Rob@RBTurbo's Avatar
Stalker
Car: 335I
Smile N54 TD03L-10T OEM Rebuilt CHRA's (for the DIY guys) - 11-16-2016, 05:38 PM
CURRENTLY ONLY ONE SET AVAILABLE FOR SALE 1/7/20.
Many of you may know we have been selling these as used take off's for many of years now. Despite selling quite possibly up to 1,000 of these to others all around the globe, we STILL have many units on hand SO decided it was time to put them to a good cause. We have had many folks request this service as well so it has been a long time coming to finally have the offering.
We started by having some custom "larger than TD04" Thrust Upgrade hardware made to adapt into the TD03 OEM turbos ensuring that these will be better than what they were new. The end result is a mega cheap new core CHRA for you all looking for a true better than OEM replacement but with standard performance, availability, AND budget in mind. As these cars are getting much cheaper they are also being purchased by the more mechanically inclined (or younger ambitious) types, so we do realize that budget and DIY is where it is going out there.
Ultimately what you get are 100% OEM MHI CHRA's with all new bearings, seals, clips, and significantly beefed up thrust hardware so you can transplant them into your old housings and be off without a hitch. But keep in mind that even though they are "Plug and Play" that this is still a cumbersome DIY so you should have some confidence and the tools necessary to tear into your own turbo and make the install. Our intention is to not offer these and then get pounded with support questions along the way, as such we are keeping the cost very low. We are simply trying to provide the part that you need to get back on the road as your OEM turbos take a dump, so please make sure you understand what you are doing before purchase.
The cost is $450 per set OR $250 per CHRA*
*if ordered individually you must specify front or rear
NOTE 1: NO CORE CHARGE!
NOTE 2: We can add a Billet 10T compressor/Custom Bullet Nut for $75 PER UNIT as well.
NOTE 3: We HIGHLY recommend doing both units, not only a single; as chances are your original units are both beat and need replacement.
NOTE 4: If you send back your old CHRA's in the same packaging we sent these to you (or such that they are undamaged and rebuildable), we will refund you $50.
All units are all VSR balanced to under .2g to 200k RPM and each unit will come with its own document.
If you are in the USA the cost will be $475 shipped for the set or $275 shipped per unit. Our paypal is rob.rbturbo@gmail.com and you can also email the same address with any questions (ie. international shipping quotes, etc).
Thanks,
Rob
blaster3500 blaster3500 is offline
Car: 2007 335i
Default 11-17-2016, 06:33 PM
I am surprised that you haven't had more replys. Solid deal.
07 E90 335i 6mt
Stalker
Car: 335I
Default 11-18-2016, 08:06 AM
Yes sir appreciate that. This is about as cheap as it gets.
More to come as well!
Rob
Stalker
Car: 335I
Default 11-18-2016, 01:57 PM
Originally Posted by the_panda_driver
So stock size with upgraded thrust parts? stock wheels or better wheels?
These wheels are 100% stock. The internals are significantly upgraded over OEM though.
Soon will have other options to build upon this DIY theme (and beyond), but this offering will certainly be the cheapest.
Thanks,
Rob
Stalker
Car: 335I
Default 11-27-2016, 07:06 PM
Update: We can now offer a Billet 10T compressor wheel/bullet nut for $75 extra per unit. First post has been updated.
Vogt.ryan's Avatar
Vogt.ryan Vogt.ryan is offline
Car: 2008 BMW 335i sport
Default 11-27-2016, 07:23 PM
Tempted to buy a set as a back up, I think I saw somewhere there is a watergate rebuild kit too, replacing turbos just got salot cheaper!!!
Stalker
Car: 335I
Default 11-27-2016, 07:43 PM
This is pretty damn dirt cheap for the DIY guys, no doubt. We have several more budget kits, even offering better performance, on the horizon as well. - BUT this is by far the cheapest there could be.
135i08 135i08 is offline
Default 12-05-2016, 07:36 AM
Email sent !
Stalker
Car: 335I
Default 12-12-2016, 11:12 AM
Originally Posted by 135i08
Email sent !
We've received and responded to many emails so you should've had a response by now.
Thanks,
Rob
Icelandic Icelandic is offline
Car: 2008 335i 6MT
Default 01-29-2017, 08:14 AM
Anyone have experience with these?
Stalker
Car: 335I
Default 01-29-2017, 09:39 AM
We've shipped out around 15 sets of these so someone should be able to chime in I'd think.
Rob
Stalker
Car: 335I
Default 02-15-2017, 04:11 PM
We've been consistently selling 2+ sets of CHRA's per week as of late, and yet another week with 3 sets of OEM rebuild CHRA's shipping out. Should be knocking on 20 sets of these out there very soon now.
Oh and a couple DIY Stage 1 kits (TD03L 9-blade with 14T Billets) too...
