(#226)
panaceabeachbum panaceabeachbum is offline
Car: 435, 540, z4, 745
Default 05-12-2019, 05:54 AM
I just received the complete f32 meth kit from Burger, no relay included and absolutely no mention of a relay needed anywhere on your site or in the instalation instructions.
In fact the PDF says to extend the yellow wire and connect directly to the pump.
Common sense says the yellow wire is just a low current trigger wire for a relay but might be a good idea to incorporate this into the instructions and possibly include a $3 relay when selling a complete kit. just my .02
miller335i miller335i is offline
Car: 2007 BMW E90 335i
Default 06-06-2019, 03:16 AM
https://ibb.co/02cspw2
Does anyone know what meth tank will fit into this cavity (PRe-lci BMW 335i sedan) and be flush with the top? Thanks!
Fredm21 Fredm21 is offline
Car: Bmw 335i 2007 N54
Default 06-06-2019, 03:35 AM
Does anyone know what meth tank will fit into this cavity and be flush with the top? Thanks!
Do you have a 335i n54?
-07 335i coupe
BMS charge pipe
Turbosmart BOV
VRSF down pipe
BMS WMI with single nozzle ( 10 )
JB4 map 3 w/bluetooth & antiliag
Afe intake filter
BMS intercooler
BMS tranny cooler
BMS Double baffle catch can
MHD BEF Racegas
Precision Raceworks Coil
-Running 91 octane with WMI
Default E90 trunk mounted stealth tank - 06-06-2019, 04:42 AM
Yes, question updated, thanks!
Default 06-06-2019, 05:08 AM
There is no tank that will fit there for the 335i n54. Get the biggest one from burger and bolt it on top in the trunk. I will get you a picture of mine later.
-07 335i coupe
BMS charge pipe
Turbosmart BOV
VRSF down pipe
Afe intake filter
BMS intercooler
BMS tranny cooler
MHD BEF Racegas
Default 06-06-2019, 05:24 AM
BMS makes some other stealth tanks that might fit I just don't have access to them, nor 100's of bucks needed to try to dry fit them. Has anyone tried? I need to have this flat in the trunk or my lifespan will be greatly shortened! Those who are married will understand. I'm willing to cut the plastic/modify it to give it more room to accept the best tank combo. Thanks!
Default 06-06-2019, 05:27 AM
BMS makes some other stealth tanks that might fit I just don't have access to them, nor 100's of bucks needed to try to dry fit them. Has anyone tried? I need to have this flat in the trunk or my lifespan will be greatly shortened! Those who are married will understand. Thanks!
Terry could confirm but they only make them for the F series
-07 335i coupe
BMS charge pipe
Turbosmart BOV
VRSF down pipe
Afe intake filter
BMS intercooler
BMS tranny cooler
MHD BEF Racegas
Default F series - 06-06-2019, 06:17 AM
...and the 5 series as well. It is a fit issue for me not that it was made for the correct series. I would happily graft a F30 trunk bottom into my E90 sedan if I could confirm it would work to put the F30 tank back there!
Treedirty5's Avatar
Treedirty5 Treedirty5 is offline
Car: 07 bmw 335i Coupé
Icon1 BMS WMI 1 Gallon bottle problems - 09-03-2019, 04:55 AM
Has anyone encountered any problems with the 1 gallon water bottle. I’ve
Tried everything and it still leaks. I believe it should have came with some
Sought of grommet I purchased it from BMS any help would be greatly appreciate.
