(#3976)
parsonsq50 parsonsq50 is offline
Car: Q50
Default 03-14-2019, 07:23 PM
That's as high as I'd run it, and you may have better results in map5. Evaluate both and see which works best for you.
Funny you say that, i though 5 felt a little stronger, but assumed since map7 was more boost, it would be better 🤷🏻*♂️
Robyn1114 Robyn1114 is offline
Car: 2017 Q60 Premium AWD
Default Please review - 03-15-2019, 11:46 AM
Terry
Can you please review this map 1 log. 3rd gear pull 20-120 mph completely stock premium on 91 octane.
Default 03-15-2019, 05:43 PM
Originally Posted by Robyn1114
Terry
Looks normal to me.
Mnom4369 Mnom4369 is offline
Car: Infiniti
Default Is my jb4 working properly ? - 03-16-2019, 05:57 PM
I can’t really tell if my jb4 working properly I tried uploading pics but it won’t let me .
Default 03-16-2019, 06:25 PM
Record a JB4 log under full throttle and post it here, and we can check the details.
Car: Infiniti
Default 03-16-2019, 08:07 PM
This is my data log
g0t2bmiirii's Avatar
Default 03-16-2019, 10:03 PM
Originally Posted by Mnom4369
This is my data log
Try data logging when you go full throttle. That’s where you can actually see if the car can handle the boost. I always data log when i go full throttle. That’s how you get the best reading for how much your car can handle the boost output
Car: Infiniti
Default Q50 jb4 log - 03-17-2019, 05:59 PM
Hey terry,
You think you view my log and see if everything looks correct ? This is my first couple of days with jb4 just want to make sure everything is good ?
Meet Google Drive – One place for all your files
Default 03-19-2019, 09:51 AM
Attach the CSV to this post and I can check it out.
TEH215 TEH215 is offline
Car: 2017 Infiniti Q60
Default 03-20-2019, 10:52 AM
Is there a viewer for the CSV files that runs in Windows?
monsta121 monsta121 is offline
Car: Q50 SS
Default 03-20-2019, 12:28 PM
@Terry @ BMS can you please take a look at these logs. Both are 3rd gear pulls starting at about 2k rpm.
Mods: jb4 with fuel wires, stillen intakes, megan ldp
Map: 6
PRQ50 PRQ50 is offline
Car: Q50
Default 03-20-2019, 03:49 PM
Has anyone been able to achieve boost over 18.5 on a Red Sport on JB 4 on 93 octane? On my RS I get 17 psi on map 1, 18 on map 2, map 3 and 5 only achieve 18 psi also.
2017 Q50 RS AWD
JB4+FW
AMS intakes
FI ldp
FB HE
JayStern85 JayStern85 is offline
Car: Infiniti Q50 RS400
Default 03-21-2019, 05:23 AM
I've seen up to 20 psi of boost in 3rd and 4th gear using map 6. I run up to +7 in midrange.
Car: q50
Default 03-21-2019, 07:13 AM
Do you have ********* or exhaust? Those turbo's need to breath to hit higher boost levels.
Car: Q50
Default 03-21-2019, 08:13 AM
I have FI ldp and stock exhaust.
2017 Q50 RS AWD
JB4+FW
AMS intakes
FI ldp
FB HE
Car: q50
Default 03-21-2019, 08:28 AM
Those optical sensors may be limiting you.
Car: Q50
Default 03-21-2019, 09:56 AM
This is on a RS? Could you share your map 6 settings? Thanks
2017 Q50 RS AWD
JB4+FW
AMS intakes
FI ldp
FB HE
Default 03-21-2019, 10:02 AM
I’ve read people with stock catback not being able to push higher psi. I can go 19-20 psi on e30. 2017 RS rwd.
Default 03-22-2019, 08:28 AM
Modifications will limit how much boost you can build, as will the factory WGDC tables the JB4 is tuning off. Keep in mind these are relatively small turbos and have a hard time keeping up with huge targets. When it starts to take a lot more WGDC to hit a given target you know you're outside of the turbos efficiency range.
SVNSYS SVNSYS is offline
Car: Infiniti Q60RS
Default Shifting takes a long time - 03-22-2019, 01:40 PM
Good evening,
When I activate met JB4 and put it on any MAP from 1-7, the shifting times are much longer then when I put it on MAP 0. Is this changable ?
Attached are my charts of MAP 3 and 7.
Also I'm looking for a manual for the JB4 mobile app. I'm new to this and don't know how to configure the User Adjusment Settings and WMI.
Thank you,
Steven from Belgium
Default 03-22-2019, 08:06 PM
You have a BMS WMI kit installed?
Serstylz2's Avatar
Car: 2019 Q50 Luxe
Default 03-23-2019, 01:57 PM
Fuel wire question, is the 12.5 AFR target only attainable at a certain RPM? Was doing some 40mph 4th gear WOT pulls and my AFRs were way up in the 17s and 18s on Map 7. 93 octane. Is there a problem?
12.64 @114mph
0-60 4.46
Car: q50
Default 03-23-2019, 02:46 PM
Your fuel trims maxxed? They updated the fuel wires to richen up the AFR for part of the Rpm curve. No way you should be that lean.
Serstylz2's Avatar
Car: 2019 Q50 Luxe
Default 03-23-2019, 07:06 PM
Don't know how to determine my fuel trims, can you assist?
12.64 @114mph
0-60 4.46
maxlegends maxlegends is offline
Car: q50
Default 03-23-2019, 07:22 PM
Terry i just posted 12.04 and 12.06 with jb4 flex wires and ms109 on map6 ��. I want to crack into 11's and suggestions? Whats the top numbers achieved with the q50 quarter mile no backend flash? Slips attached on imgur
Q50 world record jb4 - Album on Imgur
