MrHaloHalo MrHaloHalo is offline
Car: 2014 X1 35i
Default Map 7 Log Review Request - 09-14-2019, 04:30 PM
After running Map5 for a while with ~E40 fuel and seeing 17psi with 10-12 degrees of timing, I_avg at 0.6, trims at 35 maximum, and fp_h dipping only to 14, I got brave and decided to try Map7.
But first, I mixed in some more ethanol to get up to ~E50, and was able to also mix in some race gas to get the 'base' fuel up to about 96 octane.
Of all things, I forgot to turn off traction control, and you can see the throttle and timing intervention. I think there was enough octane, but trims maxed out and AFR looks real lean in that area. I don't know if that was due to the traction control, or if my fuel pump couldn't keep up? After seeing how lean it was with the maxed trims, I backed off and switched to Map1. Any insightful feedback welcomed.
Default 09-15-2019, 10:01 PM
Ideally we’d like to see some logs w. Traction fully disabled.
Could try bumping up fol to 90 as well, might help bring the trims down a bit .
http://www.fuel-it.biz/
e92 AT 335xi 2.0
Doc Race Kit 6062
