(#151)
07tundra's Avatar
07tundra 07tundra is offline
Car: a slow one
Default 09-10-2016, 12:21 PM
Originally Posted by BMW135xi
I think Vargs Turbos should represent Nizpro here in the States. It should be nice if you can partner with them.. , because Australia is very far away...
You don't think this might have happened already or is in talks as to why he's defending NIZPRO so much.....lmao. He does have a valid point though the programming needs to be addressed also which PD is doing. If folks have seen a good improvement with whatever bushings some have been replacing then there should be a good improvement with all the internal frictions being upgraded also. Regardless of whoever comes out with what in my opinion the AT - MT swap is the most cost effective and will handle whatever.
nitemare's Avatar
nitemare nitemare is offline
Car: 2010 535i 2002 530i
Default 09-10-2016, 07:46 PM
A friend of main put a DCT on it with Dodson clutches and is running hard as hell.
Tired of waiting for a solution..
Do you or anyone know of any 5series guys who have done a DCT swap yet?
WORLD'S FASTEST 535i - 60': 1.62 1/8: 7.2@98.3 1/4: 11.2@124.6 (@ 23psi only)
1/2: 151.2 (no boost in 4th or 5th bad TMAP)
Hexon RR700s/JB4/Trebila BEF/BMS Meth/MFactory LSD/Fuel-It Stage 2/ADE Port Injection/Full E85/ VRSF Inlets/VRSF ***/VTT Outlets/Custom 3.5" single exhaust/VRSF CP/Tial BOV/Rev9 FMIC/RB PCV fix kit/ RaceStar Dark Star 17" & 15" wheels/Custom 15" brake setup
Future: Lots more to come...stay tuned!
BMW135xi's Avatar
BMW135xi BMW135xi is offline
Car: BMW 135I
Default 09-11-2016, 12:48 PM
Only on 135I and 335I ..DCT swap...
klipseracer klipseracer is offline
Default 09-11-2016, 11:07 PM
I spoke about the DCT swap long ago even before Oleg(ncat) actually did it and documented it. With the 6AT upgrades on the way, I think it would be foolish to do any kind of swap unless you needed your car ready within the next 6 months for some kind of event or otherwise.
BMW135xi's Avatar
Car: BMW 135I
Default 09-12-2016, 11:17 AM
Agree, it wasn't cheap the swap from AT to DCT.
Car: 2007 BMW E90 335i
Default 09-12-2016, 12:17 PM
Propulsion Dynamics has already built, tuned, tested (tranny dyno), and shipped a handful of "beta" built 6HP21 units, a couple of which will be tested on single turbo setups.
Nizpro might be a little behind now.
2013 135is DCT Carbon Black
BMW135xi's Avatar
Car: BMW 135I
Default 09-12-2016, 12:31 PM
When are they coming with the product for sale?
335IVE 335IVE is offline
Car: 07 E93 335i 6AT
Default 09-14-2016, 06:37 PM
Exciting times ahead. Has the PD betas run any times yet?
Nizpro has a few betas out as well. Did a dozen passes all around 134mph trap, 11.2 ET. Non TCU calibration yet
Default 09-14-2016, 07:08 PM
As far as I know PD has a unit in their shop car and a couple beta units are getting installed within the next couple of weeks. No times yet. They post updates on bimmer boost.
nitemare's Avatar
Default 09-14-2016, 09:04 PM
Is PD also flashing the TCU?
Car: 2011 N55 135DCT
Default n54 nizpro tranny - 01-03-2017, 02:09 PM
Good day any updates regarding the tranny options?
Jeffman's Avatar
Jeffman Jeffman is offline
Car: 335xi
Default 01-03-2017, 06:03 PM
+1! Looking for updates!
2008 E90 335xi AT 67K MILES
MHD CUSTOM FLEXFUEL 24 PSI, N20 TMAP, FUEL-IT STG 2 LPFP, cPE CHARGE PIPE, HELIX IC, TIAL Q BOV WHITE SPRING, BMS DCI, BMS T-STAT DELETE, BMS HIGH AND MISHIMOTO LOW OCC, RB PCV, KW-V1 COILOVERS, APEX ARC-8, 235/265 MICHELIN PSS, xHP STAGE 3, SCOOPS, PR IGNITION
Chris@VargasTurboTech's Avatar
Chris@VargasTurboTech Chris@VargasTurboTech is offline
VTT ***** *****
Car: All Things Booost
Default 01-03-2017, 06:44 PM
Nothing from our end yet... we'll def be talking about it when we do!
Chris
Chris - VTT Forum Representative
For fastest response: Chris@Vargasturbo.com
www.Vargasturbo.com
RS6 RS6 is offline
Car: Audi RS6
Default 05-20-2018, 08:28 PM
Sorry for resurrecting old thread but its the best i could find!!
Hi all
I am new here and am after information on strenthenjng the 6HP19/21.
Has anyone worked out how to use the larger inout shaft and other front parts drom the 6R80 like they do with the 6HP26s in the 19/21? Also are the cryod oem or aftermarket billet our only options for the other shafts or is there a chance to use the larger oem/billet lole the above mentioned modification?
Regarding torque holding what is the most we can do in terms of best and max no of frictions/steels etc?
I hope its okay that I am asking for an Audi and not a BMW! application is a A6 4.2 V8 Twin turbo and i am aiming to make 1000whp to hopefuelly run 9s
N54QC N54QC is offline
Car: 07 BMW 335i
Default 05-20-2018, 09:04 PM
Hi all
If you are looking to strengthen a 6HP19/21, I would look into propulsive dynamics. As far as I know, they are really your only choice short of choosing a different transmission option.
BMW135xi's Avatar
Car: BMW 135I
Default 05-22-2018, 11:35 AM
Yep, only one is PD for the 6HP19/21.I think you can also ask MMP is just getting into it.
