Car: B46 F56S
Default Flash+JB4+Meth. Adjusted Safety Map Request - 04-06-2019, 02:56 AM
Car: 2016 Mini Cooper S (F56/B46)
Flash: Dervtech
JB4: Map 4 or Map 0 (Disabled)
Meth: BMS Kit
I just wanted to request an adjusted safety map so I can use my JB4 to run my meth kit and to have it monitor in the background for safety features.
Theoretically, right now if the JB4 bumped to the "safety map" it wouldn't do anything beneficial as the ECU is tuned. Is it possible to trigger a "False Limp" when safety hits? Ex: AFR Lean, Boost Over Safety, Fuel Pressure Low, etc.
Not too concerned about meth low safety as I chose not to tune for meth.
I have attached some logs of the flash map with and without meth.
Thanks in advance!
Default 04-06-2019, 11:18 AM
Just set all map6 values to 1psi and run map6, should do what you want.
Car: B46 F56S
Default 04-07-2019, 02:08 AM
Will do.
What happens when safety hits?
Wouldn’t it just bump to Map 4? Which still is the tuned map.
Currently running Map 4 right now anyway.
Default 04-07-2019, 08:15 PM
We can adjust the firmware so map4 is a low boost valet map, then you'd use map0 for flash only, so when you safety you wind up making less than flash boost.
Car: B46 F56S
Default 04-08-2019, 02:06 AM
Thanks. Valet Map 4 sounds like a good solution.
How can I move forward with this?
Appreciate the time.
Jay1312 Jay1312 is offline
Jay1312
Car: BMW 320i and M5
Default 04-08-2019, 10:09 AM
Can the valet firmware be posted here please as I would also like to test.
Default 04-08-2019, 01:31 PM
I'll have to write it. Will try to get to it this week and post it here for you guys to test!
Car: B46 F56S
Default 04-10-2019, 04:10 AM
Thanks Terry. Will standby.
Valet sounds like a great idea to also hide the flash map during dealer service test drives so they aren’t slammed with unexpected power.
