Exo Performance Exo Performance is offline
Car: M3
Exclamation 2019 Tiguan - Issue - 04-25-2019, 02:41 PM
DME BT Gauge always in red
Codes P01106 and P0502
Car shift by itself at 6500rpm
Map 3
94 Octane
CTS Turbo ******* ********
Moderator
Default 04-25-2019, 03:48 PM
Map 3
94 Octane
DME BT and FP H are not used parameters on the Gen3B.
There is currently a issue with the fault reading on the app so they cannot be translated. Possible the related to the exhaust.
Log looks ok. Try map 2 and see if it give you more timing Ign1.
Not sure if the car has a gear lock mode where it wont upshift but typically most DSG will upshift at that rpm.
2021 VW Golf 8 R
Car: M3
Default 04-26-2019, 08:30 AM
Here is the map 2 logs
Customer said car feels better but definately not as strong as map 3
Moderator
Default 04-26-2019, 09:08 AM
Looks better. Power will most likely be more consistent.
2021 VW Golf 8 R
Car: M3
Default 05-17-2019, 08:10 AM
Here is a new log... Customer tried it again in map 3...
What's your though on this one?
Car is running great and definately stronger in map 3 thus the reason customer still wants to know if he can keep it safely in map 3.
