E90 335xi E90 335xi is offline
Car: 2011 BMW 335xi Sedan
Default JB4 DTC toggle on/off doesn't work on AWD (xi) - 04-09-2015, 10:37 AM
Hi guys, first post here.
I just got my BMS JB4 & intake a few weeks ago and I love it all.
Just having trouble with 1 thing: "Toggle on/off DTC push at startup"
I've tried it a bunch of times and it just won't toggle my DTC when I start the car.
I was however successfully able to use the toggles for stealth guage mode, and startup guage sweep without a problem.
What gives?
Default 04-09-2015, 10:52 AM
That function isn't Xi compatible.
Default 04-09-2015, 11:10 AM
Well that explains it! Thanks Terry.
BreakMyWallet's Avatar
BreakMyWallet BreakMyWallet is offline
Car: E60 535i Sport 6mt
Default 10-14-2016, 01:28 PM
What about 535i (RWD, not XI)?
I can't get it to work with mine.
2009 535i 6mt, PURE Stage 2, PSP 900IC, Fuel-It PI, PR N55 location ignition coils, VTT inlets, VRSF things, Injen Intake, RPi exhaust, Walbro 525, EOS BPM4.
Default 10-14-2016, 02:30 PM
If it doesn't work then its not compatible with that model yet.
Default 06-07-2018, 04:54 PM
Will functional DTC toggle be added for 535i someday?
Default 06-07-2018, 04:55 PM
We'd like to get to that some day but don't have a car here handy to work on it with.
5alive 5alive is offline
Car: JB535
Default 535i for DTC One Push - 02-06-2019, 02:44 AM
I'm in HB. What day should I stop by?
No, SERIOUSLY?!?!
2008 535i | 6MT | Evo CP (stock DV)| jB4 (duh) | BMS BEF (PumpUSA) | BMS DCI | 93 (via 91 + Octane booster) | E85 ~35% | MFactory SMF | Spec Stage 2+ Clutch | UUC STS | 7" Street FMIC | Toggle Switch Gas Pedal delete
157k - Maintenance (HPFP, LPFP sensor, Fuel sending unit, CPK sensor, Injectors (12), Plugs 97506 (.020), Delphi Coils, AGM Battery, starter, Koni FSD @ corners...)
