Stoolz Stoolz is offline
Car: 11 135i
Exclamation Dct M4 Flywheel Installation - 09-01-2018, 02:47 PM
Guys, my car has been plagued by an issue ever since my M4 flywheel went in, well there's certainly been other bumps in the road but I'm pretty certain the latest coincided with my flywheel replacement.
My question is can the swap been done incorrectly??
It seems like maybe my crank angle sensor is involved with the issue.
I dont have my original fw it was binned by the installerand the car is in a different shop now.
Cheers!
Default 09-01-2018, 09:37 PM
What codes, exactly?
Car: 11 135i
Default 09-01-2018, 10:52 PM
Weird codes that dont make sense, ecu fueling and knock but logs show all is fine and the car isn't actually knocking.
We have now swapped the crank angle sensor and the problem is actually worse. I think it's open circuit code (but it isn't open circuit and the wiring harness looks fine. I'm the Aussie dude who emailed you, we decided to push my car off a cliff lol!
Ferrora66 Ferrora66 is offline
Car: BMW 135i
Default 09-18-2018, 01:58 AM
I installed the Mfactory flywheel on my n55 last week. I used to experience the random misfires at high rpm before installing the flywheel. Since I've installed the flywheel, my car has been misfiring a lot earlier (around 4500rpm) at any boost level past 22psi. I've also been experiencing drastic timing drops, not sure what's causing that. I'm not sure if the flywheel is to blame for all this but my car was definitely in a better position before the flywheel swap. I am running a gtx35 turbo.
Default 09-18-2018, 05:11 AM
I’m running s55 flywheel dct no knock or codes.
houtan houtan is offline
Default 09-18-2018, 06:35 AM
Have you contacted mfactory? What tune are you running?
Car: BMW 135i
Default 09-18-2018, 12:43 PM
Wanted to know if anyone is experiencing the same issue with the mfactory flywheel before I contact them. Running jb4 with custom mhd backend
Car: 2011 N55 135DCT
Default 09-19-2018, 01:07 AM
I just rather got the m4 dct flywheel
Car: 11 135i
Default 09-19-2018, 04:36 AM
It looks like the M4 fw after inspection is installed correctly and not the issue. My car is driving me nuts.
Default 09-19-2018, 05:02 AM
Maybe those stiffer mounts
Car: 11 135i
Default 09-19-2018, 05:59 PM
Yeah it's possible mate
Default 09-19-2018, 06:31 PM
Do you have issues if you run the stock flash with no jb4?
Car: 11 135i
Default 09-19-2018, 11:31 PM
I have the issue no matter what, even completely stock. No jb4 no mhd. With jb4 i could make a 1 psi map 6 and still have the problem.
I spoke with my mechanic, even tho hes at his give up point he doesn't believe its my engine or trans mounts.
Car: BMW 135i
Default 09-20-2018, 02:46 AM
Why donít you send the car to the agents in stock form. They might be able to pick up the fault
Car: 11 135i
Default 09-20-2018, 02:02 PM
Why don’t you send the car to the agents in stock form. They might be able to pick up the fault
Yes, airbag recall needs doing, I think its my only option. Edit, ..but i called the shop to send it to bmw, they've ordered a whole new wiring harness already, going to try that first.
Default 10-01-2018, 01:18 PM
any luck?
Default 10-01-2018, 01:21 PM
Any luck
Car: 11 135i
Default 10-02-2018, 12:59 AM
They got the injector harness accidentally instead of the actual ecu harness. My life story really.
Car: 11 135i
Default 11-10-2018, 01:33 PM
Update, cars been at dealer, showed a vanos motor code, they replaced it plus the entire wiring harness. No good. Dealer gives up, thinks it might be ecu but weve already done that way back, car being sent back to my local shop to look like a barn find for a while again.
Default 11-11-2018, 03:00 AM
Anyways. I installed my m4 flywheel and can now run 26 psi to 7000rpm no missfires on my GTX3576R on my e82 n55 dct. Thank you Pure
Default 11-11-2018, 03:01 AM
Still running the bms Pump flash with low timming.
Car: 11 135i
Default 11-11-2018, 04:00 AM
That's awesome news mate.
What kinda power are you puting down?
Default 11-11-2018, 04:11 AM
600hp buddy. But im at 5500ft elevation
Car: 11 135i
Default 11-11-2018, 09:56 PM
That must be one hell of a fun car to drive
Default 11-12-2018, 12:34 AM
Yes it is very. Timming still low. Busy with more timming.
