(#126)
biochembro biochembro is offline
Car: E92
Default 02-22-2019, 09:26 AM
Do these accept 48.5mm 60lb LS3 EV14 injectors
Car: E92
Default 02-22-2019, 10:52 AM
also Do you need the “basic” fuel-it upgrade for the line and adaptor?
Default 02-22-2019, 01:27 PM
I used LS7 injectors on mine, IIRC they're the same.
Basic kit, is just the intake manifold, fuel rail, and hardware.
You can also purchase with injectors and fuel line kit.
ifjd073's Avatar
ifjd073 ifjd073 is offline
Car: 2007 BMW 335 (E90)
Default 02-25-2019, 11:10 AM
Quick question, are the gaskets (o-rings) for the manifold the same size as stock? If not, do you know the size so that I can source some for my next walnut blasting?
'07 335 sedan, Stage 2 VVT, VVT inlets/outlets, VVT DCI, Phoenix CP with Tial BV, 3.5 bar TMAP sensor, Spec twin disk clutch with SMF, BMS OCC, RB PCV valve, ***less ***, VRSF catback with Vibrant *** installed, ETS 5" intercooler, Fuel-It stage 2 fuel pump, Fuel-It 650HP LPFP upgrade with 525 pump, JB4 with custom Trebila BEF, Phoenix PI intake manifold /w 550cc injectors, Fuel-it fuel lines, ethanol sensor and analyzer
Default 02-25-2019, 11:15 AM
Email us and we can send you a set for $20.
Ours are made for ethanol/methanol properties, and high temp.
mattgu40 mattgu40 is offline
Default 04-08-2019, 01:21 PM
Anyone had clearance issue between cyl 1 runner and filter housing bolt
Default 04-08-2019, 01:37 PM
We've only had one issue so far crop up, he said he had to file the bolt a little.
Do you have any pictures you can email me? Payam@burgertuning.com
WOT808 WOT808 is offline
Default 07-02-2019, 07:43 AM
Have you seen any HP / Flow gains with these manifolds @BMS?
Default 07-02-2019, 10:49 AM
I've tested 3 intake manifolds that are out in the market and non of them have showed any gains. This is more for integrated PI as well as an aluminum intake manifold.
You don't want it to blow up like this during a 1/2 mile race event
Default 07-02-2019, 11:14 AM
What caused your manifold to split?
My stock manifold shattered on a 3 to 4 shift.
Default 07-02-2019, 01:35 PM
Backfire + lots of boost ruined my track day! =/
chadillac2000's Avatar
Car: 2008 535i
Default 07-25-2019, 07:11 PM
I've had mine on for 35,000 miles now with no issues to note. Seems to be holding up great.
datbimmer datbimmer is offline
Car: E92 335i
Default 09-13-2019, 11:47 AM
Phoenix accidentally sent us an aluminum N54 intake without the port injection ports. Good for doing something custom, just a stronger higher flowing replacement, etc. Willing to part with it for $500 shipped.
You don't happen to still have this one do you ?
Default 09-16-2019, 11:41 AM
No, sold a long time ago.
