(#3801)
Anthony235's Avatar
Anthony235 Anthony235 is offline
Car: m235i
Default 08-26-2016, 07:48 AM
Originally Posted by _ink
Hey Donnie, just wondering when you double tap on boost gauge to show max boost, that it shows a bit over over boost, when this doesn't appear in the logs?
Anyway to fix this?
I think that probably just has to do with the refresh rate of the logs.
Logs don't refresh fast enough to capture every data point.
_ink's Avatar
_ink _ink is offline
Car: 335i DCT
Default 08-26-2016, 08:46 AM
Originally Posted by Dmac @ BMS/DMD
Which theme are you using?
Circular gauges (2)
BostonBeemah's Avatar
Car: AW 135i
Default 08-26-2016, 12:51 PM
Any support for usb type C to micro USB such as on the new Galaxy Note 7?? Just picked it up but haven't had a chance to test yet.
RIP 2008 AW/BL 135i
x99percent x99percent is offline
Car: 2008 135i
Default 08-26-2016, 09:00 PM
They make Type-C OTG cables. I used one with my Nexus 5X before I bought the Bluetooth kit.
Car: AW 135i
Default 08-27-2016, 07:08 AM
Have one on order. Hoping it works with mhd too.
RIP 2008 AW/BL 135i
Car: 2008 135i
Default 08-27-2016, 10:23 AM
I've had no issues with MHD, either. As long as the Android phone/tablet/device supports USB OTG, you should be good to go.
DSG03Bolt's Avatar
DSG03Bolt DSG03Bolt is offline
Car: 08 535i
Default 08-27-2016, 07:16 PM
Noob here. Installed jb4 mobile a few minutes ago. If I do a log, how do I post it on the forum? I do not have usb, only bluetooth & jb4 app on my g5 iso.
What 12 selections should I graph?
My galaxy tab won't connect (sserial port not available) if any techs have info on what to do with that. I'm computer ignorant lol
2008 535i
Jb4 G5 map 2, DCI, vrsf down *****, fingers crossed the charge pipe holds!
-phoenix racing charge pipe, rev9 intercooler, xs power BOV awaiting install....
lightning lightning is offline
Car: BMW 1M Coupe
Default 08-27-2016, 08:08 PM
Nope I'm not in the beta group. How do I get in?
_ink's Avatar
Car: 335i DCT
Default 08-27-2016, 08:43 PM
need to upload a kill video to get in.
leo_malta747's Avatar
leo_malta747 leo_malta747 is offline
Car: 135i e82
Default 08-27-2016, 11:25 PM
How can i set my FUD?
I don't found this option in settings
135i n54
FBO + wmi + e50 + billet wheels
Traf Traf is offline
Car: 2009 135i Coupe
Default 08-27-2016, 11:52 PM
Do the logs show higher than eight?
Yes, logs are fine.
f*** v-bands clamp
Dmac @ BMS/DMD's Avatar
Car: 2008 135i
Default 08-29-2016, 12:15 PM
Circular gauges (2)
With the "Max Boost" number, it's more than likely an issue of when I save the max boost number (right now I save it during the animation loop, so it saves the incremental value instead of the raw input). I'll be changing that.
Don't see why it shouldn't work out.
Email the log to yourself, then upload it from a computer.
Are you trying to use the Connect Kit with the Galaxy Tab or an OTG connection?
This ^.
Just send me an email and I'll add you. support@jb4connectkit.com
Click the FUD box in the user adjustment page.
Originally Posted by Traf
Yes, logs are fine.
I'll be posting a new Android beta to try later. Are you in the Android beta group?
DSG03Bolt's Avatar
Car: 08 535i
Default 08-29-2016, 12:30 PM
Are you trying to use the Connect Kit with the Galaxy Tab or an OTG connection? --
Using jb4 mobile / bluetooth. I grabbed a different tablet & it worked. (Also used my phone).
Yesterday I updated firmware, but what user adjustments do I need in future use a /d for timing in my datalog
I'm in map 2 mods in sig
2008 535i
JP.BSB JP.BSB is offline
Car: BMW 320i Sport 15/15
Default 08-29-2016, 12:57 PM
Is there a place to suggest feature request (like a JIRA)?
