(#11526)
faffo faffo is offline
Car: E93 335i
Default 11-20-2019, 03:13 AM
Originally Posted by dmckmc
If you are outside the USA the JB4 can be used to keep the CEL clear. In the USA I believe you will have CEL on any map as you are removing emission hardware. Any 'fix', however you see it advertised, is simply a cover up and will only hide the code from YOUR view. If your state has tight emission inspections, your car will fail because it will likely never reach a state of emission 'readiness'. There are many threads in this and other BMW forums about this topic and can be overwhelming to sift through them. PM me and i'll share what I can to help.
thanks for the reply, i'm from Italy, i'm not worried about emission inspections, i will reinstall the cats when i have to do inspections. i prefer to not hide the CEL, i want to "tell" at the lambda that the values she read with *** are correct
fazman fazman is offline
Car: e90 FBO
Default Latest Interface download - 01-06-2020, 11:50 AM
Hi @terry
I must be blind or something, because I can't find the link any more for the latest Interface. Could you or someone point me to where that is now posted on your site?
I was able to grab the latest firmware... but for the life of me I can't find the latest interface files
UPDATE:
Nevermind... I think I found the "files section here" --> Index of /flash_files
nz92's Avatar
nz92 nz92 is offline
Car: E90 BMW
Default 01-09-2020, 07:01 PM
Originally Posted by THE BEAST
No luck on gauge sweep ?
Whats wrong with the sweep ? is it gone in the latest update ?
Default 01-15-2020, 09:18 AM
G5_ISO_32_15 BETA
1) Adjusted CANbus to take select channels via passive CANbus rather than active. The passive channels include RPM, pedal, clutch position (for manuals), and brake position. The change allows for faster sampling of those channels and frees up CANbus bandwidth for some new active channels we'll be adding soon.
2) As part of this change manual transmission vehicles using the NLS relay no longer need the JB4 clutch wire installed. It does not need to be removed but in the future won't need to be installed. We will be updating our site to reflect the change.
3) As part of this change we've opened up an additional analog input which can be used by customers running WMI, PI, and flex fuel. Email me for details on how to set it up.
4) This firmware is BETA so if you have any issues you can roll back to the previous version and/or email us for assistance.
Default 01-15-2020, 12:00 PM
G5_ISO_32_15 BETA
So now in theory can we have a signal return from PI and Meth for users that are running both?
Default 01-15-2020, 02:00 PM
Correct
