(#176)
str8shot str8shot is offline
Car: N54 135i
Default 10-14-2016, 07:51 AM
Originally Posted by Bmwfixerguy
When running a jb4 g5 with meth ad well what package would I need to have E content on my fixed tablet and jb4 mobile app?
What are my options since I already use that pin for meth flow?
If you're using meth, you have two options - the LED display, or the bluetooth version. Bluetooth version will display content via my app in the google play store.
2008 Montego Blue 135i Coupe // Sport Package // JB4 G5 Iso in passive mode with custom e30 MHD tune // Bluetooth e85 content analyzer with JB4 integration // Walboro 255 inline pump // BMS downp|pes // VRSF 7" FMIC // ER charge pipe // Turbosmart BOV // Injen intake // M-Factory SMFW // F10 550i clutch // Vorshlag camber plates // Hotchkis FSB // Turner adjustable drop links // AST 5100 coilovers // Hawk HPS pads // Ti backing plates // Stoptech stainless lines // Turner 15mm front spacers
Car: N54 135i
Default 10-14-2016, 07:53 AM
Originally Posted by suspenceful
Mr. Str8shot himself pretty much guided the installed. We sliced the stock line and removed a few inches. Added the quick connect fittings and put the sensor in. Pretty simple actually.
This. It's super easy if you leave the line on the car.
Mount the sensor, line up the factory line with the sensor, cut and install the fittings.
All your doing is taking 2-3" out of the factory line so the sensor can fit in between.
I'm doing one later today. I'll take some pictures.
Car: N54 135i
Default 10-14-2016, 11:44 AM
I just reinstalled mine laying on the ground in about a half hour. I had previously removed it and my line (I made a new one) and swapped back to OEM for the wastegate warranty / new turbo install a few weeks ago.
Rather than reinstall the line I made, I just cut the factory line (way quicker than installing a whole new line).
Here's how I did it.
1 - Mount the sensor and install the quick disconnect fittings on the sensor; this way you can gauge where to cut your factory line:
Hold the line up to the fitting, so you can see where you need to cut it. I don't have a picture of the cut, but in the picture above, it was approximately where the line is resting on the middle of the black clamp.
Install the front fitting:
I cut the back end where the orange mark is and installed the quick disconnect:
That's it. I also installed clamps, but it's probably not necessary.
Here's how much line I removed:
Car: N54 135i
Default 10-14-2016, 11:46 AM
Also, photobucket sucks. I had all those pictures rotated to the same orientation.
Time to start self hosting...
sch4400 sch4400 is offline
Car: 08 535i
Default 10-15-2016, 07:43 AM
Can I buy Standard ECA with harness and digital LED display ??
also should I buy continetal sensor and some quick fuel connects by myself?
sent you the money for the package a and led display.
Car: N54 135i
Default 10-16-2016, 08:25 AM
Thanks for the order!
Car: 08 535i
Default 11-06-2016, 04:11 AM
just got a item and test it.
The display showed like picture and after that unpluged the display wire , and re connected wire.
but the display show me another number like bottom picture.
after that,the display turned off byitself.
is that led display problem?
keyap keyap is offline
Car: N55 135i
Default 11-06-2016, 04:29 AM
When running a jb4 g5 with meth ad well what package would I need to have E content on my fixed tablet and jb4 mobile app? What are my options since I already use that pin for meth flow?
You could wire both to the JB4 and add a switch. You don't need to read E all the time so fill up, read the E %, flick the switch to turn the feed from the sensor off and make the meth live again :-)
[B]
Car: N54 135i
Default 11-06-2016, 08:08 AM
I wouldn't do this. Typically you can't just flip between the two; meth scaling needs to be adjusted in the JB4 settings.
You could flip the switch, JB4 could think meth is flowing, and you could nuke your engine.
Car: N54 135i
Default 11-06-2016, 08:10 AM
Make sure the sensor connector is seated all the way.
Make sure none of the pins in the JST connectors backed out when you plugged them together (seen it happen once or twice).
Make sure you have the display connector oriented the right way.
Try removing the 5ft display extension and run the LED right off the ECA connector.
Last, make sure all your grounds are good.
Default 11-23-2016, 09:46 AM
Bump any updates on shipping?
2007 e90 335i
Hexon turbos
Trebila Custom tuning
Default 11-28-2016, 09:49 PM
It's Nov 28th,i sent my payment in Nov 5 for a basic 80 doller ethonal harness and have not heard from the seller at all. Tried emailing, private messaging on here and e90post.com..
Be warned everyone
2007 e90 335i
Hexon turbos
m5james's Avatar
m5james m5james is offline
Default 11-29-2016, 03:11 PM
Is a Fuel-It system required to run this? Fuel-It doesn't have anything for me, likely never will. I've got a 2010 X5M that I will be running BMS' JB4, BCM and meth kit. I've played around by waiting until I've got an empty tank, adding 5 gallons of E85 then topping off with 92. I don't think anyone has ever run straight E85 in an S63/S63TU but the day could come.
Default 12-01-2016, 08:52 AM
Dec 1, I filed a PayPal complaint and a refund Nov 28th. PayPal or myself have not heard back from this gentleman.
2007 e90 335i
Hexon turbos
Default 12-11-2016, 07:56 AM
Update :Dec 11..
I receive the ethonal analyzer yesterday from Scott. As per our email he has agreed to refund me my money and let me keep the product as soon as the PayPal dispute is
Closed.
2007 e90 335i
Hexon turbos
CharliesN54's Avatar
CharliesN54 CharliesN54 is offline
Car: 2008 335xi
Default 06-13-2017, 08:53 AM
Bump. Still selling these?
Single Turbo Z4 that's constantly broken
orteeze orteeze is offline
Car: 08' 335i
Default 06-13-2017, 12:59 PM
He is. Message him.
E90 LCI M Sport
Car: N54 135i
Default 06-14-2017, 08:03 AM
All sales are temporarily suspended. Unfortunately I'm way too busy at work to build any of these at the moment.
I should be making more in July. I'll update the post then.
RacePace RacePace is offline
Car: E90 335i M Sport
Default 06-26-2017, 11:13 PM
Please put me down for 1x ECA kit asap
06 335i E90 MSport: FMIC, DCI, E85 50%, JB4 + MHD, Fuel-it Stage 1 LPFP, Rear Muffler delete
06 987 Boxster S
RIP 07 335i
neroneuman's Avatar
neroneuman neroneuman is offline
Car: n54 335i
Default 08-22-2017, 07:39 PM
I have one Package A - Standard ECA, Brand New in Box for $80.00 shipped.
Bryce 135i Bryce 135i is offline
Car: 2008 135i
Default 01-29-2018, 10:44 AM
Any word of these are still available? I would be interested.
Car: 08 535i
Default 03-19-2018, 09:20 PM
still have it?
neroneuman's Avatar
Car: n54 335i
Default 03-19-2018, 09:22 PM
Sorry Buddy, it was sold
Car: N54 135i
Default 03-20-2018, 06:19 AM
I've got a few of these for sale again. Just 0-5v, non-upgradeable.
Asking $75 shipped.
Car: 08 535i
Default 03-20-2018, 06:39 AM
Asking $75 shipped.
what does that mean non-upgradeable?
I bought Package A - Standard ECA with digital LED dispaly a years ago..
is it upgradeable???
want to buy a set of standard eca kit with digital led.