How to become part of the Android beta group?
Default 08-29-2016, 02:05 PM
Yes.
f*** v-bands clamp
_ink's Avatar
Car: 335i DCT
Default 08-29-2016, 07:18 PM
Really looking forward to this! Seeing true numbers is much better for piece of mind.
Thanks Donnie!
SilverJester SilverJester is offline
Car: 2007 335i Coupe
Default 08-30-2016, 07:31 AM
I don't know if this has been mentioned yet or not, but there seems to be a bug (at least with the android version). If I connect to the JB4 while the device is in landscape mode, all gauges read -1 and do not update. I have to close the app and reconnect in portrait mode (disconnecting and reconnecting alone without closing the app doesn't work). If I connect while in portrait and then rotate to landscape everything works fine. This is true for both my nexus 7 and Galaxy S6.
2008 335i MT
VRSF Inlets | VRSF Chargepipe | Turbosmart Race Port | VRSF D-***** | VRSF 7" FMIC | BMS DCI | BMS Cowl Filters |Spec 3+ Clutch | mFactory Flywheel | UUC SSK | UUC DSSR | Rouge Engineering Trans Mounts (Best Mod Ever) | TWM A6 Leopard Shift Knob (1.07lbs, 2nd Best Mod) | Boost Concepts FPM-1 | Fuel-it ES-1 |JB4 G5 ISO | MHD Flasher
DSG03Bolt's Avatar
Car: 08 535i
Default 08-30-2016, 07:36 AM
Noticed this last night on my android tablet. I must close the app & try to reconnect a few times before it works properly. Or restart the tablet to get it to work
2008 535i
Car: F06 N55 640i Gran Coupe
Default 08-30-2016, 04:16 PM
iOS build is uploaded. Beta will be out tonight and the release should be out next week.
Includes:
Swipe to delete "Configs".
Bug fixes.
Hi Dmac, can you pls get the update release asap? Travelling to another country with lower Octance without being able to change map 6 setting is a nuisance, especially driving at high speed with 1 hand keying in the Duty Bias setting is really dangerous, pls release the map 6 delete function to the latest update or send me the beta version soon if u can. Thanks
2014/2009 M4/335 COUPE
AndyTuning Custom Map 6
SS ** n FULL Custom Exhaust
Custom BC forge 18/17 set up
_ink's Avatar
Car: 335i DCT
Default 08-30-2016, 04:47 PM
Just switch to a different map, I.e. Map 2
Default 08-31-2016, 05:27 AM
Got the beta update. Can now delete map 6 configs
Hi, how do you did that? How to delete map 6 configs??? I'm in the beta now, but don't seem to be able to delete any map 6 saved in it.
Anthony235's Avatar
Car: m235i
Default 08-31-2016, 07:27 AM
In the "load config" screen you swipe them to delete them.
Default 08-31-2016, 08:10 AM
Yes got it, thanks man!
Dcara Dcara is offline
Default But in latest firmware or android app??? - 09-03-2016, 03:07 PM
Hey guys. I just updated to the latest firmware and android app and I noticed that when I change the rpm value for the shift indicator in the app it's not updated when I check the setting in the gauges. Same goes if I change the value in the gauges. Anyone else notice this? Btw I'm using the android version of the app
Car: 2008 135i
Default 09-04-2016, 12:02 PM
For tuning support, make a post in the support section.
You can request things here.
Use this link to join the beta group. https://play.google.com/apps/testing...o91.jb4_mobile
It's probably not a bug with portrait vs landscape. The main bug with Android right now is that if you leave the app in the background for a period of time, the next connection bringing it from the background won't allow the gauges to get updated (like you are describing). Still investigating that
Resolved. Added to beta group.
Those 2 values aren't synced. The JB4 shift indicator is completely separate from the app's value. They must be set individually.
Hadn't checked the forum in a few days. If you need more immediate assistance, feel free to email me. support@jb4connectkit.com
Currently Active Users Viewing This Thread: 13 (0 members and 13 guests)
