(#201)
rkreimer10 rkreimer10 is offline
Car: 08 535i
Default 11-23-2018, 02:21 PM
Well I am back at it, trying to get some things finished before the end of the year.
N55 PR coil kit...
I made sure all the pins were seated properly, then installed the water seal. Some pins were pushed out when installin the clips.
I also started the dynamic drive and active steering removal!!!
Lines to the rear draining...
All the dynamic drive lines removed
All that nonsense is being replaced with just this. lol
Active steering rack is next....
Should have it wrapped up before the weekend is over...
Car: 08 535i
Default 11-23-2018, 02:32 PM
I found some leaks while getting into this project.
front cover...
My rear turbo drain line had oil pooling on the anodized fitting, still unsure of where it is coming from.
My oil pan gasket is not leaking but I am going to replace that while the subframe is off. and I also have index 12s to finally install, bank 1 has a leaky injector...
Car: 08 535i
Default 12-07-2018, 05:27 PM
So now that I have the dynamic drive removed from the car I am looking into m5 rear swaybar and m5 pullrods.
Pull rods are ordered. and about to pull the trigger on an m5 rear sway.
I also developed a cylinder 6 misfire while trying to log. Seems to only happen with mhd stage 2+ installed. flashed dme back to stock and no more misfire. hmmm
Wish it wasn't so cold out, hopefully it will not be a long winter.
Car: 335i, 2009
Default 12-07-2018, 05:47 PM
Nice build! Looking forward to seeing more.
JB4 ||| H&R Sport Springs
X5 50i 2013 ///M Sport
BMS Stage 1
BeatupVR4 BeatupVR4 is offline
Car: 2003 Forester
Default 12-10-2018, 05:24 AM
Not sure if I mentioned this but I run a M5 rear bar ($100) and H&R's on my X-drive and think it's a great setup for daily use. One thing to look at though is the Dinan M5 rear bar. It's only $190
https://www.ecstuning.com/b-dinan-pa...d120-0491~din/
Car: 08 535i
Default 12-14-2018, 04:28 PM
Back at it today. I installed my m5 pullrods and cut my engine cover to fit.
Here are the list of parts needed.
You will need (4) of #16 ; (2) of #15 ; (2) of #17
Engine cover pics.....
The car is running very well, minus the fact that it never seems to want to warm up. I am about to make a post about it. But otherwise all is good in the hood!!!!
Car: 08 535i
Default 12-15-2018, 03:37 PM
I have deemed the reason the car does not want to warm up is the coolant t-stat is bad. you can read all about it here.....
https://www.n54tech.com/forums/showthread.php?t=56185
I also have had a louder than normal tick that is harmonious to the injectors, but definitely not the injectors. I found that the issue was due to my lifters not getting sufficient oil pressure. You can read about how to bleed the hydraulic lifters here...
https://www.quirkyuncle.com/2013/04/...yVktJNi65ORsAk
I also decided to do a compression test to see how things are holding up. here are the results...
Car: 08 535i
Default 09-11-2019, 01:47 PM
Anyone have a wiring diagram? lol
If you ever have to do a heater core......burn the car. lol
y0itzflip y0itzflip is offline
Car: e60 535i
Default 09-11-2019, 05:44 PM
oh no. what led to this?
Car: 08 535i
Default 09-27-2019, 08:29 AM
Parting out a few e60s and needed to pull the heater core to get the front carpet out. Never want to do that again. Lol
CaptainMorgan535i CaptainMorgan535i is offline
Car: 2010 e60 535i
Default 11-29-2019, 02:25 AM
Any new updates? Love seeing the time and work you've put into your 535.
E60 535i. Cobb Tune. BMS DCI. RB PCV. VRSF meowless p1pes. Vogtland Coilovers. Stock chargepipe
E46 M3. SMG to 6 speed. Koni yellows. Apex Arc 8's. Beisan systems Vanos overhaul.
Car: 08 535i
Default 01-09-2020, 04:12 PM
Yes , there have been a few. I cannot wait to update this thread. I have done CIC & Logic7...I may do HUD, not sure tho, I want something more updated...
I just rented a shop!!!!!
So now I can take on real projects......Like this one!!!!!!!!!Stay tuned..e60s are about to go Single!!!!!
Car: 2003 Forester
Default 01-10-2020, 06:05 AM
And by the looks of it you even mean for us X-Drive losers!
Car: 08 535i
Default 01-10-2020, 09:44 AM
The xi is a whole problem in its self. Lol. But I am working on it. A few more problems to solve and I should be throwing it on my 535i.
Car: e60 535i
Default 01-10-2020, 06:16 PM
ive been waiting for this day. still babying the car around town on my old oem turbos since i want to go single.
Seven11 Seven11 is offline
Car: 535i
Default 01-15-2020, 03:32 PM
my turbo or turbos went. i gave the car away. No garage and living in San Francisco, CA parking is a no go. Also nobody would touch it under $3000 to change turbos. Plus all bent wheels, and steering rack making noise, plus much much more. I just gave it away for free.
here is the best part. Leased a new 2020 M340i in september and I just lemon law'ed it.
- BMW 535i - Sport - Sport Auto - JB4 G5 ISO - DCI - BMS E85 BackEnd via MHD - 19in M6 Wheels -
- Suzuki GSX-R750 - Akrapovic Titanium Exhaust - Mirror Block-Offs - WoodCraft RearSets - Yoshimura Frame Sliders -
