JapSpec JapSpec is offline
Default n54 Single turbo Misfire at high RPM - 09-13-2019, 05:31 AM
i've been having a misfire issue when i pass 6700 rpm. on Map 5
the setup is a 07 335i automamatic
JB4/MHD
JP workz 6266 turbo
BMP port injection with JB4 PI controller
BMP stage 3 LPFP
VRSF Race Intercooler
VRSF Chargepipe
3.5 Tmap BMS harness
BL coil / NGK 2 step colder plug gap to 0.20
Fuel E85
i can see that my LPFP is not that healty i have a new walbro 450 pump coming so ill replace that.
but maybe you guys can see something else what could it be
Default 09-15-2019, 09:55 PM
Does the miss happen on lower boost maps?
Default 09-16-2019, 04:49 AM
no not really on map 2 map 3 is good. map 4 sometimes it does misfire.
Default 09-16-2019, 12:42 PM
Have you tried closing your plug gap a bit? .018
Default 09-16-2019, 07:08 PM
Yes I have now on .018 still same
Default 09-16-2019, 10:10 PM
Misfire might be fuel related, although your HPFP looks really solid up top.
How longs it been doing it?
Could be false Knock too, especially at your boost levels...knock sensors still on?
Default 09-17-2019, 01:23 AM
when you said fuel related. what you mean by that? and is there adjustment I should I change on fuel bias?
itís been misfire since I been running higher boost than 20psi
but if shift it 6500 rpm no misfire anything higher it will.
and yes knock sensor still on.
Default 09-20-2019, 07:25 AM
Fuel related meaning it could be, never rule it out- but as stated your HPFP values look solid & it looks like you’ll be replacing your walbro.
To me it almost seems like it could be false knock causing the misfire
Default 09-20-2019, 07:37 AM
Fuel related meaning it could be, never rule it out- but as stated your HPFP values look solid & it looks like youíll be replacing your walbro.
thanks Dave, i just replace my LPFP it seem to be good now. but Misfire still happen.
is there a way to diagnose the false knock? and what could it be the causing of the false Knock?
Default 09-20-2019, 09:41 AM
What clutch are you using- is it a DMFW?
index injectors?
Default 09-21-2019, 04:51 AM
index injectors?
It's a automatic with xhp stage 3 flash.
Index 12 injectors
Default 09-23-2019, 07:24 AM
We may want to try pulling your cyl 6 injector & swapping it to say 5.
I wonder if your cyl 6 injector flow is off
