM
I use 8 for 1st, 7 for 2nd, and 5 for 3rd. With the s55 boost is reduced by that amount. Since some maps are additive and others absolute this method allows the setting to work for both control schemes.
PS. 3rd gear is coming in the next firmware release.
Car: f80
Thumbs up 04-02-2015, 05:38 PM
Thanks guys. Love the quick support for the jb4. Def a must for f8x cars
morkusyambo morkusyambo is offline
Car: 328i
Default 04-03-2015, 07:16 AM
I dont understand the drivability issues a few claim to be having. Is the only concern ETs at the drag-strip, because the car is still very easy to drive, even with Stage 1 adding 4 psi across the board and conti all season tires.
Default 04-03-2015, 12:24 PM
Easy to drive but hard to drive fast especially in lower gears. Limiting boost really helps.
Car: f80
Default 04-03-2015, 01:58 PM
Yes easy to drive but cannot keep the pedal floored in 1st or 2nd unless you leave traction control on or want to spin. I have advan ad08r tires and 2nd gear traction was non existent. Haven't tested the new inputs yet for the reductions
Default 04-03-2015, 02:17 PM
You should tell these guys they are using the wrong S55 forum. Sputtering in high gear means fuel trims are maxing out. They need to connect FF connector and if its already installed then raise the open loop setting in the JB4 interface.
Car: f80
Default 04-03-2015, 02:21 PM
Told them haha
Car: f80
Default 04-04-2015, 06:01 PM
Went for a test with 5psi decrease 1st and 3psi 2nd and it worked perfectly. I had hardly any spin. Absolutely love the jb4. These are the perfect settings for the street stage 2. I also have advan ad08r tires though so not sure about the OEM pss
rutiger rutiger is offline
Car: f82
Default 04-25-2015, 07:29 PM
Is there any boost limiting enabled for 1st and 2nd by default?
Default 04-25-2015, 09:46 PM
No you need to enable that in the interface.
