(#2451)
Default 10-01-2016, 09:13 AM
Originally Posted by ms335i
Hey guys I'm currently ordering a tmap sensor in order to run more boost but in the mean time would like more aggressive timing for the boost I am currently on. I'm currently on st pump flash. Is there a st e85 flash without pi? Can I run that one without pi?
The fuel system will not support much E85 without meth or port injection. In the case of a lower E85 mixture the normal ST file is used.
Default 10-04-2016, 12:05 PM
For those running the 4bar, should I fix the firmware so maps 5 and 7 reflect the normal boost targets? Currently due to a "bug" those maps are inflated a few PSI on the 4bar. For example map5 targets 31psi instead of 26psi, and map7 runs 33psi instead of 28psi.
335i-Driver 335i-Driver is offline
Default 10-04-2016, 12:31 PM
Hi Terry..i need helb..for mag 35 solenoid.
solenoid is not clicking..I checked as your video..
If I press the gas pedal..not voltage...
Without jb4 solenoid orange wire 12v and white wir is 4.5v..pleas what is problem..pleas if you reply..i am happy..thanks
Default 10-04-2016, 01:33 PM
We can't really provide hardware level support like that via forums. You'll need to chase down the solenoid power source or find a mechanic who can do that for you if you're unable to.
Hefel135i Hefel135i is offline
Car: 135i coupe
Default need help with single turbo software - 10-15-2016, 08:59 AM
so I'm new to all this BACKEND flashing and running basically 2 programs at once. so with that being said, what all do i need to run my single turbo?
so far what i understand is that i have jb4 g5 already so i will need to purchase and android pad, mhd from the android store and a data cable. is that correct?
but why can't i use my usb data cable already from the jb4?
thanks!
GrantCraik GrantCraik is offline
Car: 135i AW
Default 10-16-2016, 09:54 AM
Just finished installing a single turbo on my RHD 135i, using 4bar map sensor and the Mac solenoid. Could somebody give me a quick run through as to where I find the firmware etc for my setup? Thanks
Rob.K Rob.K is offline
Car: 08 135i 6MT
Default 10-16-2016, 10:43 AM
First post in this thread has the firmware and info you need to run the Mac solenoid
Current - 2008 135i 6MT | XR9567
Sold - 2007 335xi AT | 12.1@117
BostonBeemah's Avatar
Car: AW 135i
Default 10-23-2016, 11:14 AM
I keep getting 2abd faults with my 4bar tmap and chose to go back to my stock just to test but the JB app won't save my setting of 0. Is this purposefully done on the single turbo firmware?
RIP 2008 AW/BL 135i
Default 10-23-2016, 11:24 AM
Fix the 2ABD faults... Normally its in the flash file itself. Email if you need help with it.
Single turbo firmware supports the OEM TMAP sensor.
Car: AW 135i
Default 10-23-2016, 12:09 PM
Thanks Terry! Just shot you a quick email.
RIP 2008 AW/BL 135i
Car: 135i coupe
Default 10-29-2016, 11:20 AM
I'm working on plumping my wastegates for the MAC solenoid. Do all the air ports need to be plugged including the very top on one the center of the wastgate? Leaving just the side bottom and top ports available for the solenoid lines? I have the TIAL MVS's
101Duck's Avatar
101Duck 101Duck is offline
Australia
Car: 2008 135i MT
Default 10-30-2016, 01:41 AM
I'm quite happy with the 33psi target tbh. although I can't seem to get it to hit that target on the street just yet.
2007 E90 335i M sport
Single turbo, E85, PI
Worlds Quickest N54 and e9x. 10.1 @134mph
Default 10-30-2016, 06:10 PM
Maybe need a tighter WG spring?
