Junkyarddogg Junkyarddogg is offline
Car: 2011 E92 335is
Default VRSF 7" or 5" for stick turbos/DD? - 09-26-2016, 09:43 AM
I'm debating which version I should go with. Right now all I have is ER CP and BMS DCI with MHD Stage 1. An fmic is the next mod and I will move to the Stage 1+FMIC. So the question is, should I go with the smaller one or go big? I am still undecided if I want to get a ********* ** because of the raspyness. So I might not even go Stage 2, although it is possible. I don't plan on tracking regularly.
Texsquirrel's Avatar
Texsquirrel Texsquirrel is offline
Car: 2009 BMW 135i
Default 09-26-2016, 10:17 AM
I'd go with the 5" if I were you.
2009 BMW 135i | Alpinweiß | 6AT | MHD/BMS JB4 G5 ISO32.8 | JB4 MHD 3/15/17 E85 Backend Flash | BMS Anti-Lag | Fuel-It Stage 2/ES-1/JB4 integration Kit | AD Engineering Port Injection | PR (Turbo-side) Inlets | PR Ignition System | VRSF ** | aFe Exhaust | Cobb FMIC | ER CP | Tial BOV | N20 TMAP | BMS Oil Cooler Valve | JB4 Mobile | 100% E85 | H&R Swaybars F&R | BA Diff Lock | StopTech D&S Rotors F&R | Cool Carbon Pads | Michelin PSS
BostonBeemah's Avatar
Car: AW 135i
Default 09-26-2016, 10:20 AM
+1 on the 5inch if on stock frames
RIP 2008 AW/BL 135i
seatte135i seatte135i is offline
Default 09-26-2016, 10:37 AM
They just came out with a redesigned 7in with a high density fin design(same core as the 7.5 race one). Idk if anyone has one yet. Might be a good option. I'd love to hear more about it.
2009 135i 6MT/ JB4 G5,TREBILA mhd tune, FBO w/ fuel-it dpmi.
Rushan's Avatar
Rushan Rushan is offline
Car: 335i E92 2009
Default 09-26-2016, 10:58 AM
Went with Wagner stepped performance 5" and it's going it's job considering Im in a hot region with 8-10 month exceeding 40 c degree
Stevie Stevie is offline
Car: 2008 BMW 535XI
Default 09-26-2016, 12:41 PM
I was actually looking into the 7 inch HD+ they were offering and sent them a message a few days ago. This is what they replied with on Facebook.
"FBO cars would significantly benefit from the HD core since it features an incredibly dense fin pack. You can expect lower intake temps as well as faster recovery time with the HD core."
Torgus Torgus is offline
Car: 335xi
Default 09-26-2016, 03:19 PM
5 inch should be fine but it depends on your final goals for the car. If the 7 or stepped is not much more it can't hurt.
For major IAT suppression you can't beat meth.
Got Boost?
ifarted ifarted is offline
Car: 2008 bmw 535i
Default 09-26-2016, 04:35 PM
I'm trying to decided also either going with 5" or 7" street intercooler, non HD
BMW 535i - Jb4 + dci, Vrsf **
Car: 335xi
Default 09-26-2016, 04:57 PM
Which offers better AIT suppression? If it were me I would go the 7 or stepped core. But if you are on a budget the 5 is fine and should work fine for your application. I still think people way over think intercoolers on this platform
Got Boost?
Car: 2008 bmw 535i
Default 09-26-2016, 08:13 PM
They are both the same price, I'm thinking about the 7" for more air flow
Showdown045's Avatar
Showdown045 Showdown045 is offline
Car: 2010 335i Convertible
Default 09-26-2016, 11:17 PM
I went with the 7. Growth is almost inevitable! Later on down the line, you may want more. In my case, I didn't want to end up buying the same parts twice.
2010 335i 6AT E93,FBO, Inlets, BMS Meth Kit single cm10 (55add N20 TMAP)
rathana_v rathana_v is offline
Default 09-26-2016, 11:38 PM
Got my 7" vrsf fmic last month install..was a pain to install..but worth it...
Car: 2011 E92 335is
Default 09-27-2016, 08:13 AM
Thanks guys, I suppose I will go with the 7" so I don't have to upgrade later. I'm debating between the VRSF HD core or the Wagner Evo II performance.
Cloud9Blue Cloud9Blue is offline
Car: 09 E92 335i
Default 09-27-2016, 09:03 AM
Even 7" core is not big enough if you do more than one pull. Just get the biggest one you can find. The effects on turbo lag will be minimal if you already have ***.
09 BMW E92 335i: EFR 7670 / Motiv / AP Racing / Wavetrac / TC Kline [Full Modlist]
07 BMW R1200S: Shine Yellow / Akrapovic / Ohlins
Chris@VargasTurboTech's Avatar
Chris@VargasTurboTech Chris@VargasTurboTech is offline
VTT ***** *****
Car: All Things Booost
Default 09-27-2016, 09:18 AM
Agreed. I have the 7" and had it with stockers through Stage 2+. It was marginal for stockers in the AZ climate and insufficient for the stage 2+ at the 550ish whp level.
Chris
Chris - VTT Forum Representative
For fastest response: Chris@Vargasturbo.com
www.Vargasturbo.com
Trunks335i7's Avatar
Trunks335i7 Trunks335i7 is offline
Car: E90
Default 09-29-2016, 03:48 PM
I went with "5" but it really does depend on you and final goals for the car. For me 5 was good enough. I went with ETS.
Bimmer_Boost's Avatar
Car: 2011 e92 335i
Default 09-29-2016, 06:10 PM
I went with the 7 inch and I am glad I did. I do run meth so between the two I never have issues with the IAT. Install was kind of a pain because of some of the cheap parts you get with the kit. Here is a link to my review.
http://www.e90post.com/forums/showthread.php?t=1172354
2011 E92 335i Auto
12.0 @ 125MPH JB4
Sold
Car: 2011 E92 335is
Default 10-01-2016, 08:56 AM
I changed my mind. I live in the northeast, don't track, and its a daily driver. I'm deciding between the following FMIC's.
ETS 5"
Mishimoto
Wagner Evo I Performance
Default 10-01-2016, 12:12 PM
What made you change your mind?
Car: 2011 E92 335is
Default 10-02-2016, 12:16 PM
1. less pressure drop
2. only hot a few months out of the year where I live
3. easy to install
4. daily driver
5. won't be tracking
6. only other mods may be ** and stage 2 mhd tune
mike@x-ph.com mike@x-ph.com is offline
Car: 2007 e92 335
Default 10-05-2016, 02:06 PM
Do 7" ... You can use it with your current mods and it will still do the job if you decide to add more mods in the future
BeastMode335i's Avatar
BeastMode335i BeastMode335i is offline
Car: 08 E92 335i
Default 10-06-2016, 06:38 AM
7" ftw...
Car: E90
Default 10-06-2016, 10:18 AM
"7" is so sexy though...
Car: 2011 e92 335i
Default 10-06-2016, 11:01 AM
A stepped 5 usually looks better as it fills the entire bumper opening. I would still recommend a 7" though.
2011 E92 335i Auto
12.0 @ 125MPH JB4
Sold
