j3vr6 j3vr6 is offline
Car: 2016 340i RWD
Default Does a Trans flash work with JB4? - 05-01-2019, 01:40 PM
Seen a few places offer transmission flashes. Wanted to know if those flashes could be used if you have a JB4?
Default 05-02-2019, 09:40 AM
Yes, they have nothing to do with each other.
Car: 2016 340i RWD
Default 05-23-2019, 03:24 PM
Do you all have any recommendations on which to go with?
imsorussian imsorussian is offline
Car: 2017 BMW 340i Xdrive
Default 06-01-2019, 02:55 AM
I just did X-HP trans flash on 2017 340i. Wow. Shifts are lighting fast. I didnt bother with stage 1 and stage 2. I went straight for stage 3 racing set up. It drives smooth in comfort, but once you put in sport+ wow. And it sort of rev matches on downshifts. You feel those hard kicks, i love it
luchocamp's Avatar
Default 06-01-2019, 03:30 AM
XHP stg3 flash is a nice upgrade
10.64 @129mph, MHD Custom + #LUCHOJB4, E40 + meth ~ Drag Track online set up on instagram @luchocampusano ➡
BazBar's Avatar
BazBar BazBar is offline
Car: UK 140i-M Sport Auto
Default 06-27-2019, 03:09 AM
I am looking at installing the the xHP on my 2017 140i, i was reading the install instructions and i says you have to uninstall your JB4 before you install the xHP trans flash, did you guys do this ?
Default 06-27-2019, 05:13 AM
No I didnít uninstall JB4.
BazBar's Avatar
Default 06-27-2019, 05:32 AM
Ok, I will give it a go tonight, Have you played around with the Torque settings yet or just left it as standard ?.
Default 06-27-2019, 05:46 AM
Didnít play with torque yet. And i skipped stage 1 and 2 did stage 3 and its a beast
dRDiesel's Avatar
dRDiesel dRDiesel is offline
Car: BMW
Default 07-01-2019, 07:40 AM
What exactly does the torque setting do?
BazBar's Avatar
Default 07-03-2019, 02:40 AM
Looking at the instructions you can change the torque setting for each gear, you can also change when in the RPM band it changes gear, not tried it yet but will at a later date, I also am running on the race settings (MAP 3) i like the way it drives in NORMAL D MODE, and when you change to SPORT MODE it really Kicks BUTT...
So far so good all round, plus its easy to use just like the MHD BEF flash, they are both working well together, now i have my Quaife diff fitted it totally transforms the way the car drives/handles, just love it
CntryClub007's Avatar
CntryClub007 CntryClub007 is offline
Car: F30 340i / E70 X5-35i
Default 07-05-2019, 06:32 PM
I have the XHP Stage 3, the transmission is a beast now. Not that I ever use the gauges in iDrive, but I thought it was interesting that these show some highly unlikely max values of 640hp and 640tq, with current values of 520hp and 640tq. Ya, donít think those are correct or where those came from. Let me know if you have any questions on XHP.
BazBar's Avatar
Default 07-17-2019, 02:10 AM
Update on the xHP flash, been getting some limp mode fault codes pop up.
1F0541 - DME: internal fault (engine torque implausible).
1F052F - Drive Safety Function: Acceleration reduction.
I get this when i am in high gear and accelerate hard, i suppose its under full load when this happens.
Any one else get this ?
viperstang1 viperstang1 is offline
Car: 340i 2016
Default 08-28-2019, 06:31 AM
Just got the same code. Is there a fix for this? 1F0541
JBoe JBoe is offline
Car: M240i
Default 08-31-2019, 08:11 PM
Your posting questions in a forum that isn't monitored by XHP. It's also relatively new, so fee members have experience with it. Best option would be to contact manufacturer (XHP) directly. Please let us know what they say as there are many looking at this upgrade... Myself included. Thank you and good luck.
