(#4026)
Bigjhouse Bigjhouse is offline
Car: 2016 q50 vr30
Default 04-02-2019, 08:09 AM
Terry, can you checkout my log, quick map 7 pull on around e30
Car: q50
Default 04-02-2019, 10:43 AM
Just a heads up, within the next few weeks I'll be doing a cheap LSD upgrade on the RWD model. I'll post up my install pics and impressions. Much cheaper than Z1/AMS. Stay tuned.
jrobohm's Avatar
jrobohm jrobohm is offline
Default 04-02-2019, 10:50 AM
Wavetrac’s LSD is a tall price point for sure. Are you opting for a slightly higher ratio vs stock ?
2017 Q50 Premium RWD
  • BMS JB4 w/ Fuel Wires
  • BMS WMI w/ PM8’s
  • Pure Stage 2 Turbos
  • Z1 PU Motor Mounts
  • AMS HPFP (RA338) & LPFP
  • AMS Flex Fuel Kit v2
  • AMS LDP
  • AMS CAI
  • Fast Intentions Res. Touring 2.5” CBE
  • Mishimoto Oil Catch Can
Car: q50
Default 04-02-2019, 10:53 AM
I'm happy with the stock gear ratio and appreciate the gas mileage I'm getting. I don't want the car having to shift to 5th at the top of the drag strip. I just want the full power going to both tires
Default 04-02-2019, 02:18 PM
Need the orignal CSV to open it in the JB4 windows interface.
Car: 2016 q50 vr30
Default 04-02-2019, 07:00 PM
hopefully this works
818eddyq50 818eddyq50 is offline
Car: 2018 Infiniti Q50
Default 04-02-2019, 08:32 PM
version 7 is the latest. Once you make a pull you go to logs and click on the correct log and when the window pops asking you to either view or export etc. it will show you the 0-60. At least thats how it is for Android.
for me theres no option to see 0-60 on ios.
Default 04-02-2019, 08:52 PM
Looks OK, but fuel wires might make sense for this application to lean AFR out a bit up top there.
PRQ50 PRQ50 is offline
Car: Q50
Default 04-02-2019, 08:59 PM
Terry can you check this log? Looks like my JB4 stopped requesting boost over ecu psi. Thanks
2017 Q50 RS AWD
JB4+FW
AMS intakes
FI ldp
FB HE
Fourg63 Fourg63 is offline
Car: Q50
Default 04-03-2019, 01:17 AM
Vehicle wasn't warmed up. Coolant temp dropped below 160 degrees disabling boost control. It's a safety feature.
Car: q50
Default 04-03-2019, 06:12 AM
Odd, others can see it.
Car: Q50
Default 04-03-2019, 06:23 AM
Thanks, I had driven for a while, but apparently it wasn’t long enough in 40 degree temperatures.
2017 Q50 RS AWD
JB4+FW
AMS intakes
FI ldp
FB HE
Car: 2016 q50 vr30
Default 04-03-2019, 08:07 AM
Cool, ive got the fuel wires just havent installed yet since im going back and forth with the dealer for now. Meth and fuel wire will be in the near future. thanks.
Default 04-03-2019, 09:38 AM
Working on updating our JB4 guide. Need some engine bay photos of the JB4 harness plugged in and also showing JB4 control box placement. Ideally on a stock engine bay. Our development cars have intakes on and too lazy to remove them.
40Rolls 40Rolls is offline
Car: 2018 Q50 Silver Sport
Default Map 2 Log - 04-03-2019, 10:27 AM
Terry could you take a look, first logged map with JB4. 18' silver Q50 rwd, ams down *****,93 oct, fuel wires, map 2 & manual 3rd to 4th pull
Default 04-03-2019, 12:02 PM
Short log but looks fine to me!
Car: Q50
Default 04-03-2019, 03:20 PM
Hi Terry, how does this short pull look to you?
2017 Q50 RS AWD
JB4+FW
AMS intakes
FI ldp
FB HE
Default 04-03-2019, 08:36 PM
Seems fine to me
Default 04-04-2019, 09:20 AM
Originally Posted by BoostedSlvrSport
Hi All , I am new to this community and recently installed my JB4 on my 2019 Silver Sport. I have a few logs that I would love for someone to review as I have some boost concerns. If you could point me in the right direction much would be appreciated. -thanks man
As a side note, is there a place where I can find a comprehensive explanation of all the features of the JB4? I would like to understand my own logs and what is happening to the car.
Lastly, any shops in North Jersey anyone could recommend for Dyno and tune on the JB4.
Just post the logs here if you want us to check them out.
While we're not in the training to read log business, but there some threads around you can get the basics from if you want to start learning.
Default 04-04-2019, 09:21 AM
Bump.
Jasonviper Jasonviper is offline
Car: Q60
Default 04-04-2019, 05:00 PM
Bump.
Terry I sent you an email with some pics
Default 04-04-2019, 06:26 PM
Thanks but need them with the JB4 style larger enclosure.
Serstylz2's Avatar
Car: 2019 Q50 Luxe
Default 04-05-2019, 07:30 AM
I can try to crop out the intakes because we have twin cars
12.64 @114mph
0-60 4.46
Default 04-05-2019, 08:28 AM
The other thing is I want a car without fuel wires for these photos.. Picky, I know. But if the photos don't match what customers get they become confused.
monsta121 monsta121 is offline
Car: Q50 SS
Default 04-05-2019, 09:13 AM
@Terry can you please take a look at these logs. Both are 3rd gear pulls starting at about 2k rpm.
Mods: jb4 with fuel wires, stillen intakes, megan ldp
Map: 6
