beastmw beastmw is offline
Default going single - 09-27-2016, 07:27 PM
Going to a single top mount kit, do i have to/should i coat manifold and **'s with the heat coating? Anything else i should do/tips before install?
Venom77's Avatar
Venom77 Venom77 is offline
Car: 335I
Default 09-27-2016, 11:44 PM
Get a good amount of shielding/wrap.
Which kit?
Garrett Gtw 6465, Supporting mods , Mhd/Jb4
BostonBeemah's Avatar
Car: AW 135i
Default 09-28-2016, 08:07 AM
I wouldnt wrap if you are ceramic coating. Just make sure the O2 bungs are not coated at all on the inside or outside.
RIP 2008 AW/BL 135i
Jt0407 Jt0407 is offline
Car: Bmw
Default 09-28-2016, 08:09 AM
Coat the manifold and exhaust housing.
JPkit | Ported head, Schrick cams| all the boost | tuned by Ken
ms335i ms335i is offline
Car: 2007 BMW 335i
Default 09-28-2016, 08:34 AM
Mine is wrapped and yea it reduces heat but it still gets really really hot. I should have gotten mine coated.
Don't wrap. Coat it
Car: AW 135i
Default 09-28-2016, 09:28 AM
Don't wrap. Coat it
I dont have mine coated or wrapped and she gets hot haha
RIP 2008 AW/BL 135i
Milan's Avatar
Milan Milan is offline
Car: 08 335xi
Default 09-28-2016, 09:29 AM
In my experience ceramic coating doesn't last so might as well wrap it
09 335 - 6266
07 335i - 6870, E85 - SOLD
Car: 2007 BMW 335i
Default 09-28-2016, 01:45 PM
Damn. My **** would melt everything under the hood with the temps I experience in traffic if it wasn't wrapped.
///Mposter's Avatar
///Mposter ///Mposter is offline
Default 09-28-2016, 02:10 PM
Don't get an STD ( single turbo disaster) and wrap that thing up. Melted wires, melted valve cover or messed up paint from extra heat closer to the hood is not worth it, so just bite the bullet and do it !
Default 09-28-2016, 07:26 PM
Will it melt wires if it is coated only?
Venom77's Avatar
Car: 335I
Default 09-28-2016, 10:23 PM
Its not too bad.
I dont have my manifold wrapped or coated. Down pipe is wrapped and turbo has a blanket. Also I have 2 layers of shielding under my engine cover with one on top. Heat isnt bad at all and I live in AZ. I did melt some wires without the extra shielding under the engine cover within the first week. As it sits now its fine.
Put shielding under the engine cover on top of the wires and you will be fine.
Xshadows Xshadows is offline
Car: 2008 135i
Default 09-29-2016, 06:26 AM
That ceramic **** in a rattle can at autozone doesn't last long at all, but if you get a real 2000 degree coating that **** doesn't come off unless someone isn't applying it correctly.
DocRace Top Mount w/ Precision BB 6266 - JB4 G5 - BMS Pump flash - 650HP AD-E Intercooler - BERK Race Exhaust - Fuel-It Stage 2 Fuel pump - ER Chargepipe w/ TIAL BOV - 560whp @ 20psi on 93 octane only
