psbrennan psbrennan is offline
Car: e92 335i AT
Default MMP1k Turbos Log - 08-03-2018, 03:34 PM
Just had my MMP1k's w/ inlets and outlets installed. Did a light pull on map 2 and was hoping for some feedback.
Thanks in advance
-Patrick
2007 e92 335i AT - MMP1k's, MMP inlets/outlets - VRSF ******* **, FMIC, CP w/ Tial BOV - AFE Magnum DCI - TMAP 3.5 Bar - Fuel-It Stage 2 bucketless pump - WaveTrac LSD - JB4 g5 - MHD BEF
Default 08-03-2018, 03:55 PM
No full throttle in the log. If you have another thread be sure to keep all runs together in the same thread, too. Also if you later decide to email us for help just include a link to the thread so we can reply there. To avoid doubling up work.
Car: e92 335i AT
Default 08-03-2018, 06:18 PM
Sorry about that. This one should have a full throttle pull. I can do another/longer pull tomorrow if it would help. Thanks for your patience!
-Patrick
N54QC N54QC is offline
Car: 07 BMW 335i
Default 08-03-2018, 09:16 PM
-Patrick
You need to go WOT from 2500 to redline in 3rd, then post.
Car: e92 335i AT
Default 08-04-2018, 08:20 AM
Sorry about that. Attached is a WOT pull from 2500rpm in 3rd as requested. If you dont have enough relevant data from this log i have another i can upload as well.
Thanks,
Patrick
Car: e92 335i AT
Default 08-04-2018, 08:42 PM
Does that log work?
XXXDrive XXXDrive is offline
Car: 2010 E92 335
Default 08-04-2018, 08:55 PM
Not a pro but you should enable 6 cyl timing logging in the user adjustment tab so the guys can see timing on all cyl
Car: e92 335i AT
Default 08-05-2018, 06:05 AM
Thanks for the advice. Do you know which key value I should be entering? (1-6?)
Car: e92 335i AT
Default 08-05-2018, 02:49 PM
Terry, were you able to review my logs above?
Thanks,
Patrick
Default 08-05-2018, 10:23 PM
Thanks,
Patrick
Boost is way over target- which is why you got thrown into map 4/safety.
Letís do this:
Set DB to 50 across the board
Enable 6 cyl logging
Relog
http://www.fuel-it.biz/
e92 AT 335xi 2.0
Doc Race Kit 6062
Car: e92 335i AT
Default 08-06-2018, 06:45 AM
Awesome, thanks for the feedback. So once i set the DB to 50 should i leave it on map 6 then? Also for the 6 cyl logging what value (1-6?) do i set it to specifically?
Thanks,
-Patrick
Default 08-06-2018, 07:40 AM
Thanks,
-Patrick
6 cyl logging is DME dependent, i beleive its “4” if I8A0S” and “5” for IJE0S
Let’s stay on 2 for now, once boost is closer to target, we can move up progressively
e92 AT 335xi 2.0
Doc Race Kit 6062
Car: e92 335i AT
Default 08-09-2018, 11:44 AM
Sorry for the delay, haven't had a chance to take it out lately...
Log attached with a 3rd gear 2500rpm pull on map 2 with 6 cyl logging and DB set to 50 across the board.
Still on stock pump as the Stage 2 bucketless will be going in this weekend.
Please let me know if additional logs are needed and the next steps.
Thanks,
-Patrick
Car: 07 BMW 335i
Default 08-09-2018, 06:38 PM
Thanks,
-Patrick
You're in map 4. Switch to map 2 and re-log.
Default 08-09-2018, 11:47 PM
Thanks,
-Patrick
This looks like a map 4 log, basically stock.
Throw it in map 2 & re log
e92 AT 335xi 2.0
Doc Race Kit 6062
Car: e92 335i AT
Default 08-10-2018, 08:32 AM
So it seems i keep getting kicked from Map 2 to Map 4 when attempting these 3rd gear 2500 to 6500 pulls. Attached is my most recent log from this morning. Started off in Map 2 and all seemed well until i got to around 5k and then that's when it dumped me into Map 4.
Please have a look and let me know what i need to change.
-Patrick
Car: e92 335i AT
Default 08-10-2018, 01:09 PM
Here is another log for good measure. Looks like i was able to stay in Map 2 during the entire run.
Let me know if this log and the one before are good enough to recommend any adjustments.
Thanks all.
Car: 07 BMW 335i
Default 08-10-2018, 07:17 PM
-Patrick
You are still overboosting and is why you kicked into map 4. Lower FF to 70 and see what happens. Might have to do some DB changes also. IMO I would change your boost safety to 21 since logs don't look to bad for current boost levels and will help alleviate the map change so there is a consistent map 2 log. Do you happen to have E85 in your area? Noticed you have a stage 2 lpfp, would help timing corrections if you could add ethanol in the tank plus your current lpfp pressure is coasting close to 50.
Default 08-12-2018, 02:55 AM
Thanks all.
I donít see a log attached?
e92 AT 335xi 2.0
Doc Race Kit 6062
Car: e92 335i AT
Default 08-14-2018, 03:29 PM
Latest Log attached.
**still on stock fuel pump. Upgrading to Stage 2 bucketless this weekend.
Please let me know how the logs look.
Thanks,
Patrick
Default 08-15-2018, 12:02 PM
Looks very healthy to me. Once that Stage2 comes in you can really turn it up!
Car: e92 335i AT
Default 08-16-2018, 09:15 AM
Fuel pump is in and running great. Should i now switch to Map 6 and set boost tables?
What settings do you recommend starting off? Staying on pump 93 for now until i give the turbos and LSD some time to settle in.
Thanks in advance
-Patrick
Default 08-16-2018, 11:10 AM
Yea, you can try another 2 psi on map 6 if you want.
Car: e92 335i AT
Default 08-17-2018, 06:18 AM
Awesome, thanks for the feedback. By chance do you have a snapshot of your recommended Map 6 tables? Or do i literally just add 2 psi to the pre populated data in each rpm range under user adjustment settings for Map 6?
I should be on the latest G5 firmware.
Thanks in advance!
Default 08-17-2018, 09:12 AM
Thanks in advance!
Put in your desired boost level across all RPM and click save
