Monty_Zoomer Monty_Zoomer is offline
Car: Cooper S
Default Help Needed after install - 03-17-2018, 05:35 AM
Hi
I've installed by JB4 today in a cooper S mini - I also installed the bluetooth module
My phone connects no problem - I can see revs - ECU PSI, boost map etc
My issue is that it doesn't seem to make any difference to the performance whether I select Map 0 or 1 or 2
If I look at the boost compared to the ECU PSI they seem to match - I was expecting to see one higher than the other in Map 1 and 2 (is this correct)
No errors - just no difference ???
Default 04-09-2018, 10:03 AM
Post a JB4 log and we can review the settings, maybe you are locked in the stock mapping.
