msimoni's Avatar
msimoni msimoni is offline
Car: 2013 BMW 335i xDrive MSport, JB4, BMS intake, ******* ********, Corsa Exaust
Default PEUGEOT 308THP - 06-28-2018, 08:22 AM
Terry
My wife has a 2014 Peugeot 308THP (in Brazil), which uses exactly the same 1.6L Turbo engine/powertrain as the Mini Cooper, derated to 165HP. I know other pigback Minicooper tuning boxes will work perfectly with the 308THP raising power back to the OEM 205HP range. Have you ever tried the JB4 on a 308THP?
2013 BMW 355i xDrive M-SPORT/MPPK, JB4 Flex Fuel, BMS Intake, Corsa Pro Series, C* Less DP.
Default 06-28-2018, 09:39 AM
I've never looked at that model.. Get me some photos of the engine bay and TMAP/MAP sensors, so I can identify which electronics it uses.
msimoni's Avatar
Default 06-28-2018, 09:43 AM
Here you go with an youtube video of the RaceChip installation for the 308THP:
https://www.youtube.com/watch?v=dEtiucaedT4
Default 06-28-2018, 10:53 AM
Hard to see the sensors themselves in the video. I can see the TMAP sensor which looks correct for the B48 application, but I can't see the MAP sensor. Can you get a close up photo on your car?
msimoni's Avatar
Default 06-28-2018, 11:02 AM
I can't get that image at the moment as I am in the US and car is in Brazil, but it is on the intake manifold and it is exactly the same as the one used on the Mini. The Racechip used on the 308THP is the same used on the Mini Cooper., so I bet the connections are exactly the same as well
Default 06-28-2018, 11:46 AM
Most likely the JB4 is fully compatible then. Worst case, we have to provide a firmware update for it.