Rob
the_panda_driver's Avatar
the_panda_driver the_panda_driver is offline
Car: 2007 BMW 335i
Default 02-15-2017, 05:02 PM
What is the advantage of the billet wheel. Any dynos of the better wheel?
Vogt.ryan's Avatar
Default 02-15-2017, 05:13 PM
+1
2008 335i Sport Jb4, MHD BEF, Alpina flash, Uncatted *****, PE Mod, Injen Intake, v710's , Vogtland Springs
Stalker
Car: 335I
Default 02-15-2017, 06:25 PM
For the billet 10T vs. the cast 10T? Doubt much gains worth making any fuss about. But billet nonetheless and an option for those who want it, at $75 per unit it's reasonable to entertain but if you'd rather spend it elsewhere it's all good do your thing. Ultimately if we didn't offer it someone would ask for it.
If you mean the Stage 1 offering- these will make quite a bit more power due to the 9 blade wheel and 14T (much larger) compressor. But these are a smidge more costly as well, and we would also highly recommend (or mandate) inlets with them too.
Thanks,
Rob
Maniac0908 Maniac0908 is offline
Car: 07 BMW 335xi JB4 G5 DP DCI BOV
Default 02-15-2017, 07:25 PM
Thanks,
Rob
How much for stage 1? Or even stage 2 if possible. Any diy guides out there for this?
2007 335XI SEDAN // ACF/VM 6266 SINGLE TURBO// MMP PORT INJECTION // VRSF CP W/ TIAL BOV // XHP 6AT FLASH // MOTIV TUNED // BMS OCC // VRSF EXHAUST // DIY STAGE 3 LPFP// VRSF FMIC //
Stalker
Car: 335I
Default 02-16-2017, 06:50 AM
Attached is our 2017 RB Turbo N54 Turbocharger catalog. Please read all notes/options/accessories thoroughly. As for DIY guides perhaps someone will make one, haven't seen one yet.
Thanks,
Rob
Car: 2007 BMW 335i
Default 02-16-2017, 03:50 PM
Will the stage 1s still fit in the stock housing or will they need to be machined?
Correct me if I am wrong but you offer stock wheel size with cast blades and TD04 internals. And an option for the upgraded wheels for a small fee.
I guess what I'm asking is do you offer the stage 1 CHRA (which is different from the one CHRA mentioned above with the 10T wheel) for the DIY and does it require machining.
Stalker
Car: 335I
Default 02-16-2017, 04:26 PM
Stage 1's will fit in the OEM Turbofold without machining, but the compressor housing needs machined. So with the Stage 1 DIY setup the machined compressor housing is included and it is expected you send back your old compressor housings/CHRA's that you remove during this DIY process (thus there is a fully refundable core charge for all Stage 1's- DIY or complete). Obviously you will keep your old turbo folds and put the new Stage 1/Compressor and CHRA kit into it per your DIY, and of course address your own wastegate issues as you desire. OR just buy the complete Stage 1's and have no worries.
Car: 2007 BMW 335i
Default 02-17-2017, 06:52 AM
I have looked over the catalog. You sell the DIY RB "ONE" for 999$ and it comes with new compressor housings? If I bought some I would just have to send in my stock CHRAs and compressor housings correct?
Stalker
Car: 335I
Default 02-17-2017, 06:15 PM
Correct. There's a $300 fully refundable core charge as well.
Car: 2007 BMW 335i
Default 02-20-2017, 03:15 PM
Okay. I was going to email you with all of my question but I thought it would be better if I did it on here just in case anyone else had the same questions. Hopefully safe you some emails. I will propbably make an order 1 of each with in the next few months.
Stalker
Car: 335I
Default 02-25-2017, 09:49 AM
Sounds good. We will be making a stage 1 DIY thread soon and will link it here when it's made.
Stalker
Car: 335I
Default 02-27-2017, 08:54 AM
We have a set of cartridge cosmetic "blems" that are perfectly fine however they were quite rusted from the donor set of turbos that are now refurbished. Even though they have been processed and cleaned, as you can see per the picture due to the severity of the surface imperfection (and in part of our OCD complex) we feel they are blems so feel they should be cheaper. Keep in mind this is ONLY cosmetic and has NO relevance to performance or reliability as INTERNALLY they are perfect- and quite frankly had we not said anything you may not even be concerned with them if purchased normally.
Anyway we will offer this set (and others as they may present themselves going forward) to the forums for $325 shipped to the USA for the set which is a $75 discount. If anyone is interested in this set please let me know.
Thanks,
Rob
EDIT: This "Blem'd" set has sold 3/1/17.
Stalker
Car: 335I
Default 02-28-2017, 04:42 PM
RB Ones ("Stage 1") DIY compressor kit thread is up now:
http://www.n54tech.com/forums/showthread.php?t=45348