101Duck's Avatar
Australia
Car: 2008 135i MT
Default 10-31-2016, 02:44 AM
Think I just need to dial the FF in I have 17psi spring I thought that should be enough. Really need to get more time to play with it. Hopefully it's just FF settings
Default 10-31-2016, 09:06 AM
All FF can do is drive up PWM. Once PWM is around 80% then its basically maxed out.
alex_beridze alex_beridze is offline
Car: BMW 335
Default 11-01-2016, 01:09 PM
Hello my friends
I deside to go with 6466 gen2 turbo but i need advice about turbine housing AR. I need to use this turbo for 91 pump gas. I have some oftions from 071ar to 1.09 ar. Please advice what will be optimal for my setup. I need big diapason of torque..
Thank to all in advance
101Duck's Avatar
Australia
Car: 2008 135i MT
Default 11-02-2016, 05:45 AM
And if this is the case? how do I get the boost to go up? Tried every setting I can find, map6 or map7 both don't get to 32psi.
17psi wastegate spring. 3 port mac valve.
Default 11-02-2016, 09:14 AM
Would want to see the JB4 log, so I can verify PWM is maxed out. If so nothing else the JB4 can do for boost. Need more pressure holding the WG shut. Normally means a tighter spring... Or a larger turbo with less back pressure.
101Duck's Avatar
Australia
Car: 2008 135i MT
Default 11-02-2016, 04:55 PM
Ahh ok, that's what I was assuming. I have to upload the logs off my phone onto the computer and have a look, I'll send you one via email.
I doubt the turbo/exhaust is holding it back, it's a garrett 3884 (6567) with a 1.00AR and 3.5" exhaust, no cats. external gate with screamer.
I will get a bigger spring and see if that helps and go from there!
PWM sits at 99 the whole time.
I will look into a mechanical fault holding it back and report back!
Luis2006 Luis2006 is offline
Car: BMW 335i
Default 11-02-2016, 07:12 PM
I have a 07 335i 6speed and I have a jb4 and I don't no how 2 work jb4 I no how 2 put it and map 1 2 and 3 but I don't no about the others setting I no 1 is for the rpm but I want 2 no the rest of them!!
phv628's Avatar
phv628 phv628 is offline
Car: BMW 2009 335i xdrive
Default 11-03-2016, 05:16 AM
There are detailed instructions on page 1 on what you need to do with the settings.
|E92 335i xDrive| |JB4+MHD BEF| |VM Single Turbo Kit + PTE 6466| |Built Auto Trans| |xHP Trans Flash| |Stage 4-Triple Walbro 450s, fpr + return| |EOS Intake with Port Injection| |AD-ENG FMIC + AD-ENG OCC| |RB PCV Kit| |PR Ignition kit| |Built N54: Darton Sleeved, Manley I-Beam Rods+ARP Rod Bolts, JE 9.5:1 Pistons, JE Wrist Pins, VAC coated main & rod bearings + ARP Head Studs| |Keyed crankshaft snout, crank hub, timing & oil pump sprockets + VTT crank-bolt capture| |ADV Oxygen Sensors|
Venom77's Avatar
Venom77 Venom77 is offline
Car: 335I
Default 11-10-2016, 08:35 PM
Are there a good amount of people that use the TS ST non PI flash? I seem to have trouble with it on my car but have no issues with just the ST flash.
Default 11-10-2016, 08:52 PM
It's sort of hit and miss on the twin scroll spool mode changes in that. Works better on some kits not as well on others.
Venom77's Avatar
Car: 335I
Default 11-10-2016, 09:20 PM
Ok this makes perfect sense. I was thinking something along those lines. Thank you.
imad777 imad777 is offline
Car: BMW 335i
Default 11-14-2016, 06:07 AM
Hello guys, please have a look at my logs. Ambient is around 60F, turbo is:
Garrett GTW3684JB (aka GTW6262JB) .82 A/R, T3/VBand, FBO.
Running BEF and recent JB4 firmware (129).
Don't you think that boost is being built waaaay too slow?
Custom manifold picture and JB4 settings attached.
thanks in advance
File Type: csv 161113_1708_test.bin_WOT2_G3G4_DTCoff.csv (17.9 KB, 116 views)
2007 335i MT N54
MHD+JB4 Garret GTW3684 ST
FMIC, **, 3" *****, Fuel-It Stage 1, MF LSD.
