(#826)
Default 02-01-2019, 04:27 PM
Working on anti-lag to improve brake boosting for automatics. One of our customers first test videos attached.
Car: 09 E90 335i Msport
Default 02-02-2019, 08:40 PM
Holy boost build! This gonna be huge! Well done Terry!
Can't wait for it to be all set to run!
ClintBeastwood ClintBeastwood is offline
Car: 2009 e90 335i
Default 02-02-2019, 11:53 PM
Originally Posted by ClintBeastwood
Just to clarify
I have a Jb4 g5 purchased new in Nov 2018. Do i need the anti lag chip and wiring or wiring only?
Default 02-03-2019, 12:01 AM
Doesn't matter what you have. You need the chip, wiring and the latest back end flash.
Car: 2009 e90 335i
Default 02-03-2019, 09:48 AM
Thank you
E9x_raphy E9x_raphy is offline
Default 02-03-2019, 01:36 PM
The JB4 (Launch Assist) lol is going great feels like it's oem
Default 02-03-2019, 01:46 PM
Making good progress, need a few testers.
With the default JB4 BEF setting is works, and you get a nice popping out of the exhaust when doing it. But we've found revised settings on the BEF make the launch even harder, but you sacrifice the noise a bit. We'll probably try to make that end user adjustable.
For now though need a few people to help test it out. Drop me an email if you have time. For it to work you'll need the JB4 anti-lag kit installed and active, and the BEF loaded. If rolling anti-lag is working OK for you now then you're ready to go on testing the launch anti-lag.
Default 02-03-2019, 01:54 PM
JB4 Automatic launch anti lag tests 1 - YouTube
Here is a test hit I tried recording
Default 02-04-2019, 12:37 PM
That's on the -35 degrees right? The -35 gives a smoother higher boost launch but you don't get the brap-brap-brap I now many of our automatic customers want.
When it dries out I'll also make a few videos on our 135i automatic to showcase the differences.
Default 02-04-2019, 08:32 PM
JB4 ANTI-LAG LAUNCH ASSIST TEST 3 - YouTube
So another quick test to bad i can't launch it because of the weather
Default 02-04-2019, 08:45 PM
Sounds pretty wicked!
Once the weather clears out I can't wait to see some better videos.
psixtc's Avatar
psixtc psixtc is offline
Default 02-05-2019, 11:12 AM
If you're looking for more testers towards the end of this month, I'd love to help out. I would love to see how this works with my 6466, but need to figure out my XHP issues before hopping on board.
Evil1 '08 135i 6AT with a few go fast bits...
Default 02-05-2019, 08:07 PM
Here is another video of the latest changes feels great and works 100%
Default 02-05-2019, 08:09 PM
Making good progress. Basically to get the pops and bangs along with the hard launch, the anti-lag + 2TEP relay will be required. I think you can get most of the performance benefit without the noise with the anti-lag only though. Waiting for the weather to dry out here so I can do some better testing!
Default 02-07-2019, 09:55 PM
For those testing the new JB4 automatic anti-lag, found a bug in the firmware breaking the stealth boost gauges. Will fix in the next test version.
Also, updated the BEF maps to reflect -36 timing during anti-lag, works a little better.
AnilKram AnilKram is offline
Car: 09 135i
Default 02-07-2019, 10:25 PM
I did the update, but my step still sounds like it used to. What could the issue be?
09 135I MT jb4 g5/MHD Trebila backend Frankenturbo F21 FBO, PI, stage 3 lpfp, full E85, Quaife LSD
Default 02-08-2019, 02:18 PM
Latest automatic test firmware and directions below.
To do this you'll require the latest BEF (we posted updates the other day), anti-lag wire, and if you want to 2STEP also then the 2STEP relay. The clutch wire from the 2STEP relay obviously doesn't need to be installed.
Worth noting for rolling antilag+2step mentioned in video, you have to use the foot brake to engage the antilag or it won't register the 2step request on channel down.
Default 02-08-2019, 02:19 PM
Post a log of the 2STEP so we can see if anti-lag is engaging.
psixtc's Avatar
Default 02-08-2019, 04:03 PM
I noticed in the video you mentioned the 1st gear boost setting to 10psi, which would be your target for anti-lag.
Out of curiosity, would this feature work for those of us that launch in 2nd gear if we adjusted the 2nd gear boost settings down to a reasonable level?
Default 02-08-2019, 04:24 PM
Yes should work same way. It's early days so test it out, provide logs, and let's evaluate!
Car: 09 135i
Default 02-08-2019, 05:22 PM
Thanks terry, my rolling antilag works. I also have a trebila tune. I didnt know the foot brake needed to be engaged. I was doing it the old way with a manual, clutch in and full throttle. I guess same thing just have to be quick with the gas/brake foot lol
Default 02-08-2019, 05:32 PM
Have him adjust the offset to -36 degrees in it also.
For manual anti-lag engages off volume bottom since you won't have a 3rd foot.
Car: 09 135i
Default 02-08-2019, 11:17 PM
Thanks Terry I'll let him know and have a log for you
Default 02-09-2019, 11:43 PM
Loving the new rolling anti lag
trebila's Avatar
trebila trebila is offline
Default 02-10-2019, 03:24 AM
Done, you can try and log to evaluate
