Taron's Avatar
Taron Taron is offline
Car: 2008 BMW 335XI
Default multi nozzle meth setup suggestion needed. - 10-03-2014, 01:44 AM
Hi guys
I have cooling mist 200psi pump, FSB controller, Valve, tubes etc. I was using cm14 nozzle and the car performs strong with RB turbines. Now I plan to go next level, and the reason I want to add more meth is that gasoline quality is not the best here.
Any idea what should I do?
I sow lot of threads before in this board but Terry deleted all old threads so forced to ask again.
Taron
2008 335XI(E92) AT/ garrett gtx3582r with jpworks manifold 1.06AR housing/ tial mv-s 38mm wgs(13.5 psi springs)/ tial bov/ fuel it level1 upgrade/ index 12 injectors/ N20 Map sensor/JB4 ST TS BEF with MHD/ Alpina Flash for now.
Stucks Stucks is offline
Default 10-03-2014, 02:56 AM
Originally Posted by Taron
Hi guys
Taron
if you are going to go dual nozzle I think terry recommends a cm10 + cm5 or a combo of cm10 + cm7. the dual nozzle kit is available on the burgertuning website
Current: 2008 e92 335i coupe.
Taron's Avatar
Car: 2008 BMW 335XI
Default 10-03-2014, 07:00 AM
spraying before or after turbine is producing more power ?
Ando @ BMS's Avatar
BMS Customer Service
Car: bmw 335i
Default 10-03-2014, 11:10 AM
CM 7 and CM 5 Should be fine.
When I had RB's I just did CM14 single nozzle.
tboudre's Avatar
tboudre tboudre is offline
Car: 2011 BMW 335xi E90 N55
Default 10-03-2014, 11:23 AM
Would there be benefit to spraying water with one nozzle and meth with the other? Maybe you could tune your mix on the fly, or have more of one spray at low/high rpm or boost? Or maybe water before the turbo & meth after, or vice versa. Just brainstorming here.
2011 335i xDrive ///M-Sport LeMans Blue Navigation iDrive 15% Tint N55 E90 - BMS Intake, Le Mans Blue Grilles, Le Mans Blue Rear Diffuser, Alpina B3 TCU Flash, Misc Coding, Matte Black Badge, Gloss Black Exhaust Tips, Blue Calipers*, VRSF Charge Pipe*, Cyba Scoops*, JB4 ISO 5.5, Sport Oil Cooler Valve, FlexFuel (Fuel Rail Pressure) Wires, Wheel Lock Set, Ethanol Content Sensor - No problems up to E70 fuel mix
jovonni31 jovonni31 is offline
Default 10-03-2014, 12:43 PM
would a cm 12 and cm 10 combo be too much for fbo+ RB turbo car?
2016 340i trackpack , JB4,MHD BEF e85 tune, BMS intake, BMS CC
Russell @ BMS's Avatar
Car: 2009 335i AT
Default 10-03-2014, 12:47 PM
If you are worried about timing..... up your water ratio.
Pump pressure will really take a dive with that combo.... but your call.
Instead of speculation just log.
Peter @ Pure's Avatar
Car: F20 M135i
Default 10-03-2014, 12:51 PM
I switched from single cm10 to dual cm7 + cm5 this week
F21 M140i - 100-200: 6.95
Audi TTRS - 100-200: 4.47 60-130: 5.16
F80 M3 - 100-200: 4.45, 60-130: 5.1
peter@pureturbos.eu
peter@pureturbos.com
peter@protuningfreaks.com
pureturbos.eu
Default 10-03-2014, 01:07 PM
cool i have a cm 12 right now , waiting for that VArgas hfpf shotgun barrel to come out, i heard we dont need meth with that but i might still keeep it i liek to see low AIT.
lightning lightning is offline
Car: BMW 1M Coupe
Default 06-24-2018, 05:11 AM
So what’s the verdict? Dual CM?? Vs cm14s?
N54QC N54QC is offline
Car: 07 BMW 335i
Default 06-24-2018, 07:15 PM
Originally Posted by lightning
So whatís the verdict? Dual CM?? Vs cm14s?
You're over 3 1/2 years late to the party. Haha But yes, dual 7cm over a single 14cm. That's dependent also on your setup wether you need that much volume.
Default 06-25-2018, 07:41 AM
Depends on the power goals.
I usually rec dual Cm10 for anything over 600whp.
Car: BMW 1M Coupe
Default 06-25-2018, 07:47 AM
Thank you!! I’ve been having a cm14 for 2 years on Pure S2s doing around 5.9s 100-200..
So just wanna improve my setup..
blown07's Avatar
blown07 blown07 is offline
Car: 335xi, 335i
Default 06-25-2018, 04:13 PM
I used to run 2 nozzles but am not a fan of it now.
- more connections to leak/monitor
- smaller jets clog easier
- cost
- if you don't run a second solenoid then the meth will get siphoned out of both lines from the "T" to the jets. I think some guys have done loops to prevent this but not sure.
- due to pressure loss you can't just add the jet sizes together as the overall amount will be far less
- I drilled and tapped the outlet of the intercooler to get the best distribution. I will take this over any perceived gain with spraying closer. My trims are identical between both banks.
- You can spray more on these cars than most of the sites recommend. As long as your trims are not bottoming out then as I understand it the fuel in the w/m is accounted for.
335xi FBO,Meth,MHD,XHP3,VTT stage1 11.58@121.67
335i FBO,Meth,MHD,XHP3,LSD, 12.1@118, Now with GCLites
Car: BMW 1M Coupe
Default 08-25-2018, 07:55 AM
Hi Payam! Ok i changed to the PHOENIX RACING chargepipe with dual CM10 nozzles.
Need some advice, when running dual nozzles, does the length of WMI hose from T joint to the bungs affect anything? also, Iíve noticed that thereís a difference in bank 1 & 2 trims when the meth comes on, itís consistently 8-9 difference, am I doing something wrong?
Default 08-27-2018, 09:09 AM
I got to your email, send me pics of your setup since we're talking about it.
AWSAWS's Avatar
AWSAWS AWSAWS is offline
Car: 335i MSport DCT
Default 08-29-2018, 09:13 AM
Tried a DO14 once and the trims were terrible.
One bank got very little meth. The other bank got loads. I imagine the big dropplets just followed the air within the manifold to a very large degree.
blown07's Avatar
Car: 335xi, 335i
Default 08-29-2018, 10:37 AM
Yes the length is important if running dual nozzles with only one solenoid. All the meth will drain out from both jets up to the "T"...read my post above. I have heard that a loop in each line after the "T" may help with this but I never tried it. FYI I am now using a single CM14 that outputs 1100 ml/min tapped into the outlet of the intercooler and both banks of my trims are identical. Also not a drop of meth leaks out of the jet with this setup.
