breakabolt's Avatar
breakabolt breakabolt is offline
Car: 16vw gti ,n54 swapped e46 wagon
Icon1 n54 engine swapped e46 wagon build thread - 07-03-2019, 09:11 AM
Hello everyone,
I have started to build a n54 swapped e46 wagon.
Please share, like comment, subscribe and check out my YouTube channel for weekly build update.
I'll try to post some of the progress on the thread as well.
Thank you in advance for all your support.
https://www.youtube.com/channel/UC7H...o9zfL4b8JaNiGQ
2001 325ti (e46 wagon)
e46 engine is out
e46 interior is out
2009 bmw 335i, n54 donor car.
335i front end is removed.
mrmax1984's Avatar
mrmax1984 mrmax1984 is offline
Car: E92 335i
Default 07-09-2019, 01:54 PM
Not sure what you're using for a camera, but it might behoove you to get an external microphone like this one:
https://smile.amazon.com/Microphone-...s%2C160&sr=8-8
Since you're filming outside, it would help cut down on ambient noise a bit.
I look forward to this project.
mrmax1984's Avatar
Car: E92 335i
Default 07-09-2019, 01:56 PM
Now would also be a great time to add an oil cooler to the N54, since it's missing the option.
breakabolt's Avatar
Default 07-09-2019, 11:39 PM
@mrmax1984
I'll probably look in to getting an external mic, tnx for the link. I'm planning on adding an oil cooler at some point, before the engine gets settled in to the E46 bay for good. Thank you for the support.
breakabolt's Avatar
Default 07-18-2019, 10:12 AM
N54 engine is in the E46 engine bay. I may have to do few custom modifications in the engine bay. just a few issues, nothing major.
check the link for the video.
https://youtu.be/Vs-SjjUZSls
breakabolt's Avatar
Default 07-22-2019, 09:53 AM
N54 engine is ready for a test fit
N54 in E46 engine bay. engine is sitting a bit too high. got to make some custom mounts or modify the sub frame.
E90 interior is coming out.
Front interior is out.
Default 07-22-2019, 12:50 PM
very cool
http://www.fuel-it.biz/
e92 AT 335xi 2.0
Doc Race Kit 6062
breakabolt's Avatar
Default 07-25-2019, 08:19 AM
check out the video on removing the e90 interior.
https://youtu.be/cfcY9lMqIwc
breakabolt's Avatar
Default 08-01-2019, 09:23 AM
Took the interior off of the E90. Got the wiring harness out and labeled, I got to thin out the harness by removing unwanted stuff and swapping it over to the E46 body. It is quite time incentive to take it apart and document. The harness and everything looks intimidating. The dream of swapping E90 interior into E46 may be a little far fetched. But, hey at least others don't have to guess if its possible or not. I'm still rooting to swap the front interior and try to make it look stock. fingers crossed.
check out the video on YT
https://youtu.be/SYOtGfaz1TU
breakabolt's Avatar
Default 08-15-2019, 09:30 AM
Finally I was able to jump back on to the E46 and build instead of taking things off.
Started the first part of reinforcing the rear sub frame mounting points.
Check out the video on Youtube.
https://www.youtube.com/watch?v=4_qHWlsBXAk
breakabolt's Avatar
Default 09-12-2019, 10:08 AM
Got around to install the VinceBar rear reinforcement kit.
I hope the E46 wagon rear end is able to handle up to 1000whp with both
reinforcement plates and Vinces bar installed. I'm not planning to gain that much hp. my goal is to get 400hp and around same amount of torque.
check out the install video on youtube.
https://youtu.be/f-5Fvf_6XVw
datbimmer datbimmer is offline
Car: E92 335i
Default 09-13-2019, 12:13 PM
Nice looking forward to seeing this project completed.
breakabolt's Avatar
Default 10-01-2019, 10:32 AM
breakabolt's Avatar
Default 10-01-2019, 10:46 AM
Started working on a budget Big Brake Kit setup, its taking some time due to R&D.in the mean time replaced the CSB (center support bearing) on the m3 drive shaft
check out the video on Youtube.
https://youtu.be/AofgO3FQLMM
new csb bearing
make sure to mark a line on both sides of the driveshaft to make it easier to put it back together. the driveshaft is balanced from factory. It is important to keep the orientation as it is. Use a 18mm wrench and a prybar or a big flathead for leverage and remove the inner bolt.
use a pulley puller to remove the bearing.
breakabolt's Avatar
Default 10-04-2019, 04:20 PM
Got around to concentrate on brakes. I was able to retrofit E90 335i front brakes and E46 M3 rears in to E46 wagon.
It looks easy but had to do quite a bit of R&D to get it going. hopefully it'll help others to do the retrofit and gives them a starting point.
You can check out the how-to retrofit 335i calipers on to E46
https://forum.e46fanatics.com/showthread.php?t=1263569
or check out the youtube video on
https://youtu.be/eiacEuYc56M
as always, subscribe, comment, like and share.
stock 325i vs 335i brake setup
