Immaculate Immaculate is offline
Car: 11' 135i
Default LPFP question - 05-17-2019, 05:20 PM
Since install of my Fuel-it stage 2 on my E series N55 I am getting the yellow lift symbol that will come and go. Will appear under 50% or so throttle then dissapear when less. At idle jb4 is reading around 10 fpl and the HPFP sits a 6 so that does not seem to be an issue. Cranks amd starts just fine.
Any opnions why? I was planning on putting the stock pump back in to see if it appeared as it did not before. Figured I should see if there is something I am missing before I do that.
Weehe Weehe is offline
Default 05-20-2019, 08:29 AM
It's probably the high current issue a lot of people have. There is a post in this board by Torr explaining how to code it to fix it.
Car: 11' 135i
Default 05-20-2019, 09:50 AM
Found the thread. Looks like that is what I am experiencing. Thank you!
