Default JB4 All Weather Sleeve for F Series - 03-26-2015, 06:04 PM
We've had a small but steady report of water related issues with respect to the F Series JB4. When placed properly under the plastic covers it should be almost impossible for water to seep in to the board but placement isn't always perfect and sometimes it does happen. Of course BMS will warranty replace any water damaged board, but that also isn't very convenient for the end user.
So we've come up with a couple solutions to this potential problem. The first is an inexpensive solution. We've designed a special silicon/rubber sleeve that encloses the JB4 & harness connector. It's easy to install, rugged, and rated for both warm and cold climates. Attached is a photo of it in action. If you want one of these just grab one for $5 shipped from our N20 or N55 upgrades page. We have 500 or so in stock. Note, if you have a BMS DATA cable you'd have to either cut a slit (reducing its effectiveness) for it or only install this cover when you don't have the DATA cable installed.
http://www.burgertuning.com/N55_JB4_upgrades.html
The second option we're working on is upgrading the F series JB4 enclosures all together to a new CNC & ORING design that will be rugged & all weather. We've designed the new enclosure so it will house the JB4 (or stage1) circuit board, harness connector, and DATA cable connection. I expect it will retail in the $40-50 range and will remain an add-on option to our current plastic enclosures. We're in the middle of that design process now and I'll share more info on it as we're able to do so.
eyim1988 eyim1988 is offline
Car: 2011 e92 335i
Default 03-26-2015, 08:12 PM
awesome!
2fast4utoo! 2fast4utoo! is offline
Car: 135
Default 03-26-2015, 08:20 PM
Purchased! Great cost effective solution! Thanks again T!
ShlemN55's Avatar
ShlemN55 ShlemN55 is offline
Car: F30 335i msport
Default 03-26-2015, 08:22 PM
Nice !!! I need this .. Purchased.. Thanks T
1993 Dodge Caravan ( Bone Stock )
2016 Tanzanite Blue F80 M3 jb4 , awe non res, bmc filters.
TYC's Avatar
TYC TYC is offline
Car: X1 n20
Default 03-30-2015, 06:19 AM
Sweet. Def looking forward to the new aluminum enclosure!
2015 M235i Track Edition (1 of 50 in Canada)
-Custom ProTuningFreaks BM3 Tune (PTF Developer team)
-Dinan CF Intake, wrapped in gold heat tape from -Golidlocks Automotive.
- ER Charge ***** (H & C)
- GoFastBits Diverter valve
- MeaganRacing Solid Rear adj. upper Camber arms
- H&R Springs
- Dinan bumpstops
morkusyambo morkusyambo is offline
Car: 328i
Default 03-30-2015, 07:25 AM
Will the rubber sleeve fit a stage 1 S55 box?
Ando @ BMS's Avatar
BMS Customer Service
Car: bmw 335i
Default 03-30-2015, 10:27 AM
Stage 1 uses different enclosure. So no.You can just buy the JB4 High Temp enclosure to make it fit.
http://burgertuning.com/high_temp_JB4_enclosure.html
Car: 328i
Default 03-30-2015, 11:08 AM
I'm not worried about temps, so I guess I'll wait for the aluminum enclosures.
Shankska Shankska is offline
Car: BMW M235i
Default 04-02-2015, 04:39 PM
Just bought one! Thanks.
Car: 135
Default 04-07-2015, 06:53 AM
For those of us FXX guys equipped with the Burger Meth kit, Does the FSB should be enclosed as well? Will there be any heat issue if we do?
Default 04-07-2015, 08:09 AM
It's not overly sensitive but you can just cover the open top with a piece of black duct-tape if it's not under a cover.
Car: 135
Default 04-07-2015, 04:24 PM
BD_F22 BD_F22 is offline
Car: 2015 m235i xDrive
Default 04-08-2015, 09:11 PM
Hey Terry I purchased this for my jb4 and have the usb cable coming out of the other end what do you recommend I do? Just cut the closed end to allow the cable to run through?
Default 04-08-2015, 09:18 PM
I'd just cut a small slit with a razor.
sc67065's Avatar
sc67065 sc67065 is offline
Car: n55
Default 05-28-2015, 08:30 AM
I'm interested in this to prevent some of the water issues I've heard about. But, is this sleeve not ideal for SoCal climate? My logic tells me this is better for colder and more wet climates since the silicone would be trapping heat in the box. Would using this sleeve in hot places like SoCal be okay or should I pass?
Default 05-28-2015, 08:32 AM
Heat management is not an issue with the F series tuners. The sleeve should be used in any situation where the box might become soaked. In Socal the primary source of soaking is spraying the engine bay during a car wash...
endless_435's Avatar
endless_435 endless_435 is offline
Car: 435xi
Default 05-28-2015, 09:20 AM
Using one my self havent had any issues, I also tuck my data cable end underneath the sleeve and it holds it very well.
